2-21
22-27
Elegant stream line! :)
Hi Frenchy Pilou,
thank !
the shell command is powerful : after a short time calculating, the result is very good
- "Would you like to order , Madam ? "
- "No , i do not like this color" :(
Hi
some refinements
Loubouting! :)
Hi Pilou
Loubouting ?
ah ! yes, louboutin !
http://eu.christianlouboutin.com/fr_fr/homepage-1/women.html
Hi
Rendering: Cycles
same idea . I started with a subdiv model.
But for this one a lot of surface are made by blend, loft and sweep.
the subdiv model is used like a "3d blue print"
Developing nicely - :)
Martin Spencer-Ford
some explanations (i'm french, forgive me for my poor english)
the basic shape. I use Max' tools (split, bridge, scale)
subdiv script
boolean substract with red curve
i join top edges to make a curve. I copy it and move the copy.
too many points. So i use Rebuild command
rail sweep (blue rails)
the result
iso curve (yellow). i reshape it....
... and make new rail sweep (two red profiles and two blue rails)
the basic shape (.3dm) is in attachement.
poly_shoe.3dm
wow nice :-)
Please a litle more explanation on how the basic shape is build up
Hi hep
i hope this screenshot helps you
you can read this thread
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.117Image Attachments:
Cool Tutorial (s)!
Can I translate it in French (if it's not yet translated) and put it somewhere in this French Moi Site!
http://moiscript.weebly.com/
(I am French too ! :D
Thanks - that helped alot :-)
Hi Frenchy Pilou
oui !
yes ! :)
Je passe chez le cordonnier et je livre tard dans la soirée! :)
http://moiscript.weebly.com/chaussure.html
Very nice tutorial! Thanks!
very nice translation
thank you Pilou !
Classieux! ;)
new model (not suitable for winter ! )
2-21
22-27
