Full Version: Parametric design in MoI?
Show messages:  1-11  …  352-371  372-391  392-411  412-431  432-451  452-471  472-491  …  912
25 Sep 2016   [#412]
Bug found in Slider and Knob nodes. Please update interface.js
26 Sep 2016   [#413] In reply to [#412]
Perfect! And in French! :)
26 Sep 2016   [#414] In reply to [#413]
Dear friends
can someone explain to me the features
(Points Math) with some example ..
something is simple ..... but other features
they are unknow for me-
I upload a starting file......
Many thank
al
Know Points Math.nod
26 Sep 2016   [#415]
New tests
Inspired by this video
https://www.youtube.com/watch?v=twOUPaqo-ak
26 Sep 2016   [#416] In reply to [#414]
Hi Al,
Tomorrow I'll explain how to use points and frames
26 Sep 2016   [#417] In reply to [#415]
Hi Max,
> Inspired by this video https://www.youtube.com/watch?v=twOUPaqo-ak
Hey...the old good Grasshopper is back !
To be perfectly honest, Grasshopper is by far the very best of Rhino, its point of excellence.
26 Sep 2016   [#418] In reply to [#414]
Al
(Points Math) with some example ..<
Point Math is simply Max's brilliant "FXGraph3d" script repurposed as a node.
An in depth discussion of FXGraph scripts can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.1
Attached is .nod file for generating Enneper surface with Points Math node.
Hope this helps
- James
27 Sep 2016   [#419] In reply to [#418]
Good Morning James
thanks for the file
of considerable clarification, but I ask you
how to add input into
feature
al
27 Sep 2016   [#420] In reply to [#416]
< Hi Al,
Tomorrow I'll explain how to use points and frames>
Hi Max
thanks in advance to all, look forward
your explanations, I'm sorry but I'm a beginner
al
27 Sep 2016   [#421] In reply to [#419]
Hi Al,
To add inputs to node, right button click on node and pull down: inputs/a
as shown.
Hope this helps
- James
27 Sep 2016   [#422] In reply to [#418]
Hi James, and Max ,
another question, sorry.......
How can I handle the n°. outputs
(In this case curves)-
As in the example posted to delete one
in order to make the Loft no Creased ?
(GH / Rhino you can)
and you can, in the future, implement this in "Elephant"
al
27 Sep 2016   [#423] In reply to [#421]
Hi James
Many thanks for the help...
I need to ask other, maybe you could help my;
- How can I enter a domain of U and V in the Math node pt
into Fx3D Graph exists a field (Min) and (Max) ?
- you can create parametrically, with values on slider,
a Range -> (Domain / integer) ?
-and you can , always create parametrically ,
a Series of numbers -> Start Number / Interval / Number instances ?
thanks in advance
have a nice day
al
27 Sep 2016   [#424] In reply to [#423]
Hi Al
into Fx3D Graph exists a field (Min) and (Max) ?<<
An earlier iteration of MathArray node had inputs for UMin, UMax, VMin & UMax.
These have been removed with the name change to MathPoints.
I believe that Max is developing Range and series nodes to satisfy this requirement
and the others you mentioned We need to wait and see.
-James
27 Sep 2016   [#425] In reply to [#423]
Hi Al
FROM YOUR IMAGE >> How insert domain Ex (-2pi to 2pi)<<
In the URange or VRange field type:
-2*PI,2*PI
exactly as above, and it will populate field with numerical values.
I'm noy sure if this answers your question.
Let me know
-James
27 Sep 2016   [#426] In reply to [#425]
Hi james
Sorry, I'm too "speedy", I had not noticed
the comma as separator in the fields ,
I wrote-2 *pi to 2 * pi - like in Grasshopper-
Sorry...
Many appreciate your answers
al
28 Sep 2016   [#427] In reply to [#383]
Hello Max,
I thougth about an interpolation for numarrays. I choose a spline interpolation and activated your average mode. Maybe you can use parts of the code. Maybe someone can test it, if it is useful ...
Have a nice day
Karsten
basicFunctions.js
infonodes.js
litegraph.js
SM.nod
Message 7713.428 was deleted
28 Sep 2016   [#429] In reply to [#428]
Hello James,
it is exacly what it should do. You have 11 circles and the radius is given as a sequence of numbers (1,2,1). The average mode in the circles-node, maps a interpolation of the three values to the radii of the circles. You can add or delete a value also- (I hope so:-) It isn't tested well, because the integration in litegraph.js is just a hack - as good as I understand the code.
Have a nice day
Karsten
28 Sep 2016   [#430] In reply to [#429]
Hi Karsten,
I get it now. This will be very useful.
- James
28 Sep 2016   [#431] In reply to [#430]
But I don't know, if average is the right word for that? Max has to decide about it!
