Show messages: 1-18 … 239-258 259-278 279-298 299-318 319-338 339-358 359-378 … 899-912
// Circles
function Circles()
this.addInput("Center","pointarray");
this.addInput("Radius","number");
this.addInput("Elements","number");
this.addInput("Step","number");
this.addOutput("Out","objectlist");
this.properties = { radius:1, elements:1, step:1 };
Circles.title = "Circles";
Circles.desc = "Circles";
Circles.prototype.onExecute = function()
var output = moi.geometryDatabase.createObjectList();
var centers = this.getInputData(0, new pointArray());
var len = centers.getLength();
this.properties.radius = this.getInputData(1, this.properties.radius);
this.properties.elements = this.getInputData(2, this.properties.elements);
if (this.properties.elements <= 0) this.properties.elements = 1;
this.properties.step = this.getInputData(3, this.properties.step);
if (this.properties.step <= 0) this.properties.step = 1;
if (this.properties.step > len) this.properties.step = len;
for (i = 0; i < len && i < this.properties.elements; i += this.properties.step) {
var cir = factory( 'circle', true, centers.getFrame(i), null, this.properties.radius );
output.addObject(cir.item(0));
this.setOutputData(0, output);
LiteGraph.registerNodeType("Curves/Circles", Circles);
function GetBBoxes()
this.addInput("In","objectlist");
this.addOutput("BBox Center","pointarray");
this.properties = { elements:0, step:1 };
GetBBoxes.title = "BoundingBoxes";
GetBBoxes.desc = "Get BoundingBoxes";
GetBBoxes.prototype.onExecute = function()
var input = this.getInputData(0, moi.geometryDatabase.createObjectList());
var len = input.length;
var bbox = new pointArray();
this.properties.elements = this.getInputData(1, this.properties.elements);
if ((this.properties.elements <= 0) || (this.properties.elements > len)) this.properties.elements = len;
this.properties.step = this.getInputData(2, this.properties.step);
this.setOutputData(0, input);
bbox.pushPoint(input.item(i).getBoundingBox().center);
this.setOutputData(1, bbox);
LiteGraph.registerNodeType("Objects/GetBBoxes", GetBBoxes);
BBoxes.nod
Circles.nod
function PtArrayConcat()
this.labels = "abcdef";
this.size = [60,20];
this.internal = {a:1, b:1};
this.addOutput("Out", "pointarray");
// Cones
function Cones()
this.addInput("Height","number");
this.properties = { radius:1, height:1, elements:1, step:1 };
Cones.title = "Cones";
Cones.desc = "Cones";
Cones.prototype.onExecute = function()
this.properties.height = this.getInputData(2, this.properties.height);
this.properties.elements = this.getInputData(3, this.properties.elements);
this.properties.step = this.getInputData(4, this.properties.step);
var frame = centers.getFrame(i);
var cone = factory('cone', true, frame, null, this.properties.radius, frame.evaluate(0,0,this.properties.height));
output.addObject(cone.item(0));
LiteGraph.registerNodeType("Solids/Cones", Cones);
// Cylinders
function Cylinders()
Cylinders.title = "Cylinders";
Cylinders.desc = "Cylinders";
Cylinders.prototype.onExecute = function()
var cylF = moi.command.createFactory( 'cylinder' );
cylF.setInput(0, true);
cylF.setInput(1, frame);
cylF.setInput(3, this.properties.radius);
cylF.setInput(4, frame.evaluate(0,0,this.properties.height));
var cyl = cylF.calculate();
output.addObject(cyl.item(0));
cylF.cancel();
LiteGraph.registerNodeType("Solids/Cylinders", Cylinders);
// Spheres
function Spheres()
// this.size = [60,20];
Spheres.title = "Spheres";
Spheres.desc = "Spheres";
Spheres.prototype.onExecute = function()
var sphF = moi.command.createFactory( 'sphere' );
sphF.setInput(0, true);
sphF.setInput(1, frame);
sphF.setInput(3, this.properties.radius);
var sph = sphF.calculate();
output.addObject(sph.item(0));
sphF.cancel();
LiteGraph.registerNodeType("Solids/Spheres", Spheres);
CylsAndCones.nod
Message 7713.315 was deleted
// PatternSelectArray
function PatternSelArray()
this.addInput("In","pointarray");
this.addOutput("Out","pointarray");
this.addOutput("Elems","number");
this.properties = { pattern:"+-", elems:0 };
PatternSelArray.title = "PatternSelArray";
PatternSelArray.desc = "PatternSelArray";
PatternSelArray.prototype.onExecute = function()
var output = new pointArray();
var source = this.getInputData(0, new pointArray());
if (this.properties.pattern == '') this.properties.pattern = "+-";
var len = source.getLength();
var cn = 0;
for (i = 0; i < len ; i++) {
if ( this.properties.pattern[cn] === '1' || this.properties.pattern[cn] === '+') {
var source_elem = source.getElement(i);
output.push(source_elem.pt.x,
source_elem.pt.y,
source_elem.pt.z,
source_elem.AngleX,
source_elem.AngleY,
source_elem.AngleZ,
source_elem.Size);
cn = (cn < this.properties.pattern.length-1) ? cn+1 : 0;
this.properties.elems = output.getLength();
this.setOutputData(1, output.getLength());
LiteGraph.registerNodeType("Arrays/PatternSelArray", PatternSelArray);
pointArray.prototype.getElement = function(n)
var shift = n*this.recordLength;
var element = {"pt":this.getPoint(n),
"AngleX":this.data[shift+3],
"AngleY":this.data[shift+4],
"AngleZ":this.data[shift+5],
"Size":this.data[shift+6]};
return element;
PatternSelArray.nod
Message 7713.318 was deleted
