Show messages: All
1-5
6
I got it!
Because codemirror has its' own undo/redo functionality objects can be added to commandbar like in FullScreen.js and then I simply set up a new shortcut for CTRL+Z and Y that checks if the editor has focus.
var cb = moi.ui.getUIPanel('moi://ui/CommandBar.htm');
cb.consoleDoc = document;
cb.editor = editor;
$(window).unload(function() {
delete cb.consoleDoc;
delete cb.editor;
if (cb.consoleDoc && cb.consoleDoc.hasFocus()) {
cb.editor.undo()
} else {
moi.command.undo();
So now there is a small script console with syntax highlighting, line numbers, undo/redo and bracket matching. Still not too much, but it can be found here:
https://github.com/thetumbledtype/moi3d-scripts-other/blob/master/ScriptConsole.htm
Show messages: All
1-5
6
