I have this at start but after all works fine! (Maybe an extra translation of something...)
Or maybe the default node that I have erased in previous session ?
And quasi all nodes are now in French! Not so evident! :)
Hi Max
Great Job... Wonderful
Your Plug make a quality jump to Moi...
I have a question ;
Can I install the plug NodeEditer , without , before to install
Custom UI in my computer
thanx
al
>> Generally all words between 2 "" ?
No. You can safely change only "In" "Out" Loft.title Loft.desc
P.S. Don't waste your time. Wait for the beta version.
speedy
>> Can I install the plug NodeEditer , without , before to install Custom UI in my computer
Yes. You need to extract archive to /ui/ directory and then bind "moi.ui.createDialog...." command to any button you want (Options/Shortcut keys).
Had a very brief peek at the code to see about trying to code catenary, or something.
(This may be within my capability, after the roof leaks are patched:-)
In general it can arrive some problems with accents! (UTF / ANSI)
For the moment seems I must convert to ANSI when I edit the file and resave!
You will post a text(s) file(s) ressource with list with some items with empty second part of line like above
or I must collect myself some words in some existing little files ?
(i am not sure in all cases if it's a real word to translate or a variable or other! ;)
It's ok. Just convert the file to UFT and send it to me.
>>I must collect some words in some existing little files ?
Yes, but you don't need to dig into the files. Just translate everything you see. Order doesn't matter.
