Full Version: Dimension tool (as in sketchup)
Show messages:  0-19  20-39  40-59  60-79  …  120-138
18 May 2015   [#1]
Hi Moi'ers
Is it possible to add dimensions and angles of a model, as in sketchup, by adding a script?
I think it would be very useful :)
Stardust
18 May 2015   [#2] In reply to [#1]
you can use the free Design Spark Mechanical for this sort of thing!
And advantage you can make the Fillets that have some problem in Moi! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1 and see message 24 ...
18 May 2015   [#3] In reply to [#1]
Hi Stardust,
Sorry no, that's not really feasible for a script. Scripts can do things like automate existing functionality but dimensions are something that need need low level support in the draw engine, they're not like just automating and repackaging existing functionality like a script can usually do.
So it's not really something that can be added by a script, it needs to be added more directly into some of the core MoI modules.
Certainly it would be! I am planning on working on it for v4.
19 May 2015   [#4] In reply to [#3]
Thank you Michael, sounds promising for v4
27 Jun 2015   [#5]
I wrote this script today evening for my friend. It's very primitive, but it's better than nothing. :)
I have no plans to continue developing of this script. Sorry.
27 Jun 2015   [#6] In reply to [#5]
I have not the "little Lines" of extremities!
Must I draw them separately ?
And alas we can't use the Helpers lines for align because of the second click ! :)
Seems Scale inactive! ?
French Version http://moiscript.weebly.com/cotations.html
28 Jun 2015   [#7] In reply to [#5]
hi Max
Many thanks for this great present .
i don't think that's primitive , for me , it's a major improvement .
Thanks again
Chri from France
28 Jun 2015   [#8]
Very useful - many thanks Max! :)
Hi Pilou:
Me neither.
I guess so. Max?
Any helper lines can be created immediately after starting script but before first click defining location of dimension arrow head #1.
It's activated after 'first click' for arrowhead #1.
Cheers,
Hamish
28 Jun 2015   [#9] In reply to [#8]
<< but before first click defining location of dimension arrow head #1.
Ahhh yes! Different than the normal use of a script!
So cool!
<< It's activated after 'first click' for arrowhead #1.
Ahhhh yes! Funny use! So very cool! :)
28 Jun 2015   [#10] In reply to [#5]
Hi ..
Showing my ignorance about scripts ..
How do I install this script and use it ?
Cheers, and thanks,
eric
28 Jun 2015   [#11] In reply to [#5]
Hi Max, thank you for the dimension script it is very useful.
Cheers!
28 Jun 2015   [#12] In reply to [#10]
HI eric (ERICCLOUGH)
first time
You need to copy the two files in the commands folder of MOI
second time
you need to add the shortcut keys and the command :
_dimensions
Chri from France
28 Jun 2015   [#13] In reply to [#12]
Thanks Christian,
eric
28 Jun 2015   [#14]
Script update. Fixed few bugs. Changed internal structure. Script modifications should be easier.
Frenchy Pilou
Yes, you should draw them manually.
You can use LockConstructionLine script
var cln =0, gd = moi.geometryDatabase, cl = gd.getObjects().getConstructionLines(), cll = cl.length;
for (var i=0; i<cll; i++) if (!cl.item(i).isTemporary) cln++; if (cln == cll) { gd.removeObjects(cl) } else { cl.setProperty( "isTemporary", false ) }
Bind it to key. Draw construction lines. Run script (the lines will be locked). Run script again to delete the lines.
Hamish, Chri, phlatt5th
Thank you :)
28 Jun 2015   [#15] In reply to [#14]
Cool!
French version Updated! :)
28 Jun 2015   [#16]
Max, that's fine!
This is what the Bolsheviks were dreaming! ))))
I download and run the testing. Thank you very much!
You are, as always, is a genius!
29 Jun 2015   [#17]
Forget to say about hidden features.
Double click title to load default values
Double click "Scale" to reset scale.
29 Jun 2015   [#18] In reply to [#17]
All day a nice surprise! :)
29 Jun 2015   [#19]
Beautiful script, Max!
as usual... :-)
Thanks for sharing.
Mik
29 Jun 2015   [#20]
Thanks a lot, Max. Its quite usefull.
