Full Version: Dimension tool (as in sketchup)
Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  …  126-138
29 Jun 2015   [#26]
French version Updated! :)
http://moiscript.weebly.com/cotations.html
Alt + 0216 = Ø ;)
When I draw something on a surface in the 3D view
dimension Text, arraws are not parallal to this surface!
I must draw inside the View Face!
29 Jun 2015   [#27] In reply to [#25]
Hi Max,
> Could you help me? I have problem with pointpicker snapping. Is there a way to exclude
> all objects with "Dimensions" style from the object snapping list?
You can do that by making a pass through those objects before using the pointpicker, and turn off the "hit test" flag on each of those objects using: obj.setHitTest( false );
If an object is set with the "no hit test" flag, it should cause the pointpicker to skip over it and not target any snaps on it, and also it won't be targeted for selection either. Then if you want it to behave normally later on afterwards you'll need to set obj.setHitTest( true ); on those same objects to reset it.
If you do not have the objects already separated out somehow, you can find the style index of the "Dimensions" style by using:
var style = moi.geometryDatabase.findStyle( 'Dimensions', false /*CreateIfNotFound*/ );
if ( style )
    var index = style.index;
     // Now look for objects that have obj.styleIndex == index
Hope that does what you need!
29 Jun 2015   [#28] In reply to [#22]
Thank you Frenchy ..
eric
29 Jun 2015   [#29]
Hi Max,
arrow type is nice feature.
...as Frenchy imply, it would be very useful to have two additional checkboxes (same as Unit) "prefix" and "suffix" with text field for pasting symbols or additional text in front and behind of dimensions.
... and Arc drawing with angle value would be absolutely fantastic :-)
Excellent job, thank you.
Mik
30 Jun 2015   [#30]
A well made script. Quite useful while we wait for a proper dimension element.
M.
30 Jun 2015   [#31]
Someone ask text before the dimension, also text in replacement of the dimension! (here text is after)
You can make that but...
30 Jun 2015   [#32]
Michael
Yes! That's exactly what I needed. Thank you! :)
Mik
I've made some changes in the new version ;)
v0.6
Snapping disabled for dimension lines (now script works exacly as planned)
Added more hidden features:
Prefix can be setted by using split symbol | in the units field. Example: R|mm -> R 15.1 mm
Special for you. :) Add * in the beginning. Example: *3/4 de pieds d'alouette!
30 Jun 2015   [#33] In reply to [#32]
Max, brilliant!! Thanks again for the tweaks to the already awesome! script.
Cheers.
30 Jun 2015   [#34]
Hi Max,
it works perfectly.
Many thanks!
Mik
30 Jun 2015   [#35]
@Max
Excellent! Bravo!
French Version Updated! http://moiscript.weebly.com/cotations.html
30 Jun 2015   [#36] In reply to [#3]
Michael,
Thank you for putting this on your V4 list. Probably not the most fun thing to work on but but man will it put a spin on MOI.
Terry
1 Jul 2015   [#37]
Great tool !
many thanks Max !
Message 7403.38 was deleted
1 Jul 2015   [#39]
Hi Max,
I allowed myself to add new arrow type 4, which can be useful for various description in drafts.
Kind regards,
Mik
Dimensions.v.0.7.2015.07.01.zip
1 Jul 2015   [#40] In reply to [#39]
Neat add!
French Version UpDated http://moiscript.weebly.com/cotations.html
1 Jul 2015   [#41]
This is so helpful. Thanks so much Max for your time.Theses scripts really help fill some missing features without changing the program.
1 Jul 2015   [#42]
...and twin of type 4 -> type 5 :-)
Dimensions.v.0.8.2015.07.01.zip
1 Jul 2015   [#43] In reply to [#42]
Does it not possible to input a test inside the code for have only a Type 4 ?
Pseudo Code : When 180° > Arrow Angle > 360° reverse Position Text ...
1 Jul 2015   [#44]
it's question for MAX, I have no experiences with script writing unfortunately. I've only analysed Max's script and analogically added new arrow types.
I've only noticed that arrows are created as polylines in Cartesian coordinate system and then it makes surface from polyline.
Position of text is done by vector of direction probably when the arrow line is created (from left to right and vice versa).
BTW Type 5 is can be used for radius measurement as well. In "unit" text box it has to be paste " R| "
Mik
2 Jul 2015   [#45]
Great script, Max, very useful.
