Full Version: Variable Width Line Offset Command - fatT Lines
Show messages:  1-9  10-29  30-49  50-51
28 Nov 2024   [#50] In reply to [#49]
hi pilou can you set the line widths to a specific width? e.g. 2mm or anything else a user may decide?
edit:
i presume that is setting the "larguer" slider shown in your earlier posts?
kindest...
28 Nov 2024   [#51] In reply to [#50]
Of course yes you can input any width !
Here 10 unities on 2 separated straigt lines
If you have several widths make several sets of lines (curves)
You will have a different result if you take connected lines! (here a polyline of 2 segments)
