 366-385
 386-405
 406-425
 426-445
 446-465
 466-485
 486-505
 906-912
Hi james
Sorry, I'm too "speedy", I had not noticed
the comma as separator in the fields ,
I wrote-2 *pi  to 2 * pi  - like in  Grasshopper-
Sorry...
Many  appreciate your answers
al
Hello Max,
I thougth about an interpolation for numarrays. I choose a spline interpolation and activated your average mode. Maybe you can use parts of the code. Maybe someone can test it, if it is useful ...
Have a nice day
Karsten
 basicFunctions.js
basicFunctions.js
 infonodes.js
infonodes.js
 litegraph.js
litegraph.js
 SM.nod
SM.nod
Message 7713.428 was deleted
Hello James,
it is exacly what it should do. You have 11 circles and the radius is given as a sequence of numbers (1,2,1). The average mode in the circles-node, maps a interpolation of the three values to the radii of the circles. You can add or delete a value also- (I hope so:-) It isn't tested well, because the integration in litegraph.js is just a hack - as good as I understand the code.
Have a nice day
Karsten
Hi Karsten,
I get it now. This will be very useful.
- James
But I don't know, if average is the right word for that? Max has to decide about it!
p.s.: for 2 values it degenerates to a linear interpolation:-)
Hi Max and Friends .
I am trying to redo the exercise (twist), (simple in Grasshopper ) but can not find the same Node
Polygon pts-
Node that I can use at the time, has three called input
center, radius, sides,
and not two , as the one used in the video......
Where am I doing wrong ????
Thanks for your help
al
Hello Al,
I think that Max hasn't released the node, typically he post also the exampe.nod file for new features -so we have to wait:-)
Have a nice day
Karsten
Thanks Karsten ,
I thought so, but I was not sure
best
al
Hi guys
I was busy few days, so I didn't wrote anything since tuesday.
Here is small announce for the new version:
PolygonPts node (done)
TransformPts node (done: twist, rotate; to do: explode)
Interpolation node (to do)
ConvertPts node improvements
pushFrame rad/deg bug fixed (again) :)) I accidentally wrote Math.pi instead of Math.PI in the last version.
I don't know when I will release the new version. Maybe this Sunday.
Good to know! Thanks a lot!
Sweet sounds to my ears.......
do not forget (tutor) exercises for beginners like me-
Great
al
I am testing it and it's great! Thanks.
Question for newbies: how do I extrude some shapes randomly? I can generate a random number but of course the number is used for every extrusion.
M.
maybe you have to set Long rather than Short
in the field math
al
PathPoints:-) only integration of the startframe evaluation is missing at the moment!
Have a nice day
Karsten
Hello James,
I had make some tests with the average-mode and found two bugs. If you want, you should correct this two lines:
        r.push((e[1]-e[0])); //error corrected was r.push(2*(e[1]-e[0])); !!!
        r.push((e[i]-e[i-1])-((r[i-1]*h[i-1])/u[i-1])); // error corrected was r.push((e[i]-e[i-1])-(r[i-1]*h[i-1]/u[i-1]));!!!
in basicFunctions.js -splineMap-function.
Have a nice day
Karsten
Thanks Karsten,
It fixed an anomaly in interpolation with > 3 values in radii input series
as well as crashing bug if U,V or W input centre value < the number
of values values in radii input series.
I can't wait until Max has finalised the foundations of node editor,
to see what you build upon it.
Keep up the great work
Hello James,
thanks for the reply. If you want to test another node, please test this one. But first you have to correct pushFrame in litegraph.js as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.436
PathArray in Points2.js generates an aligned pointarray along a curve. ShowFrame shows now all Frames in a pointarray - I think useful for test.
Have a nice day
Karsten
 infonodes.js
infonodes.js
 pa.nod
pa.nod
The new version is not ready yet. But today I wrote interpolation node for using with numarrays. At the moment it supports the following interpolation methods:
Linear, Cosine, Cubic, CatmullRom, Hermite, FritschCarlson
 366-385
 386-405
 406-425
 426-445
 446-465
 466-485
 486-505
 906-912
