Full Version: Let's Model a Car: A Tutorial
Show messages:  1-3  4-23  24-43  44-63  64-79
24 May 2015   [#64]
Hi Ed,
I just read this tutorial. Fantastic work! I'm happy that my scripts helped you :)
I hope, I'll return to script development in the nearest future. Unfortunatelly I haven't free time for it now.
24 May 2015   [#65] In reply to [#64]
Thank you Max for bringing this added functionality to MoI. I'm sure your scripts will help a lot of people.
14 Jun 2015   [#66]
Help please,
I'm new to scripts and the forum. I downloaded scripts and copied and pasted into MoI's command file.
when I tryed subdivide, got- SyntaxError: Parse error
any help would be appreciated.
thanks,
Bob
FlySketchWorkflow-2015.06.15 00.22.20.pdf.pdf
FlySketchWorkflow-2015.06.15 00.32.47.tiff
14 Jun 2015   [#67] In reply to [#66]
Hi Bob - it looks like you have copied the files into the correct place. But it looks like you may have some problem in how the shortcut key is set up, do you have some extra characters in the shortcut key or something like that?
In the shortcut key, you should put in just: Subdiv_beta6
15 Jun 2015   [#68]
That is is curious because all plugins by Max are something like _Subdiv_beta6 with a "_" as first letter!
Have you modified the name of the original script as shown on your list of files ?
15 Jun 2015   [#69] In reply to [#67]
Michael
Thank you, I was trying to use the detected buttons, but the shortcut keys work!
This is really a great addition to your program. I have friends that rave about Creo for product design, this seems to give a MoI another level of flexibility in model generation.
Bob
15 Jun 2015   [#70] In reply to [#68]
Pllou
yes I did (my ignorance). Micheal's direction on the shortcut keys got it working.
I'm really excited to try out this new tools!
thanks for your help
bob
15 Jun 2015   [#71]
Absolutely awesome tutorial - thanks so much for this!
-Will
24 Jun 2015   [#72]
Thank you so much for producing this wonderful tutorial Ed!
Definitely one I'll be putting on the reference shelf - and referring people to as a great example of just how capable MoI (+ Max's SubD) is.
Keep up the great work.
Cheers,
Hamish
16 Oct 2015   [#73]
Hey man...you did an OUTSTANDING JOB!!!!!!!!!!!!!!!!!!
I'll never be tired to say that....I love to see this project...in the right hands, this little gem of program can do really amazing things! :)
Great job, and thanks a ton for the tutorial!!!! :)
31 Oct 2015   [#74] In reply to [#2]
When I download the .zip file for the Bridge script I only get 1 file: _sBridge.js. There is no .htm file included. Is there something missing or is the .htm not required for the bridge command.
31 Oct 2015   [#75] In reply to [#74]
No need for the function Bridge : Generaly htm is used for UI, menu, parameter etc...
So make just a short cut or press tab then write _bridge (upper caser letter(s) or not but don't forget the "_") !!!
31 Oct 2015   [#76] In reply to [#74]
Hi Wlawton,
That's normal that there's no .htm file for that particular command.
The .htm files contain user interface elements for a command like buttons and checkboxes and stuff like that. If the way a command works is that it just immediately performs an action and doesn't have any UI for buttons and options or things like that, then it may not have an .htm file in it.
1 Nov 2015   [#77]
Hi
I found adding the scripts a bit confusing at first and struggled along installing them piecemeal before discovering there is a link that allows you to install them all complete with a new set of icons in Moi's UI. Oddly nobody ever seems to point this out despite the tools being present in some tutorial videos. I'm off to work now but you should be able to find them on Max's page http://moi.maxsm.net/startpos/8. And looking at this thread I'm missing a few:)http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
6 Dec 2015   [#78]
I gave up on making a car when Carrara kept ripping up the smoothing. I found half an old model today so put some wheels on it and rendered it in Simlab. I like the smooth surfaces but I don't think I will finish the model as I feel like doing something new.
Moi is really amazing!
6 Dec 2015   [#79]
Very elegant!
