185-204
205-224
225-244
245-264
265-284
285-304
305-324
905-912
v.0.55 (it may be buggy)
- Changed translation engine
- Added timer features (double click on background to show node timers)
- Added Line node
- Added TextArray node.
Each line => point: [x] [y] [z] [xAngle] [yAngle] [zAngle]. Use space or ; as separator.
Example:
1 2
5 6
10 15
or
1 0 0 0 -90 180
-1 0 0 0 90 0
0 1 0 90 0 90
0 -1 0 -90 0 -90
0 0 1 0 0 0
0 0 -1 0 180 0
Hello Max,
thank you for that great work. - your speed is incredible.
As mentioned, I am working on a pushFrame-function. Here is my first working code with some reworked nodes to test it. Please let me know if you want to improve and integrate it, or we should use an external way.
In a short test I can't run the circle-node?
By the way I made another cursor. The original crosshair has in my opinion not enough contrast. It is a simple PNG which can changed with a simple graphic prog. Activation for those who also need more contrast: open litegraph.css in the css directory and change cursor: crosshair; to cursor: url(./crosscursor.png) 16 16, crosshair; put the crosscursor.png in the same directory.
Have a nice day
Karsten
infonodes.js
infotest.3dm
infotest.nod
litegraph.js
As of version _NodeEditor0.55.2016.5.06, the language used by NodeEditor is the same as used in the users MoI program,
and is determined by the moi.ini file.
For example, to change from say English to another supported language, say French:
From the MoI screen, select Options, edit moi.ini, then under [UI],
change Language=English to Language=French. (Or Russian)
Currently supported by NodeEditor are Russian, English, and French thanks to Pilou.
(Except for "Clean" :-)
hmm, Russian works in NodeEditor, but does not work in my MoI, because I do not have RussianStrings.txt in MoI ui directory
A google search for "RussianStrings.txt MoI" located a download of the txt file, but I cannot read or understand Russian.
Cool!
Karsten
Thank you very much. I'll check all your code today.
My fault. Fixed.
curves.js, line 59
var output = factory( 'circle', true, center.getFrame(0), null, this.properties.radius );
It's looks good for me, but I'll add this line to css
bemfarmer
Could you explain, what's wrong with it? My english is far from good. Should I use "Clear" instead?
It's Resolved!
PS I have not a,b inside the MathArray as shown on the "Line Video" above ?
No Multiple Clone ?
Edit : about the a,b :):): You can add them by Right Click on the Node MathArray then "Inputs" !
Last French Version! :)
By Max S
There are a lot of words to translate.
Stop is not translated.
- B
<< There are a lot of words to translate.
like what ?
<< Stop is not translated
No need it's the same! ;)
Don't work ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/glitch01.nod
Edit: works! I don't must start from a & b but from others! :)
How made that ?
From left to right
v0.6
added Jitter,Rotate,MoveArray nodes
added pushFrame function
added custom mouse cursor support (put cursor.png to /core/imgs directory)
Crazzy speed of production!
French Version :)
https://answers.yahoo.com/question/index?qid=20130909122044AAx7iew
http://www.wordhippo.com/what-is/the/french-word-for-stop.html
I was contemplating doing Spanish (ES), but after looking at all the French words, it would have to be proof read by
someone who knows Spanish, to avoid errors. :-)
http://www.wordreference.com/fren/stop ;)
Look at the second line of the second column !
And don't forget that I am also French from my first day of birth! :)
And that we also have the small words possible for the UI!
Hi Max,
Suggested spelling changes:
Under Add Node, Construct:
Differrence should be spelled Difference.
Substractors should be spelled Subtracters.
Intersectors should be spelled Intersecters.
(The ors endings do sound kind of mathematical.)
Clear (the Output) is more correct than Clean (the Output), in my opinion.
Hi Pilou
Thank you for all of your hard work.
It would be impossible for myself to do it.
3 very minor observations:
OutPuts should be Outputs, (in my opinion), and would be a duplicate entry.
Center has a duplicate entry.
Loft has a duplicate entry.
I've entered the English words into Excel, and sorted.
Hello Max,
I have tested the pushFrame function. Unfortunately the function gives confusing results and crashes in particular situations. After a look in the code I saw one thing that causes definitely a problem:
>>>> ry = -Math.asin(frame.zaxis.x);
The results range is limited:-( As mentioned by you, it's a hard peace of cake;-)
Have a nice day
and let fly @'y'@
Karsten
I've found Microsofts Terminology Search to be rather helpful for UI translations.
https://www.microsoft.com/Language/en-US/Search.aspx
...shows you somewhat standardized terms used in various (localized) Microsoft products.
bemfarmer
Thank you! I'll fix it. :)
Karsten
Which parameters could cause a crash?
What's wrong with this line? The frame.zaxis.x value is always in [-1...1]
@Bemfarmer : Thx for the remarks and files' help!
I must update following each Max's versions (and some variable words) so possible to have some little differences.
I must also adapt with the actual French version of the Moi prog itself and Max Elephant.
Scale... was yet made on my site!
http://moiscript.weebly.com/elephant-systegraveme-nodal.html ;)
About the dupplication words you right but as it's any consequence on the result I will erase them at the end.
It's because the list of Max is very short and I take on the fly words using the nodes on the screen! ;)
And sure for excellence i should use some sort's actions like your Excel method ...
About some words like "Widget" there is no satisfactory French translation! :)
A suivre...
185-204
205-224
225-244
245-264
265-284
285-304
305-324
905-912
