3-22
23-42
43-62
63-82
83-102
103-122
123-138
Does it not possible to input a test inside the code for have only a Type 4 ?
Pseudo Code : When 180° > Arrow Angle > 360° reverse Position Text ...
it's question for MAX, I have no experiences with script writing unfortunately. I've only analysed Max's script and analogically added new arrow types.
I've only noticed that arrows are created as polylines in Cartesian coordinate system and then it makes surface from polyline.
Position of text is done by vector of direction probably when the arrow line is created (from left to right and vice versa).
BTW Type 5 is can be used for radius measurement as well. In "unit" text box it has to be paste " R| "
Mik
Great script, Max, very useful.
Max should get some sort of "USER OF THE DECADE" award for MoI. Great job!!!
Frenchy Pilou
Now it looks better :)
I am confident! :)
Seems cool!
French version
http://moiscript.weebly.com/cotations.html
Can the output be in curves instead of surfaces?
hello
formidable efficiency.
Well done guys and applause to Max !!!
Chri
;) v.0.9 wil be soon
What a teasing! :)
Very nice demo, Christian.
Version 0.9
Added circular mode.
In fact I made it for angles, but unfortunatelly I had no free time this weekend to write that.
To enter this mode hold the control button while selecting a first point.
In this mode a length of the arrow will be locked to a circle diameter (arrow type 1-3), or radius (arrow type 4-5).
Cool!
But there is a little glitch with this new Mode(with CTRL): when you make a second click on the first click!
All disapears for ever in the space dimension with also the figure! :)
Hmm, my script doesn't interact with any objects except of dimension lines. I looks like a MoI bug, caused by bug in my script (division by zero). Anyway it's my fault. I've already fixed it. I'll upload new version today evening.
Please, is it possible to get the output in curves instead of surfaces? I think it's more lightweight and it's possible to export them without using hidden line removal algorithm.
Max.
Hi Max, re: make curves instead of surfaces, open the file _Dimensions.htm in a text editor, and edit the line that creates the text factory. It's this one here:
var text = factory ('text', moi.VectorMath.createTopFrame(), tx, fontName, false, false, 'surfaces', textSize, 0, false);
Edit that to replace 'surfaces' with 'curves' and then it will make curve text rather than surface text.
<< it will make curve text rather than surface
And for the Arrows ?
I don't like this idea. If you need curves you can click Dimensions style, select all, select edges, ctrl+c, ctrl+v. It will take 3-4 seconds.
My script works correctly with surfaces only. If you change surfaces to curves, snapping will be enabled for all objects including anotations and dimension lines.
No problem! :)
it is better to turn outside the circle , explanation on the next POST :
il est préférable de tourner en dehors du cercle, explication dans le prochain POST:
Chri
3-22
23-42
43-62
63-82
83-102
103-122
123-138
