69-88
89-108
109-128
129-138
Hi Michael - as always thanks for your prompt and helpful reply ;-) ... I will look out for what happens with the v4 as it progresses ... Have a good weekend when you get to that ... Jesper
HI
I also have a problem when :
1 - i call this fonction (TypeError...)
2 - i select an objet and call this fonction (Invalid index ...)
3 - i would like th draw a dimension ( tab is empty , color line is white)
chri
Hi
A dumb question.
Is there a way to get Max's dimensions to display feet/inches/fractions?
thanks,
eric
hi eric
Please take a look to the previous post 7403.93
chri
Dimensions v1.1
Improved compatibility with MoI v4
Added font change menu
http://moi.maxsm.net/item/37
Great !
Thanks a lot Max
Thank you so much, this script is too useful ..
Thank you very much Max!
Great job...as usual :)
Hi
Thanks a lot Max
Christian
French Version! ;)
http://moiscript.weebly.com/cotations.html
69-88
89-108
109-128
129-138
