 306-325
 326-345
 346-365
 366-385
 386-405
 406-425
 426-445
 906-912
Hi Max!
How are you ?
> I have no time for programming right now, but it will not last for long. Wait two or three weeks.
What about the new release of project Elephant ?
Ciao!
- Marco (mkdm).
Repetita iuvant...
Hi Max!
How are you ?
Ciao!
- Marco (mkdm).
Hi Marco! :)
I don't know when I release the new version. :(
I'll try to do it this month.
Hello Max!
OK, that's good to know !
Message 7713.370 was deleted
Hi guys! :)
Sorry for delay.. My work takes all free time during last months.
But today I wrote a few lines of code :)
Take your time!
Hi Max!
I'm glad to see you back here!
Waiting for your new version of NodeEditor...
So, I can finally finish my bunch of utility nodes for pointArray() data structure.
Ciao!
Hi Marco
I made a lot of changes in the internal structure today. The work goes faster than expected. :)
Right now I rewrite all nodes for using numarrays as input data. It will take couple of days.
Wait for the new version next week.
Hi Max,
I'm glad to know that your work is almost done!
Well...which means most likely I have to rewrite some portions of my utility nodes.
I'll wait and see :)
Ciao!
P.S. One last question Max.
Some times ago, when you developed the excellent SubDiv scripts, if I remember correctly,
you said that one day you'd add the ability to accept surfaces with more then 4 edges.
Do you think to upgrade SubDiv script in order to give it that feature ?
Thanks a lot and have a nice day.
Red star! ;)
Today evening I rewrote all nodes except arrays. I'm very impressed with the results.
Yes you can! Bravo!
Hi Max,
...very promising results!
Does it mean that you are not going to add any new features to PointArray ?
For example : programmatic ways to specify the iteration order, or parameters to specify start,end,step,
or the possibility to map every array element to a generic tag object (IMHO this would be a very powerful feature, for example link an array element with a
GeometryFactory Subclasses).
Etc...etc...
I hope you have the time and and desire to do it.
Ciao!
>Some times ago, when you developed the excellent SubDiv scripts, if I remember correctly, you said that one day you'd add the ability to accept surfaces with more then 4 edges. Do you think to upgrade SubDiv script in order to give it that feature ?
Hi Marco,
I have no plans to continue developing of the Subdiv script this year. Maybe later.
I will add a new features, but not now.
Ok Max.
Thanks for the clarifications.
Ciao!
Yes! I did it! :)
In this version I replaced "number" type with "numarray". Nodeeditor now uses only three types of data: objectlist (built-in moi type, in fact it's object array), point/frame array, number array.
Now you can send multiple values to each node input.
For example, you can create Circle node and set radius "10,15,33", and you will get three circles(use "," as array separator and  "." as decimal separator).
Or create Point node and set X "0,2,4", Y "0,3,6", Z "0,5,10". In this case nodeeditor will process all arrays simultaneously. You will get three points(x,y,z): (0,0,0)   (2,3,5)  (4,6,9)
Also you can set arrays with a different lengths. In this case the arrays can be processed with different methods. Right now I implemented two methods "Long" and "Short"
This picture will help you to understand how it works.
Later I'll add Cross and Interpolation modes. But first I need to make "resize/interpolation" node.
Also I need to make Range slider node because some nodes uses arrays as range settings.
Hi Max!
I'm very glad to read this your post! :)
Finally now I can rewrite and finish all my utility nodes.
Tomorrow i will start to test your new NodeEditor.
Thanks a lot and good night!
Variable geometry! :)
French version of the Manual! ;)
 306-325
 326-345
 346-365
 366-385
 386-405
 406-425
 426-445
 906-912
