10-29
30-49
50-69
70-89
90-109
130-138
A well made script. Quite useful while we wait for a proper dimension element.
M.
Someone ask text before the dimension, also text in replacement of the dimension! (here text is after)
You can make that but...
Michael
>obj.setHitTest( false );
Yes! That's exactly what I needed. Thank you! :)
Mik
>it would be very useful to have two additional checkboxes (same as Unit) "prefix" and "suffix"
I've made some changes in the new version ;)
v0.6
Snapping disabled for dimension lines (now script works exacly as planned)
Added more hidden features:
Prefix can be setted by using split symbol | in the units field. Example: R|mm -> R 15.1 mm
Special for you. :) Add * in the beginning. Example: *3/4 de pieds d'alouette!
Max, brilliant!! Thanks again for the tweaks to the already awesome! script.
Cheers.
Hi Max,
it works perfectly.
Many thanks!
Mik
@Max
Excellent! Bravo!
French Version Updated!
http://moiscript.weebly.com/cotations.html
Michael,
Thank you for putting this on your V4 list. Probably not the most fun thing to work on but but man will it put a spin on MOI.
Terry
Great tool !
many thanks Max !
Message 7403.38 was deleted
Hi Max,
I allowed myself to add new arrow type 4, which can be useful for various description in drafts.
Kind regards,
Mik
Dimensions.v.0.7.2015.07.01.zip
Neat add!
French Version UpDated
This is so helpful. Thanks so much Max for your time.Theses scripts really help fill some missing features without changing the program.
...and twin of type 4 -> type 5 :-)
Dimensions.v.0.8.2015.07.01.zip
Does it not possible to input a test inside the code for have only a Type 4 ?
Pseudo Code : When 180° > Arrow Angle > 360° reverse Position Text ...
it's question for MAX, I have no experiences with script writing unfortunately. I've only analysed Max's script and analogically added new arrow types.
I've only noticed that arrows are created as polylines in Cartesian coordinate system and then it makes surface from polyline.
Position of text is done by vector of direction probably when the arrow line is created (from left to right and vice versa).
BTW Type 5 is can be used for radius measurement as well. In "unit" text box it has to be paste " R| "
Mik
Great script, Max, very useful.
Max should get some sort of "USER OF THE DECADE" award for MoI. Great job!!!
Frenchy Pilou
Now it looks better :)
I am confident! :)
Seems cool!
French version
Can the output be in curves instead of surfaces?
10-29
30-49
50-69
70-89
90-109
130-138
