20-39
40-59
60-79
80-99
900-912
In fact I didn't spend a lot of time writing it. I decided to finish the main core script, and then share it with community.
I still do not have plans to write the whole node-system for MoI.
Max,
I think there is a real business opportunity here.
I for one, would be prepared to pay for a node-based parametric add-on for Moi3d.
This project is very close to alpha release :)
In the last build I added Save/Load functions, node info/edit panel, slider node.
VIDEO
Seems terrific! Pleasure of the coding! ;)
Any functions valuable ?
Hi Max,
I am deeply impressed! Hats off to You!
With respect and Kind regards
Karsten
Unbelievable, this is realy great. Bringing MoI closer to tools like Houdini etc.
Great work Max
hello ,
it is possible integrate appleseed or similar?
http://appleseedhq.net/features.html
http://appleseedhq.net/gallery.html#http%3A%2F%2Fappleseedhq.net%2Fimg%2Fscreenshots%2Fgafferseed.jpg
Preview 3
VIDEO
James,
Maybe.. Anyway this script will be free for every MoI user.
Frenchy Pilou
Sorry, I don't understand you question.
guyver
Everything is possible. But I have no plans about it. ;)
Vojtisek, Karsten, Frenchy Pilou, James thank you! :)
Very neat!
@ Max
Just if all functions of the Moi UI will be present on the nodes system! ;)
Another thing : your nodes will be easily accessible for translation ?
Like this for example
It's looking really cool Max, I think a lot of people will be interested in it!
It's looking cool indeed, time to parametrize some stairs!
Thanks Max,
Max.
Frenchy Pilou
Not every function can be implemented.
At the moment this program doesn't support translations at all. The engine uses names of variables as labels. So, you can't just rename labels.
I'll make multilanguage support later. But now it will be English only.
Good news :) Today evening will be first public release of this node-editor.
Btw, could somebody help me with documentation? As you can see, my english is far from perfect, so I'll waste a lot of time if I do it myself.
I definetely need help :)
Suspense! ;)
v0.2 alpha (tech demo)
Extract .zip archive to /ui/ directory:
\ui\nodeeditor\index.html
\ui\nodeeditor\core\imgs
\ui\nodeeditor\core\litegraph-editor.js
\ui\nodeeditor\core\litegraph.js
\ui\nodeeditor\core\imgs\*
\ui\nodeeditor\css\litegraph-editor.css
\ui\nodeeditor\css\litegraph.css
\ui\nodeeditor\css\style.css
\ui\nodeeditor\nodes\basic.js
\ui\nodeeditor\nodes\factories.js
\ui\nodeeditor\nodes\interface.js
\ui\nodeeditor\nodes\objects.js
use this command to run the script:
moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
You can run this script using CustomUI addon. Put attached "99 NodeEdit.htm" file to /ui/customui/ directory and restart MoI.
It works, I like the interface also.
Of course the more functions available, the better it gets.
Thank you
Custom UI :
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
Works fine! Very neat! And very smart when you have 2 screens! Bravo!
French Version of the Install! ;)
The tricky thing is (re) install the Custom UI if not existing! ;)
No Erase All or New?
No Undo ? (When create some nodes)
A very minor default : little flickering when we resize the window ;)
Seems translation possible with some attention to the code! :)
Access to the nodes
Here the Nodes accessible : Maybe I have forgotten something ?
Properties of the nodes
Hi Max,
I'll try to help with documentation.
@Max
In this portion I must translate only red lines : more, less? I am not sure for the "objectlist"...
Generally all words between 2 "" ?
20-39
40-59
60-79
80-99
900-912
