Full Version: Parametric design in MoI?
Show messages:  1-15  …  336-355  356-375  376-395  396-415  416-435  436-455  456-475  …  896-912
22 Sep 2016   [#396]
Frenchy Pilou
>Can i start translations of new nodes or I must wait some other updates?
No need to wait, you can start now
>PS I suppose this can be made ?
I can't implement this using current javascript api. Let's wait until Michael release MoI v.4.
22 Sep 2016   [#397] In reply to [#396]
So maybe tomorrow! :)
And wait & see 4
22 Sep 2016   [#398] In reply to [#395]
Hello Max,
many thanks for the commented example. The important information for me at first is the automatic assignment of the sequence of the inputs to the parameters sequence of the callback, I supposed that, but I was not shure.
(// callback function which will be called for processing of each value set (center = input0, r = input1, rt = input2, s = input3) )
Am I right, that I can also direct access to the elements of a numarray with [] ? I can't find a explicit definition of that type!?
Have a nice evening
Karsten
p.s.: Incredible what is possible!
22 Sep 2016   [#399] In reply to [#398]
Karsten
Yes, you can access any element. It's just an array like [1,2,3,4,5].
22 Sep 2016   [#400] In reply to [#395]
Hi Max,
Thanks a lot for the little tutorial. Much appreciated.
When I used previous versions of Project Elephant, I needed to comb through the code many times to understand the businnes logic...
I'm going to transfer this new logic into my old nodes.
Good night!
23 Sep 2016   [#401] In reply to [#400]
Hello
My Friends I are in confusion.............
I started using Elephant, and I uploaded some applications....
Now, I post pictures of my ui
where you see what I've uploaded ...
Considering the last release of the legendary Max
the question is;
What should I charge, to have the updated features, I can add
that load in my Node Editor without removing what is already
..... or , do I have to remove everything, and in this case what should I enter
I await yours suggestion
regards
al
sorry for my bad English, I hope
I understand my problem
ui-Nodeedotor1.jpg  ui-Nodeedotor2.jpg  ui-Nodeedotor3.jpg  ui-Nodeedotor4.jpg  ui-Nodeedotor5.jpg
23 Sep 2016   [#402] In reply to [#401]
Hello Al,
it seems that you use a very old version of the Elephant.(Date 2015). So you should rename your nodeeditor folder to e.g. nodeeditor-old. Than extract the archive and rename the folder nodeeditor.0.77.a to nodeeditor. Copy the folder to /ui of your Moi installation. Your node-files will not work with the new version - if you need them, you can change or dublicate your shortcut-key and can use them also.
Have a nice day
Karsten
23 Sep 2016   [#403]
It's me or there is no "a" on the N° 0.77a of the last Elephant ?
23 Sep 2016   [#404]
@Max : here the lang.js (0.77a) If you can add this part in your futur version (s) that will help me for avoid to reload numerous old versions! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.js
Maybe there is somewhere in Sub- menus, ... something other to translate ?
French version of the Nodes! :)
23 Sep 2016   [#405] In reply to [#402]
Hi Karsten
Many Many Many....Thanks for your indication
Now Ok - Work fine
best
al
24 Sep 2016   [#406]
v.0.80
Added function updateThisNodeGraph. This function updates node graph without canvas reloading.
Knob, Slider and Output nodes has been rewritten. Now they use updateThisNodeGraph. Significant interface performance boost!
Fixed pointArray.pushFrame deg/rad bug
Changed node connections (lot of graphical changes)
Arrays group renamed to Points
Due lack of time I didn't tested all new graphical features well. Send me a message if you find glitches and bugs.
25 Sep 2016   [#407] In reply to [#406]
Hello Max,
thanks for the update, but I have some problems to get it to run. It seems that arrays.js is missing - as file and as link in index.html!?
Have a nice evening
Karsten
p.s.: Adding from 0.77a fixed it:-)
25 Sep 2016   [#408] In reply to [#407]
Hi Karsten,
I've renamed Arrays section to Points in the last version.
25 Sep 2016   [#409] In reply to [#408]
Hello Max,
thanks for the reply. Ok, I understood! And now I see you mentioned it! I've tested the example.0.77 and get some errors, so I fixed it in the wrong way.
Have a nice evening
Karsten
25 Sep 2016   [#410]
v 0.8 with example 0.77a
25 Sep 2016   [#411]
Dear friends, don't use .nod from the old beta version. And don't use old .js files.
This software still in developing. I'm changing nodes, variables, logic, names.
I'll think about back compatibility after v.1.0 release only.
25 Sep 2016   [#412]
Bug found in Slider and Knob nodes. Please update interface.js
26 Sep 2016   [#413] In reply to [#412]
Perfect! And in French! :)
26 Sep 2016   [#414] In reply to [#413]
Dear friends
can someone explain to me the features
(Points Math) with some example ..
something is simple ..... but other features
they are unknow for me-
I upload a starting file......
Many thank
al
Know Points Math.nod
26 Sep 2016   [#415]
New tests
Inspired by this video
https://www.youtube.com/watch?v=twOUPaqo-ak
