Full Version: Parametric design in MoI?
Show messages:  1-19  …  320-339  340-359  360-379  380-399  400-419  420-439  440-459  …  900-912
19 Sep 2016   [#380] In reply to [#378]
Hi Max,
...very promising results!
> Today evening I rewrote all nodes except arrays.
Does it mean that you are not going to add any new features to PointArray ?
For example : programmatic ways to specify the iteration order, or parameters to specify start,end,step,
or the possibility to map every array element to a generic tag object (IMHO this would be a very powerful feature, for example link an array element with a
GeometryFactory Subclasses).
Etc...etc...
I hope you have the time and and desire to do it.
Ciao!
19 Sep 2016   [#381] In reply to [#376]
>Some times ago, when you developed the excellent SubDiv scripts, if I remember correctly, you said that one day you'd add the ability to accept surfaces with more then 4 edges. Do you think to upgrade SubDiv script in order to give it that feature ?
Hi Marco,
I have no plans to continue developing of the Subdiv script this year. Maybe later.
I will add a new features, but not now.
19 Sep 2016   [#382] In reply to [#381]
Ok Max.
Thanks for the clarifications.
Ciao!
21 Sep 2016   [#383]
Yes! I did it! :)
In this version I replaced "number" type with "numarray". Nodeeditor now uses only three types of data: objectlist (built-in moi type, in fact it's object array), point/frame array, number array.
Now you can send multiple values to each node input.
For example, you can create Circle node and set radius "10,15,33", and you will get three circles(use "," as array separator and "." as decimal separator).
Or create Point node and set X "0,2,4", Y "0,3,6", Z "0,5,10". In this case nodeeditor will process all arrays simultaneously. You will get three points(x,y,z): (0,0,0) (2,3,5) (4,6,9)
Also you can set arrays with a different lengths. In this case the arrays can be processed with different methods. Right now I implemented two methods "Long" and "Short"
This picture will help you to understand how it works.
Later I'll add Cross and Interpolation modes. But first I need to make "resize/interpolation" node.
Also I need to make Range slider node because some nodes uses arrays as range settings.
21 Sep 2016   [#384] In reply to [#383]
Hi Max!
I'm very glad to read this your post! :)
Finally now I can rewrite and finish all my utility nodes.
Tomorrow i will start to test your new NodeEditor.
Thanks a lot and good night!
21 Sep 2016   [#385]
Variable geometry! :)
French version of the Manual! ;)
21 Sep 2016   [#386] In reply to [#385]
Hi Pilou
It seems you've got duplicated arrays. Is that bug?
22 Sep 2016   [#387]
Short mode bug fixed
22 Sep 2016   [#388] In reply to [#386]
I have just launch the script! ;)
I see that was advantageous! :D
22 Sep 2016   [#389] In reply to [#388]
I can't reproduce this bug. It looks like you accidentally pressed Apply button.
22 Sep 2016   [#390] In reply to [#389]
Surrely because I relaunch Moi and all works fine! ;)
22 Sep 2016   [#391]
Can i start translations of new nodes or I must wait some other updates?
PS I suppose this can be made ?
22 Sep 2016   [#392] In reply to [#383]
Hello Max,
thanks for sharing this great work. I've started to study your changes and saw there are a lot. I think it will take a while, until I understand all the improvements. I've tested also some of my old nodes without number inputs and they all seems to work:-) Only the pushFrame has still the rad/deg conversion problem?
Thanks a lot and have a nice day
Karsten
22 Sep 2016   [#393] In reply to [#392]
Hi Karsten,
I've forgot about this. Fixed. :)
Most noticable change is processInOut function. I'll explain how to use it.
22 Sep 2016   [#394] In reply to [#393]
Hi Max,
Explanations will be much appreciated. Thanks.
22 Sep 2016   [#395]
Just finished my supper :) Now I'm ready to explain how to write nodes for the last version of nodeeditor.
this is an example. check the comments
function Star() // let's make a new node
	this.addInput("Center","pointarray");		// input 0, type: pointarray
	this.addInput("Radius","numarray");		// input 1, type: numarray. In fact it's just a common numeric array like [1,2,3,4,5]
	this.addInput("Ratio","numarray");		// input 2, type: numarray
	this.addInput("Sides","numarray");		// input 3, type: numarray
	this.addOutput("Out","objectlist");		// output 0, type: objectlist
	this.properties = { mode:["Long","Long","Short"], radius:[1], ratio:[0.4], sides:[5] };
	// each node has two types of properties. both of them will stored when you save a .nod file, or clone a node
	// there  are only one difference: .properties is shown in nodeinfo panel and .internal is hidden
	// string arrays like mode:["Long","Long","Short"] will be processed as a droplist. First value "Long" points to selected value. Other ones is available values: "Long", "Short".
	// numeric arrays will be processed as numarrays
Star.title = "Star";	// default title
Star.desc = "Star";	// legacy litegraph parameter. At the moment I don't use it.
Star.prototype.onExecute = function()	// this function will run on node execution command
	var data = this.processInOut(this.properties.mode[0], this.multiProcess, null, this.properties.radius, this.properties.ratio, this.properties.sides);
	// .processInOut function processes input arrays and creates output arrays
	// first parameter: (string) array processing mode.
	// modes supported:
	// Short, Long as described above in my post
	// Short+, Long+ same as  Short, Long, but objectarray will be processed as one element
	// Long# same as Long, but pointarray will be processed as one element
	// second parameter: callback function which will be called for processing of each value set (important!)
	// other parameters is optional. it's a default values for each input, which will be used if the input is not connected
	// you may skip it or set it to null. in this case processInOut function will generate default value automatically.
	// autovalue for numarray: [0]
	// autovalue for pointarray: (0,0,0)
	// autovalue for objectlist: empty objectlist
	// if you want to use another values, you need to set them directly like in this example:
	// null - autovalue(0,0,0),  this.properties.radius - [1],  this.properties.ratio - [0.4],  this.properties.sides - [5]
	// this function returns structure { inputs:[ input0, input1, ... input n], outputs:[output0, output1, ... output n]}
	// input0, input1, ... input n  - if the input connected, it wil return connected node data
	// output0, output1, ... output n  - returns concated output data generated by callback function for each output
	this.properties.radius = data.inputs[1];  // you can update properties values if input data is changed
	this.properties.ratio = data.inputs[2];
	this.properties.sides = data.inputs[3];
	this.setOutputData(0, data.outputs[0]); // set node output data
Star.prototype.multiProcess = function(center, r, rt, s) // callback function which will be called for processing of each value set (center = input0, r = input1, rt = input2, s = input3)
	// object array data will be sent as objectarray with one object (except Long+ Short+ modes)
	// point array data will be sent as pointarray with one object (except Long# mode)
	// numarray data will be sent as number
	var frame = center.getFrame();  // center.getFrame() = center.getFrame(0);
	return [factory( 'polygonstar', frame, frame.evaluate( 0, r, 0 ), s, frame.evaluate( 0, r*rt, 0 ))];
	// this function should return array [ output0, output1, ... output n ]
	// return [factory( 'polygonstar', frame, frame.evaluate( 0, r, 0 ), s, frame.evaluate( 0, r*rt, 0 ))]
	// is the same as
	// var outputs = [];
	// outputs[0] = factory( 'polygonstar', frame, frame.evaluate( 0, r, 0 ), s, frame.evaluate( 0, r*rt, 0 ));
	// return outputs;
	// if node has more than one output you nned to set outputs[1], outputs[2] .. etc
	// correct output[n] data is objectlist / pointarray / number
LiteGraph.registerNodeType("Curves/Star", Star);
22 Sep 2016   [#396]
Frenchy Pilou
No need to wait, you can start now
I can't implement this using current javascript api. Let's wait until Michael release MoI v.4.
22 Sep 2016   [#397] In reply to [#396]
So maybe tomorrow! :)
And wait & see 4
22 Sep 2016   [#398] In reply to [#395]
Hello Max,
many thanks for the commented example. The important information for me at first is the automatic assignment of the sequence of the inputs to the parameters sequence of the callback, I supposed that, but I was not shure.
(// callback function which will be called for processing of each value set (center = input0, r = input1, rt = input2, s = input3) )
Am I right, that I can also direct access to the elements of a numarray with [] ? I can't find a explicit definition of that type!?
Have a nice evening
Karsten
p.s.: Incredible what is possible!
22 Sep 2016   [#399] In reply to [#398]
Karsten
Yes, you can access any element. It's just an array like [1,2,3,4,5].
