Full Version: Parametric design in MoI?
Show messages:  1-8  …  89-108  109-128  129-148  149-168  169-188  189-208  209-228  …  909-912
30 Dec 2015   [#149]
Tracks & nodes draw a gun! ;)
30 Dec 2015   [#150] In reply to [#148]
Hi Barry,
I'm not an expert, so I can't decide if this is a proper way, but I think everything works fine. I'm playing with the @'Y'@ like some others, too. Remarked by chipp, the system is not easy to use at the moment, but playing with it, will help to find better solutions.(like your comments:-))
Max announced some changes in the core system that will help reduce wiring, but maybe some nodes have to be changed, alot will be obsolete. I'm not a programmer and time is limited, so I will have a look to a reset function or some better defaults, with the next version of max core system.
Keep on playing:-)
Have a nice day
Karsten
30 Dec 2015   [#151] In reply to [#150]
Hi ,
being a beginner I'm posting this file hoping for some feed back on where I could
improve it or make it easier.
The attached node file as two arrays combined to allow nesting of objects.
In the picture the red and silver objects are the same. This was an exercise to maximise
a mould layout for a given shape with the ability to rotate and adjust and offset centres.
Barry
Nesting.nod
Message 7713.152 was deleted
Message 7713.153 was deleted
31 Dec 2015   [#154] In reply to [#153]
Hello Barry, Hello James,
It should be a bug if it isn't work. I will have a look tomorrow.
Very interesting to see the different application areas and different point of view to the same thing.
Sorry, if there are bugs in the nodes.
Happy new year to all
Karsten
1 Jan 2016   [#155] In reply to [#154]
Hi James & Karsten,
I'm not sure if this may help but I replicated James problem and found you could
produce the sine wave in the X & Y or Y & X also X & Z but not Y & Z.
Happy new year
Barry.
1 Jan 2016   [#156] In reply to [#155]
Hallo Barry,
Thank you for your investigations. The problem is that I check the input of x(n) and generate not an default array for that. So if you put an array with the same number of values, with start value 0 and step 0, it should work (all ports connected to avoid side effects). I am waiting till next alpha of the @'y'@ to find a better solution, because Max has announced big changes in value handling - maybe he will integrate some better solutions by himselve? I'm very curious:-)
Kind regards
Karsten
2 Jan 2016   [#157]
@ = Ear
' = Eye
Tusks missing
y = Trunk and Jaw?
http://pc.net/emoticons/smiley/elephant
12 Jan 2016   [#158]
Hi everybody! :)
I'm back from vacations. New alpha/beta vesions will be soon :)
12 Jan 2016   [#159] In reply to [#158]
Happy new year MAX!
Made with the incredible free Verve: we can now embed an image inside bristles Brush!
http://www.taron.de/forum/viewforum.php?f=4
12 Jan 2016   [#160] In reply to [#158]
Hello Max,
Happy new year! I am very excited about the changes you have made:-) and I hope, I will understand them!
Kind regards
Karsten
15 Jan 2016   [#161] In reply to [#160]
Hello,
I want to share my last investigations of subD for the elephant. I have simple wrapped Max SubD-Script in a node. Sorry about the videoformat. It's my first screenrecording and I have some problems with the upload.
Kind regards
Karsten
15 Jan 2016   [#162] In reply to [#161]
You will not erase this one ? ;)
15 Jan 2016   [#163] In reply to [#162]
Hello Pilou,
I have not deleted the other video. YT has deleted it, caused by a 95% problem. So I made a new one and converted it before upload - but I'm to stupid to get a correct aspect ratio:-). Maybe some day I will find the time for better results.
Have a nice day
Karsten
15 Jan 2016   [#164] In reply to [#163]
No problem! :)
18 Jan 2016   [#165]
Hi Max
Is it possible to have a node that outputs the X,Y & Z box dimensions of a selected object.
Unfortunately I don't have the ability to write it myself.
Barry
4 Feb 2016   [#166] In reply to [#158]
Max
Any chance of an update on Project Elephant progress.
I have been checking the forum incessantly since your last posting:
"New alpha/beta vesions will be soon :)"
Please don't mistake my enthusiasm for impatience.
- James
5 Feb 2016   [#167] In reply to [#166]
Hi James
Yes, I will continue development of this project in the nearest future. But now I have no free time at all.
I'm sorry for the delay.
17 Apr 2016   [#168]
