198-217
218-237
238-257
258-277
278-297
298-317
318-337
898-912
http://www.wordreference.com/fren/stop ;)
Look at the second line of the second column !
And don't forget that I am also French from my first day of birth! :)
And that we also have the small words possible for the UI!
Hi Max,
Suggested spelling changes:
Under Add Node, Construct:
Differrence should be spelled Difference.
Substractors should be spelled Subtracters.
Intersectors should be spelled Intersecters.
(The ors endings do sound kind of mathematical.)
Clear (the Output) is more correct than Clean (the Output), in my opinion.
Hi Pilou
Thank you for all of your hard work.
It would be impossible for myself to do it.
3 very minor observations:
OutPuts should be Outputs, (in my opinion), and would be a duplicate entry.
Center has a duplicate entry.
Loft has a duplicate entry.
I've entered the English words into Excel, and sorted.
Hello Max,
I have tested the pushFrame function. Unfortunately the function gives confusing results and crashes in particular situations. After a look in the code I saw one thing that causes definitely a problem:
>>>> ry = -Math.asin(frame.zaxis.x);
The results range is limited:-( As mentioned by you, it's a hard peace of cake;-)
Have a nice day
and let fly @'y'@
Karsten
I've found Microsofts Terminology Search to be rather helpful for UI translations.
https://www.microsoft.com/Language/en-US/Search.aspx
...shows you somewhat standardized terms used in various (localized) Microsoft products.
bemfarmer
Thank you! I'll fix it. :)
Karsten
Which parameters could cause a crash?
What's wrong with this line? The frame.zaxis.x value is always in [-1...1]
@Bemfarmer : Thx for the remarks and files' help!
I must update following each Max's versions (and some variable words) so possible to have some little differences.
I must also adapt with the actual French version of the Moi prog itself and Max Elephant.
Scale... was yet made on my site!
http://moiscript.weebly.com/elephant-systegraveme-nodal.html ;)
About the dupplication words you right but as it's any consequence on the result I will erase them at the end.
It's because the list of Max is very short and I take on the fly words using the nodes on the screen! ;)
And sure for excellence i should use some sort's actions like your Excel method ...
About some words like "Widget" there is no satisfactory French translation! :)
A suivre...
Hello Max,
Yes, thats correct, but if frame.zaxis turns over ry>90deg (z-axis downwards) you will get the same result as between 0-90deg. Another problem:
>>> rx = Math.atan2(frame.zaxis.y, frame.zaxis.z); If frame.z-axis lying on or parallel x-axis -> frame.zaxis.y=0 && frame.zaxis.z=0 -> atan2 will get a bitch ... (NaN) If you catch the situation - you have to check also the orientation:-(
I hate Euler angles now, but I'm to stupid to understand Quaternions in that way, that I can solve the problem with it:-(
Have a nice day
Karsten
p.s: The second described situation is our good old gimbal lock ...
Pilou, Brian
I think it's not a good idea to put all words in one sorted list.
It would be better if we make five separate list (as in the russian translation):
1. Main window interface (Save, Load etc )
2. Context menu (Add Node, Colors, Clone, Red, Green ... )
3. Node class names (Arrays, Curves, Solids ..)
4. Node names ( Const, Loft, Extrude, Revolve ... )
5. Inputs/outputs ( Min, Max, Count ... )
Karsten
Yes. I forgot about this. The new version:
var rx=ry=rz=0;
if ( frame.zaxis.y === 0 && frame.zaxis.z === 0) { ry = ( frame.xaxis.z > 0 )?90:-90; }
else
rz = Math.atan2(frame.xaxis.z*Math.sin(rx)-frame.xaxis.y*Math.cos(rx), frame.xaxis.x*Math.cos(ry)+(frame.xaxis.y*Math.sin(rx)+frame.xaxis.z*Math.cos(rx))*Math.sin(ry));
It's not a problem. For any frame we can get at least 2 sets of angles. It doesn't matter which one we choose.
Hello Max,
thanks for the fast reply. I can't check the code at the moment, maybe in the evening.
Ok, I agree with you. My calculation strategy differs from yours a little bit so I was blind to see:-)
Karsten
@Max
<< I think it's not a good idea to put all words in one sorted list.
You right!
Next version will be like than Russian's distribution!
(an external sort list will be used only for search dupplications :)
Hi Max and Karsten,
First of all, i wish to thank you for your efforts and for your constant developing!
Inside the NodeEditor, it would be possible to render the generated objects, using a particular style, just in order to better highlight them ?
The attached pictures show the actual Grasshopper's way...
And it would be possible to automatically select the generated objects, and eventually, assigning them to a particular style ?
Thanks for everything and have a nice day!
Marco.
Hello Max,
I figured out why my code is so complicated. I ran allways in situations where I got confusing results or crashes in following nodes. I've tried to solve the problem at the wrong place (the code is now independent of the frame axes length). In a first test I saw that Math.asin in your code gives a NaN in some configurations??? Normally it is impossible, especially when frame.zaxis.x=1. Maybe a bug or a problem with floatingpoint arithmetics??? I don't know???
Karsten
The <Language>Strings.txt in MoI are grouped.
They also have comments and subtitles preceded by semicolons.
Hello Max,
Damned! A simple "Math.round(frame.zaxis.x *10000)/10000" will fix it.
Have a nice day
Karsten
Hi Max and Karsten,
Marco.
You can yet put a color to a node
Right Click on a node!
Hello Max,
let me make a last remark about the pushFrame before you release it. Your code works fine and I can't figure out any problems:-)
(little changes: clamp frame.zaxis.x to [-1;1] | ?90:-90; -> Math.PI/4;-Math.PI/4)
The function sets in gimbal lock ry to ?90:-90. Am I right, that we need in that situation at least a rx- or rz-calculation?
Something like (not tested):
rz = Math.atan2(frame.yaxis.z,frame.yaxis.y); or a direction dependent rz=Math.asin(frame.xaxis.y)??? with rx=0
As mentioned, in tests I didn't run in that situation:-)
Have a nice day
Karsten
Have you a graphic example of the use of the function "PushFrame" ?
198-217
218-237
238-257
258-277
278-297
298-317
318-337
898-912
