Full Version: Parametric design in MoI?
Show messages:  1-10  …  351-370  371-390  391-410  411-430  431-450  451-470  471-490  …  911-912
25 Sep 2016   [#411]
Dear friends, don't use .nod from the old beta version. And don't use old .js files.
This software still in developing. I'm changing nodes, variables, logic, names.
I'll think about back compatibility after v.1.0 release only.
25 Sep 2016   [#412]
Bug found in Slider and Knob nodes. Please update interface.js
26 Sep 2016   [#413] In reply to [#412]
Perfect! And in French! :)
26 Sep 2016   [#414] In reply to [#413]
Dear friends
can someone explain to me the features
(Points Math) with some example ..
something is simple ..... but other features
they are unknow for me-
I upload a starting file......
Many thank
al
Know Points Math.nod
26 Sep 2016   [#415]
New tests
Inspired by this video
https://www.youtube.com/watch?v=twOUPaqo-ak
26 Sep 2016   [#416] In reply to [#414]
Hi Al,
Tomorrow I'll explain how to use points and frames
26 Sep 2016   [#417] In reply to [#415]
Hi Max,
> Inspired by this video https://www.youtube.com/watch?v=twOUPaqo-ak
Hey...the old good Grasshopper is back !
To be perfectly honest, Grasshopper is by far the very best of Rhino, its point of excellence.
26 Sep 2016   [#418] In reply to [#414]
Al
(Points Math) with some example ..<
Point Math is simply Max's brilliant "FXGraph3d" script repurposed as a node.
An in depth discussion of FXGraph scripts can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.1
Attached is .nod file for generating Enneper surface with Points Math node.
Hope this helps
- James
27 Sep 2016   [#419] In reply to [#418]
Good Morning James
thanks for the file
of considerable clarification, but I ask you
how to add input into
feature
al
27 Sep 2016   [#420] In reply to [#416]
< Hi Al,
Tomorrow I'll explain how to use points and frames>
Hi Max
thanks in advance to all, look forward
your explanations, I'm sorry but I'm a beginner
al
27 Sep 2016   [#421] In reply to [#419]
Hi Al,
To add inputs to node, right button click on node and pull down: inputs/a
as shown.
Hope this helps
- James
27 Sep 2016   [#422] In reply to [#418]
Hi James, and Max ,
another question, sorry.......
How can I handle the n°. outputs
(In this case curves)-
As in the example posted to delete one
in order to make the Loft no Creased ?
(GH / Rhino you can)
and you can, in the future, implement this in "Elephant"
al
27 Sep 2016   [#423] In reply to [#421]
Hi James
Many thanks for the help...
I need to ask other, maybe you could help my;
- How can I enter a domain of U and V in the Math node pt
into Fx3D Graph exists a field (Min) and (Max) ?
- you can create parametrically, with values on slider,
a Range -> (Domain / integer) ?
-and you can , always create parametrically ,
a Series of numbers -> Start Number / Interval / Number instances ?
thanks in advance
have a nice day
al
27 Sep 2016   [#424] In reply to [#423]
Hi Al
into Fx3D Graph exists a field (Min) and (Max) ?<<
An earlier iteration of MathArray node had inputs for UMin, UMax, VMin & UMax.
These have been removed with the name change to MathPoints.
I believe that Max is developing Range and series nodes to satisfy this requirement
and the others you mentioned We need to wait and see.
-James
27 Sep 2016   [#425] In reply to [#423]
Hi Al
FROM YOUR IMAGE >> How insert domain Ex (-2pi to 2pi)<<
In the URange or VRange field type:
-2*PI,2*PI
exactly as above, and it will populate field with numerical values.
I'm noy sure if this answers your question.
Let me know
-James
27 Sep 2016   [#426] In reply to [#425]
Hi james
Sorry, I'm too "speedy", I had not noticed
the comma as separator in the fields ,
I wrote-2 *pi to 2 * pi - like in Grasshopper-
Sorry...
Many appreciate your answers
al
28 Sep 2016   [#427] In reply to [#383]
Hello Max,
I thougth about an interpolation for numarrays. I choose a spline interpolation and activated your average mode. Maybe you can use parts of the code. Maybe someone can test it, if it is useful ...
Have a nice day
Karsten
basicFunctions.js
infonodes.js
litegraph.js
SM.nod
Message 7713.428 was deleted
28 Sep 2016   [#429] In reply to [#428]
Hello James,
it is exacly what it should do. You have 11 circles and the radius is given as a sequence of numbers (1,2,1). The average mode in the circles-node, maps a interpolation of the three values to the radii of the circles. You can add or delete a value also- (I hope so:-) It isn't tested well, because the integration in litegraph.js is just a hack - as good as I understand the code.
Have a nice day
Karsten
28 Sep 2016   [#430] In reply to [#429]
Hi Karsten,
I get it now. This will be very useful.
- James
