Full Version: Dimension tool (as in sketchup)
Show messages:  1-13  …  34-53  54-73  74-93  94-113  114-133  134-138
18 Jul 2015   [#94]
Near perfection! ;)
18 Jul 2015   [#95]
French version ;)
http://moiscript.weebly.com/cotations.html
19 Jul 2015   [#96] In reply to [#93]
Hi Max
Just incredible !!!
There was MOI before and MOI after your development .
It's seems so simple with your job
Thanks .... and i mean , thanks from all users.
Christian
19 Jul 2015   [#97] In reply to [#93]
Hi Max
What do you think a bout this ...
like rectangle tool but with 2 erased lines ... then _dimensions command .
Chri
19 Jul 2015   [#98]
Hi Max,
Another amazing script, thanks! Very useful indeed!
I really like christian's suggestion above, especially if the rectangle would snap to specific distances, so you can neatly place all annotations at the same distance from your drawing.
Ideally, we'd be able to set the offset from the text relative to the line, as well as the offset of the 'overshoot' of helper lines - usually you'd have this, instead of placement at very the end of these lines.
Thanks again, kind regards,
Fabien
19 Jul 2015   [#99]
A wonderful script Max. I think Christian & Fabien have valid ideas.
22 Jul 2015   [#100]
I just created command that Show/Hide Dimensions. It toggles visibility of dimensions.
If all dimensions are hidden they will be shown else they will be hidden.
Command - Styles_ShowHideDimensions
Download it here:
http://bit.ly/1SCvfJP
Also in archive there is modified original dimension script.
It will unhide all Dimensions if they was hidden when you run command.
Max if you want you can keep this modification in future releases there is function at the end of _Dimensions.htm called ShowDimensions().
13 Sep 2015   [#101]
Does it possible to have something (or a trick) for have number of decimals wished?
Because edit the "round" function of the _Dimensions.htm manually is some painful ! ;)
Here you must change the "2" with number of decimals wished!
angle = round arc.angle, 2)
fixedDist:round(dist, 2);
fixedDist = round(R, 2);
13 Sep 2015   [#102] In reply to [#101]
A little study and learning shows:
Line 21 of the .htm file has the round function, which rounds the val number to p decimals.
The function is called from 3 locations, line 52, 152, and 156, where p = 2, or p=2, or for angles, p=1.
I inserted the hard code "p+=2;" in Line 21, which raises decimals to 4, or 4, or for angles, 3decimals.
Test modification of line 21 of .htm file: function round(val, p) { p+=2; return Math.round(val*Math.pow(10, p))/Math.pow(10,p) }
I believe another user input could be added, for the desired decimals. But should 3 different user inputs be added, including one for angles?
Maybe 3 default values would be needed too?
I am not going to mess with Max's superb code :-)
14 Sep 2015   [#103]
:) Ok, boss
14 Sep 2015   [#104] In reply to [#103]
>> :) Ok, boss
You rocks!
French Version : http://moiscript.weebly.com/cotations.html
PS Here 10...
Seems 14 is the Maximum possible! So suffucient I presume! :)
So maybe you can change the 4 in 14! (line 282) ;)
14 Sep 2015   [#105] In reply to [#104]
No-no-no. :)
In fact nobody uses more than 2 digits after decimal point.
14 Sep 2015   [#106] In reply to [#105]
@Max (imum)
You don't know perversity of some geometric's maniacs! :D
So my version will be customized with funny thing max="14" (line 282) :D
14 Sep 2015   [#107]
And for Type 4 & 5 with CTRL seems we must make this! (THX Chri)
if ( arrowType.value == 4 || arrowType.value == 5 ) { f = moi.VectorMath.createPoint (c.x+dx, c.y+dy, c.z+dz ); fixedDist = round(R, 2); }
by
if ( arrowType.value == 4 || arrowType.value == 5 ) { f = moi.VectorMath.createPoint (c.x+dx, c.y+dy, c.z+dz ); fixedDist = round(R, decimals.value); }
Ps I don't know if all that work for Imperial ? Never used, too complex for me! :(
14 Sep 2015   [#108] In reply to [#107]
Yes. Missed one Round call. Fixed and uploaded.
14 Sep 2015   [#109] In reply to [#106]
""""""""So my version will be customized with funny thing max="14" (line 282) """""""""""""""
Mine is set to "15" and outputs 15....
I also set my default at 4 and wrote in to default with "units" checked and also to have "in" as the trailer.......
14 Sep 2015   [#110] In reply to [#109]
you right 15 seems the ultime limit :)
12 Oct 2015   [#111] In reply to [#103]
wow. that script is phantastic. thanks a lot!
that really will save me a lot of time.
20 Dec 2015   [#112]
the script is not working for me. I got the script error. The language is Finnish.
21 Dec 2015   [#113] In reply to [#112]
Hi JL82,
From the error it looks like you are running MoI version 2, and I think the script requires MoI version 3 in order to run properly.
