Hallo Barry,
Thank you for your investigations. The problem is that I check the input of x(n) and generate not an default array for that. So if you put an array with the same number of values, with start value 0 and step 0, it should work (all ports connected to avoid side effects). I am waiting till next alpha of the @'y'@ to find a better solution, because Max has announced big changes in value handling - maybe he will integrate some better solutions by himselve? I'm very curious:-)
I want to share my last investigations of subD for the elephant. I have simple wrapped Max SubD-Script in a node. Sorry about the videoformat. It's my first screenrecording and I have some problems with the upload.
I have not deleted the other video. YT has deleted it, caused by a 95% problem. So I made a new one and converted it before upload - but I'm to stupid to get a correct aspect ratio:-). Maybe some day I will find the time for better results.
Hi Max
Is it possible to have a node that outputs the X,Y & Z box dimensions of a selected object.
Unfortunately I don't have the ability to write it myself.
Barry
Any chance of an update on Project Elephant progress.
I have been checking the forum incessantly since your last posting:
"New alpha/beta vesions will be soon :)"
Please don't mistake my enthusiasm for impatience.
Hi Max: First of all big thanks for your great support !!!
In the context of MoI and scripting I am wondering if it would be possible to integrate functions
for minimal surfaces, some kind of relaxation of meshes as it is the case with 'RhinoMembrane'
in order to create surfaces in analogy to soap films: equal tension in all directions. ???
Here are some examples for that specific form findig process of anticlastic surfaces:
