 362-381
 382-401
 402-421
 422-441
 442-461
 462-481
 482-501
 902-912
Hi James, and Max ,
another question, sorry.......
How can I handle the n°. outputs
(In this case curves)-
As in the example posted to delete one
in order to make the Loft no Creased ?
(GH / Rhino you can)
and you can, in the future, implement this in "Elephant"
al
Hi  James
Many thanks for the help...
I need to ask other, maybe you could help my;
- How can I enter a domain of U and V in the Math node pt
  into  Fx3D Graph exists  a field (Min) and (Max) ?
- you can create parametrically, with values on slider,
  a Range -> (Domain / integer) ?
 -and you can , always create parametrically ,
  a Series of numbers -> Start Number / Interval / Number instances ?
thanks in advance
have a nice day
al
Hi Al
into Fx3D Graph exists a field (Min) and (Max) ?<<
An earlier iteration of MathArray node had inputs for UMin, UMax, VMin & UMax.
These have been removed with the name change to MathPoints.
I believe that Max is developing Range and series nodes to satisfy this requirement
and the others you mentioned    We need to wait and see.
-James
Hi Al
FROM YOUR IMAGE >> How insert domain Ex (-2pi to 2pi)<<
In the URange or VRange field type:
-2*PI,2*PI
exactly as above, and it will populate field with numerical values.
I'm noy sure if this answers your question.
Let me know
-James
Hi james
Sorry, I'm too "speedy", I had not noticed
the comma as separator in the fields ,
I wrote-2 *pi  to 2 * pi  - like in  Grasshopper-
Sorry...
Many  appreciate your answers
al
Hello Max,
I thougth about an interpolation for numarrays. I choose a spline interpolation and activated your average mode. Maybe you can use parts of the code. Maybe someone can test it, if it is useful ...
Have a nice day
Karsten
 basicFunctions.js
basicFunctions.js
 infonodes.js
infonodes.js
 litegraph.js
litegraph.js
 SM.nod
SM.nod
Message 7713.428 was deleted
Hello James,
it is exacly what it should do. You have 11 circles and the radius is given as a sequence of numbers (1,2,1). The average mode in the circles-node, maps a interpolation of the three values to the radii of the circles. You can add or delete a value also- (I hope so:-) It isn't tested well, because the integration in litegraph.js is just a hack - as good as I understand the code.
Have a nice day
Karsten
Hi Karsten,
I get it now. This will be very useful.
- James
But I don't know, if average is the right word for that? Max has to decide about it!
p.s.: for 2 values it degenerates to a linear interpolation:-)
Hi Max and Friends .
I am trying to redo the exercise (twist), (simple in Grasshopper ) but can not find the same Node
Polygon pts-
Node that I can use at the time, has three called input
center, radius, sides,
and not two , as the one used in the video......
Where am I doing wrong ????
Thanks for your help
al
Hello Al,
I think that Max hasn't released the node, typically he post also the exampe.nod file for new features -so we have to wait:-)
Have a nice day
Karsten
Thanks Karsten ,
I thought so, but I was not sure
best
al
Hi guys
I was busy few days, so I didn't wrote anything since tuesday.
Here is small announce for the new version:
PolygonPts node (done)
TransformPts node (done: twist, rotate; to do: explode)
Interpolation node (to do)
ConvertPts node improvements
pushFrame rad/deg bug fixed (again) :)) I accidentally wrote Math.pi instead of Math.PI in the last version.
I don't know when I will release the new version. Maybe this Sunday.
Good to know! Thanks a lot!
Sweet sounds to my ears.......
do not forget (tutor) exercises for beginners like me-
Great
al
I am testing it and it's great! Thanks.
Question for newbies: how do I extrude some shapes randomly? I can generate a random number but of course the number is used for every extrusion.
M.
maybe you have to set Long rather than Short
in the field math
al
PathPoints:-) only integration of the startframe evaluation is missing at the moment!
Have a nice day
Karsten
 362-381
 382-401
 402-421
 422-441
 442-461
 462-481
 482-501
 902-912
