 43-62
 63-82
 83-102
 103-122
 123-142
 143-162
 163-182
 903-912
@Karsten
Thanks : useful for training of translation! ;)
But seems I need more infos about install the the ICurve...because there is yet a nodes/factories.js inside the the index.html ! ;)
And some others don't yet appear! (Sin, Cos, 1..n, Generativ Array :)
PS International language is not coding! ;)
It's like that for example for French (here only 2 lines but there a little more :)
FR:	{
"Circle" : "Cercle",
"Z axis" : "Axe Z"
sorry for the late reply. You have to replace the original factories.js with the version from Brians post. In the index.html you have to add the two lines. Then it should work. For study look at the attached file. Please make copies of your originals:-)
Kind regards
Karsten
 index.html
index.html
@Karsten
Bingo! And in French! :)
It's a little chaotic as process! :)
You right I will wait some times before all was on the road for make the reposity! :)
When I see that I am a little affraid! :)
http://modelab.is/grasshopper-primer/
So for the effort try CTRL+SHIFT+CLICK on the Options' Button inside Moi UI ! (bottom middle right screen)
This is an inelegant solution to achieve this result,
but its my first scratch in the surface of possibilities.
Thanks to Max.... & Brian & Karsten
Post your file .nod that can help some one! ;)
Message 7713.108 was deleted
Hello James,
I think you can't make it better with this basic nodes. I tried to make something flexible - on the other side it is difficult to handle and confused to work with it. I think we need some more specialized nodes in the future for particular things. Nevertheless, it seem you have fun and that's important! I have:-) in any case.
I think that the following approach can make things easier, but it's buggy, crashes the script-engine, and can't store the reference to the selected object. I don't know how to solve the problem, and I don't know if it is possible at all:-(
(my programming abilities are very limited)
Kind regards
Karsten
Karsten
Yes it is great fun.
I see in your animated gif that you have developed some more nodes: Revolve & PickedCurve
as well as a set of Logic nodes.
I would love to have a play with them. Can you please make them available.
Love your work
Hello James,
sure!
But there are a lot of bugs in some functions. If you want to use "pickedCurve", you have first select the Curve and then generate the node. Before you leave the nodeeditor, remove the node - otherwise the Editor crashes. I think the reference to Moi's database locks something!? Maybe Michael or Max should have a look on this sometimes, but I think they have something better to do presently.
Have a nice day
Karsten
p.s.: Be Aware everything I made is only a draft!
 nodeeditor_with_lot_of_bugs.zip
Karsten
Thank you for the files. Can you tell me what "pickedCurve" offers over & above "Selected" node?
Thanks again
Hello James,
sorry, I didn't get you. Could You give me some more Details?
Kind regards
Karsten
WTF!!!
Thank You for your note!!! Now I understand! It is already implemented! I have fail to see!
Now I can study how Max has solved the Problem:-)
Have a nice day
Karsten
Hi Karsten
I am unable to switch off caps on your "revolve" node.
I have tried inputting a false result from a logic operator
but caps remain. Is this a bug?
To better explain my issue I have attached screen shot and .nod file
By my reckoning the A>B operator should switch off caps on the hyperboloid.
It is a brilliant node regardless.
Hello James,
the function was not fully implemented. My problem is that I don't know, if this is the right way. Maybe it is possible to build in controlelements inside the nodes. Maybe it is a better way to make special nodes for different behaviors of the same base function. Nevertheless here is a file:-)
Kind regards
Karsten
 factories.js
factories.js
Thanks Karsten
That did the trick :)
Message 7713.119 was deleted
Flower power! ;) With the Astra above! :)
Seems format of number is not yet managed ?
Does a zoom is existing for Elephant ?
Message 7713.121 was deleted
>>  Has this been done parametrically?
No, that was some normal Circular Array after your Astra nodes result! :)
But of course you can as shown with your last post! ;)
And you can make some fractal "LinePoly" of "LinePoly" of "LinePoly" of .......... :)
LinePoly Works fine for me!
Now Make the same with a selected object! ;)
PS Zoom is not existing in the edit window of Elephant ?
And yes now the problem is the tumultuous new nodes functions to integrate in the core of Elephant! :)
(4 th generation of factories.js file! :)
PSS Better if you can put the entiere drawing image of the Nodes! ;)
Sorry here in French/English
 43-62
 63-82
 83-102
 103-122
 123-142
 143-162
 163-182
 903-912
