Show messages: 1-2 … 263-282 283-302 303-322 323-342 343-362 363-382 383-402 … 903-912
03_order_of_selection.3dm
04_order_of_selection.nod
litegraph.js
wrappedFunctions.js
curves2.js
// PatternSelectArray
function PatternSelArray()
this.addInput("In","pointarray");
this.addInput("Start","number");
this.addInput("Qt_Max","number");
this.addInput("Step","number");
this.addOutput("Out","pointarray");
this.addOutput("Elems","number");
this.addOutput("Source","pointarray");
this.properties = { mode:["Pattern + Subset", "Pattern + Subset", "Subset + Pattern"],
pattern:"+",
start:0,
qt_max:-1,
step:1};
PatternSelArray.title = "PatternSelArray";
PatternSelArray.desc = "PatternSelArray";
PatternSelArray.prototype.onExecute = function()
//if (this.properties.order[0] == "By Selection") {
var source = this.getInputData(0, new pointArray());
this.properties.pattern = this.properties.pattern.trim();
var usePattern = false;
var isMixedPattern = false;
// check the pattern
if (this.properties.pattern != '') {
// check if pattern contains valid characters
usePattern = this.properties.pattern.match('^[+\-0-1]+$');
if (usePattern) {
// check if pattern contains only include characters (+ or 1)
usePattern = !this.properties.pattern.match('^[+1]+$');
if (usePattern) {
// if pattern contains both include and exclude characters, then the pattrn will be used
// otherwise it means that contains only exclude characters (- or 0), and therefore
// the output pointarray list will be empty
isMixedPattern = !this.properties.pattern.match('^[\-0]+$');
var output = new pointArray(); // init to empty list
if (usePattern) {
if (isMixedPattern) {
var len = source.getLength();
var cn = 0;
for (i = 0; i < len ; i++) {
if ( this.properties.pattern[cn] === '1' || this.properties.pattern[cn] === '+') {
var source_elem = source.getElement(i);
output.push(source_elem.pt.x,
source_elem.pt.y,
source_elem.pt.z,
source_elem.AngleX,
source_elem.AngleY,
source_elem.AngleZ,
source_elem.Size);
cn = (cn < this.properties.pattern.length-1) ? cn+1 : 0;
} else {
// elaborate the whole source pointarray
this.properties.pattern = '';
output = source;
var outLength = output.getLength();
this.properties.start = this.getInputData(1, this.properties.start);
if (this.properties.start < 0) this.properties.start = 0;
if (this.properties.start > (outLength - 1)) this.properties.start = (outLength - 1);
this.properties.qt_max = this.getInputData(2, this.properties.qt_max);
if ((this.properties.qt_max < 0) || (this.properties.qt_max > outLength)) this.properties.qt_max = outLength;
this.properties.step = this.getInputData(3, this.properties.step);
if (this.properties.step <= 0) this.properties.step = 1;
if (this.properties.step > outLength) this.properties.step = outLength;
// generate the final pointarray list
var outputFinal = new pointArray();
for (i = this.properties.start, cont = 0; i < outLength && cont < this.properties.qt_max; i += this.properties.step, cont++) {
var source_elem = output.getElement(i);
outputFinal.push(source_elem.pt.x,
source_elem.pt.y,
source_elem.pt.z,
source_elem.AngleX,
source_elem.AngleY,
source_elem.AngleZ,
source_elem.Size);
output = null;
this.setOutputData(0, outputFinal);
this.setOutputData(1, outputFinal.getLength());
this.setOutputData(2, source);
this.outputs[1].label = "Elems(" + outputFinal.getLength() + ")";
LiteGraph.registerNodeType("Arrays/PatternSelArray", PatternSelArray);
this.size = [160,70];
this.minsize = [160,70];
this.addInput("Start_Idx","number");
pattern:"",
start_idx:0,
qt_max:-1,
step:1 };
source = the source array
start_idx = index of the first element to pick
numMaxElem = max number of elements that will be present in the resulting array
step = step amount for the for..loop
var getPointArraySection = function(source, start_idx, numMaxElem, step) {
var result = new pointArray();
if (source) {
var sourceLength = source.getLength();
for (i = start_idx, cont = 0; i < sourceLength && cont < numMaxElem; i += step, cont++) {
result.push(source_elem.pt.x,
source_elem.pt.y,
source_elem.pt.z,
source_elem.AngleX,
source_elem.AngleY,
source_elem.AngleZ,
source_elem.Size);
return result;
pattern = string that define the selection pattern
1 or + = pick element
0 or - = skip element
var applyPatternToPointArray = function(source, pattern)
function ResultObj(pattern) {
this.array = new pointArray();
this.pattern = pattern;
var result = new ResultObj(pattern);
if (pattern) {
result.pattern = pattern.trim();
if (result.pattern != '') {
usePattern = result.pattern.match('^[+\-0-1]+$');
if (usePattern) {
usePattern = !result.pattern.match('^[+1]+$');
if (usePattern) {
isMixedPattern = !result.pattern.match('^[\-0]+$');
if (usePattern) {
var patLen = result.pattern.length;
var cn = 0;
if ( result.pattern[cn] === '1' || result.pattern[cn] === '+') {
result.array.push(source_elem.pt.x,
source_elem.pt.y,
source_elem.pt.z,
source_elem.AngleX,
source_elem.AngleY,
source_elem.AngleZ,
source_elem.Size);
cn = (cn < (patLen - 1)) ? (cn + 1) : 0;
} else {
result.pattern = '';
result.array = source;
return result;
// Business logic
this.properties.start_idx = this.getInputData(1, this.properties.start_idx);
var patternedArray;
var outputIntermediate;
var outIntermLength;
if (this.properties.mode[0] == "Pattern + Subset") {
patternedArray = applyPatternToPointArray(source, this.properties.pattern);
outputIntermediate = patternedArray.array;
outIntermLength = outputIntermediate.getLength();
} else {
outputIntermediate = source;
outIntermLength = source.getLength();
if ((this.properties.start_idx < 0) || (this.properties.start_idx > (outIntermLength - 1))) this.properties.start_idx = 0;
if (this.properties.qt_max < 0) this.properties.qt_max = outIntermLength;
outputIntermediate = getPointArraySection(outputIntermediate,
this.properties.start_idx,
this.properties.qt_max,
if (this.properties.mode[0] == "Subset + Pattern") {
patternedArray = applyPatternToPointArray(outputIntermediate, this.properties.pattern);
this.properties.pattern = patternedArray.pattern;
patternedArray = null;
this.outputs[0].label = "Out (" + outputIntermediate.getLength() + ")";
this.outputs[1].label = "Elems (" + outputIntermediate.getLength() + ")";
this.inputs[0].label = "In (" + source.getLength() + ")";
this.setOutputData(0, outputIntermediate);
this.setOutputData(1, outputIntermediate.getLength());
// ArrayReplicator
function ArrayReplicator()
this.labels = "abcdef";
this.size = [140,40];
this.minsize = [140,40];
this.internal = {a:1, b:1};
ArrayReplicator.title = "Array Replicator";
ArrayReplicator.desc = "Array Replicator";
ArrayReplicator.prototype.onGetOutputs = function()
var list = [];
for ( var i = 0; i<this.labels.length; i++ )
var out = this.labels.charAt(i);
if ( !(out in this.internal)) { list.push([this.labels.charAt(i),"pointarray", {locked:true}]); break; }
return list;
ArrayReplicator.prototype.onOutputAdded = function(out)
this.internal[out.name] = 1;
for ( var i in this.outputs ) this.outputs[i].locked = true;
if (i>1) this.outputs[i].locked = false;
ArrayReplicator.prototype.onOutputRemoved = function(slot, name)
if ( this.internal[name] ) delete this.internal[name];
if ( this.outputs.length > 2 )this.outputs[i].locked = false;
ArrayReplicator.prototype.onAdded = function()
for ( var i = 0; i<this.labels.length; i++ ) if ( this.internal[this.labels.charAt(i)] && this.outputs.length == i ) this.addOutput(this.labels.charAt(i), "pointarray");
this.setDirtyCanvas(true);
ArrayReplicator.prototype.onExecute = function()
for ( var i = 0; i<this.outputs.length; i++)
this.setOutputData(i, source);
LiteGraph.registerNodeType("Arrays/ArrayReplicator", ArrayReplicator);
