Full Version: MoI GUI Builder released for Mac and PC!
Show messages:  1-17  18-37  38-57  58-77  78-97  98-104
12 Feb 2015   [#18] In reply to [#17]
Hey guys,
Sorry..been in meetings all day with lawyers. As I mentioned, I still don't have a windows image for my VMware here at home, so it will be awhile before I can get to Windows specific changes.
I'll try and see what I can get to this evening.
13 Feb 2015   [#19]
Update
Fixed the aforementioned issues. Press button check for update (dot 1) to load the new version. No need to restart.
The (dot 4) close button now has more properties and works correctly. The (dot 3) properties field now had a custom text-color property you can set which overides the CSS in the SidePaneContextArea.htm for the text-color.
Please NOTE: If you've previously *saved* a template from MGB, and then load it, you will now need to press the (2) RESET button for any individual item which has been updated since last saved. In this case, all you need to do is reset the two shown areas (4 & 3).
Michael,
On another note, is there any sort of CSS which I can access to define the text input highlight text and background color (5)? FWIW I tried variants of:
::-webkit-selection {
  background: green;
  color: yellow;
13 Feb 2015   [#20] In reply to [#19]
Does the dowloading address of the new version is always the same ?
13 Feb 2015   [#21] In reply to [#20]
Hi Frenchy,
The URL for the application will stay the same. But, (and this is important) when newly downloaded from the web it will ONLY run the older version. You **MUST** press the check update button to download the latest version.
So, once it is installed, you never have to install again (unless I make changes to the core engine). Just press the check for update button and you will always have the latest version.
13 Feb 2015   [#22] In reply to [#21]
Thx for the Infos!
13 Feb 2015   [#23]
Don't want to niggle, just two things:
Would be nice changing
the hover Color here:
Background here:
and here:
Color of the pressed PushButton:
Thanks a lot. Rest should be fine! :-)
13 Feb 2015   [#24] In reply to [#23]
I'll look into where I can find the CSS. Thanks for sharing. Probably get to it this weekend.
13 Feb 2015   [#25] In reply to [#23]
Hi Jay & Chipp, just some quick notes on the location of the CSS for those:
That's a <moi:LabelButton>, the css for its background colors for hovered and active (when clicked down) are in moi.css:
moi\:LabelButton:hover, .label_button:hover {
	background-color:#BBBBBB;
moi\:LabelButton:active, .label_button:active {
	background-color:#999999;
> Background here:
That one is in StyleMenu.htm, in a stylesheet in the <head> element, the one for id="Container":
			#Container {
				background-color:white;
> and here:
That one is in EditStylesDialog.htm, in a stylesheet in the <head> element, the one for id="StylesContainer":
			#StylesContainer {
				border:1px solid #CCC;
				background-color:#FFF;
That one is in moi.css, the one that controls the active state of a moi:PushButton :
moi\:PushButton:active > div {
	background:rgb(205,215,227);
	-webkit-box-shadow:inset 0px -1px rgb(255,255,255), inset 2px 2px rgb(180,180,180);
Message 7245.26 was deleted
15 Feb 2015   [#27] In reply to [#25]
There are three places don't know where to change the color, please help to solve. Thank you very much!
Background here:
and here:
Color of input
-Yuan
15 Feb 2015   [#28] In reply to [#27]
Hi Yuan,
> Background here: (Shortcut key editor sections of Options command):
Unfortunately the shortcut key editor uses an unusual non-HTML based control not used anywhere else and the colors it uses are not settable using CSS. So currently there isn't any way to modify those particular colors.
> and here: (List control at top of the View > Image command):
That's in the Image.htm file, which you'll find in the commands sub-folder (commands folder, not the ui folder), it's in the top of the file here:
			#FilenameContainer {
				border:1px solid #AAA;
				background:white;
> Color of input (color for selected text in an input control):
Sorry it does not look like it is currently possible to modify these colors. There is a ::selection selector in CSS which is supposed to do it, it does not seem to be working in the version of WebKit that MoI uses though.
15 Feb 2015   [#29] In reply to [#28]
Great UI!
15 Feb 2015   [#30] In reply to [#25]
Thanks Michael,
Unfortunately, these will have to wait until next weekend before I can get to them. Much appreciated!!!
15 Feb 2015   [#31] In reply to [#28]
According to your method has been modified. Thanks!
Also,the scroll bar color can change?
-Yuan
15 Feb 2015   [#32] In reply to [#31]
Hi Yuan,
It is possible to change the scollbar colors but it's somewhat laborious since you can't just tweak a single color, when you use a custom scrollbar selector it will replace the default system drawn scrollbar entirely and so you will have to specify a lot of different properties yourself to make up all the pieces.
The different selectors are described here:
http://css-tricks.com/custom-scrollbars-in-webkit/
Also some info here:
http://beautifulpixels.com/goodies/create-custom-webkit-scrollbar/
So for a quick example, if you add this into moi.css you will get a weird looking red and yellow 2 color scrollbar:
::-webkit-scrollbar {
background:red;
::-webkit-scrollbar-thumb {
background:yellow;
15 Feb 2015   [#33] In reply to [#31]
Hi Yuan,
yes, it's a nice UI you are working on.
Would be a pleasure if you share it after finishing.
5 Mar 2015   [#34]
Hi Chippwalters
this is a great tool. Where can I found the last version?
Michael
5 Mar 2015   [#35] In reply to [#34]
Look at the bottom of the first post. Download then press the "check for updates" button.
9 Mar 2015   [#36]
Is there a way to change this frame?
9 Mar 2015   [#37]
Sorry I haven't gotten around to making all the changes yet. I've been slammed at work and have to finish other projects on the weekend. I hope I'll get to it this coming weekend :-).
