Full Version: Parametric design in MoI?
Show messages:  1-3  …  164-183  184-203  204-223  224-243  244-263  264-283  284-303  …  904-912
4 May 2016   [#224] In reply to [#223]
Shortcut key also works:
My shortcut key for nodeeditor:
Ctrl+Alt+N moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
Also made a copy of index.html named indexFR.html, with FR instead of EN the only change, also placed in nodeeditor subdirectory.
My new test shortcut key for French is:
Ctrl+Alt+Z moi.ui.createDialog( 'nodeeditor/indexFR.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
Hope some of this helps.
4 May 2016   [#225] In reply to [#224]
Thx for all precision!
But alas mystery is more more curious! :)
Bride between French version don't want to work for me!
All was working fine for the Elephant 1 !
4 May 2016   [#226] In reply to [#225]
I was able to re-create the failure of the French language to appear, by
using the WRONG lang.js file.
So I would say to triple check that the Pilou lang.js file (which includes French words :-)), is
contained in the \core subdirectory.
4 May 2016   [#227]
Today I wrote a Line node. It's not so simple as it looks :)
4 May 2016   [#228] In reply to [#227]
We are all aware of you're herculean efforts.
Be assured they do not go unappreciated.
Keep it up
- James
4 May 2016   [#229]
Seems solved but very curious!
I must add the French lines dictionnary inside the EN part !
Moi is in French
My index html is lang.set("FR");
My lang.js is var lang = { LANGUAGE: "FR" }
Does all that is normal ???
image of the lang.js
4 May 2016   [#230] In reply to [#229]
"My index html is lang.set("FR");" <<This is correct.>>
"My lang.js is var lang = { LANGUAGE: "FR" } " <<<This is "incorrect." Leave it as: var lang = { LANGUAGE: "EN" }>>>
I temporarily went to MoI Options, and edited the moi.ini file to read, under [UI] as Language=French
With index html: lang.set("FR");, and leaving your lang.js as downloaded, with var lang = { LANGUAGE: "EN" }
no other modifications were needed to get French Node language.
There is no need to add the French words to the EN section, lines 159+ in your post.
(These are my personal observations and tests and opinions:-)
5 May 2016   [#231]
Hi Pilou
Check all js files for another lang.set('EN') call. It seems like you accidentally inserted this line somewhere in the code.
5 May 2016   [#232] In reply to [#231]
<< Check all js files for another lang.set('EN') call
I have checked that: no such thing is existing! :)
5 May 2016   [#233] In reply to [#232]
Pilou, could you send all nodeedit files to me?
5 May 2016   [#234] In reply to [#233]
@Max: Sure!
Here the complete folder nodeeditor who is working! (so with 2 "French dictionnaries" as shown on my image above inside the file lang.js)
http://we.tl/TwsT35rm6z till 12 may 2016
Of course all translations of nodes and other things are not yet made! (All is in Wip building)
but with this yet made and this curious lang.js all works fine in French!
5 May 2016   [#235]
One more node added - TextArray
It converts text data to pointarray. For each point can be set upto six values: x, y, z, x-rotation angle, y-rotation angle, z-rotation angle.
5 May 2016   [#236] In reply to [#234]
I just changed language to FR and deleted all translations in EN. Everything works great.
Try this.
5 May 2016   [#237] In reply to [#236]
@Max
This last one with your file works fine!
Why when it's me that was making the same don't working stay a mystery!
I will now continue the translation more serenely! :)
Seems your new functions will delight lovers of Parametric forms!
5 May 2016   [#238]
Actuals nodes! All works fine except this!
Translation of "Clean" don't work! Where is it?
5 May 2016   [#239] In reply to [#238]
basic.js has "Clean" on line 297.
Test change to Cleeen confirms:-)
nettoyer?
6 May 2016   [#240]
French version of 0.5
6 May 2016   [#241] In reply to [#240]
Thank you for this French package. But I would like to give you a couple of advices for a future releases.
- I found few backup files and obsolete nodes in your package. It will be better if you will use my latest packages as is. Just add translation to lang.js. The next version will switch language automatically depending of the interface settings. So no need to change lang.set parameters.
- Don't translate strings like Basic/Constant, Factories/Circular Array etc. It's a waste of time, because it is just a debug info, which shouldn't be translated. I'll remove it in the future.
P.S. I'll fix that "Clean" bug in the next beta release. Don't fix it directly by changing the word in .js file.
6 May 2016   [#242]
Just made a significant changes in translation engine to stop that translation hell. Now all labels and node titles are stored in .nod files with english names (with the exception of manually renamed nodes). The script will make all translations on the fly.
Waiting for a bug reports :)
6 May 2016   [#243] In reply to [#241]
<< I found few backup files and obsolete nodes in your package.
Normal : I increase the dictionnary with the new names without erasing old ones (difficult to see what are they)! :)
<< - Don't translate strings like Basic/Constant ... I'll remove it in the future.
Cool to know!
