Full Version: MoI GUI Builder released for Mac and PC!
Show messages:  1-9  10-29  30-49  50-69  70-89  90-104
10 Feb 2015   [#10]
Thank you! Great app.
10 Feb 2015   [#11] In reply to [#10]
Thanks Max to you, too, for all the great work you do for this community!
Let me know if I missed any selectors.
10 Feb 2015   [#12] In reply to [#9]
The UI font is automatically set onto the <body> element as part of the processing that happens when an HTML document is loaded, the setting for it is in moi.ini, under:
[UI]
UIFontName=Century Gothic
The font size is also set in the same way and it can be adjusted in the Options dialog under the "General" section with the slider for "UI size".
11 Feb 2015   [#13] In reply to [#12]
This is really fantastic, Chipp! Thank you very much!
How can I change this grey text color?
11 Feb 2015   [#14] In reply to [#13]
Hi Jay & Chipp,
re: How can I change this grey text color?
See here for a description of where the CSS that controls that color is located:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7132.2
11 Feb 2015   [#15]
Okay. I'll trying get that fixed tonight. Is there anything else that's missing?
12 Feb 2015   [#16]
I'm not sure if changing the "CloseWindowButton" Backgroundcolor Change is working...
12 Feb 2015   [#17] In reply to [#16]
Hi Jay & Chipp,
re: I'm not sure if changing the "CloseWindowButton" Backgroundcolor Change is working...
There are 2 different window close buttons, the first one is a <moi:WindowControlButton> with id="Close" - that one is one that you will only see on the Windows version when it is a maximized window, it will be a close button in the upper right corner of the main window. That one is controlled in moi.css by:
moi\:WindowControlButton#CloseWindow:hover img {
background-color:rgb(250,96,96);
moi\:WindowControlButton#CloseWindow:active img {
background-color:rgb(235,9,9);
The one that Jay shows below is in flyout menus, that one is a <moi:SmallCloseWindowButton>, it's controlled in moi.css by:
moi\:SmallCloseWindowButton:hover {
border-color:rgb(124,124,124);
moi\:SmallCloseWindowButton:active {
12 Feb 2015   [#18] In reply to [#17]
Hey guys,
Sorry..been in meetings all day with lawyers. As I mentioned, I still don't have a windows image for my VMware here at home, so it will be awhile before I can get to Windows specific changes.
I'll try and see what I can get to this evening.
13 Feb 2015   [#19]
Update
Fixed the aforementioned issues. Press button check for update (dot 1) to load the new version. No need to restart.
The (dot 4) close button now has more properties and works correctly. The (dot 3) properties field now had a custom text-color property you can set which overides the CSS in the SidePaneContextArea.htm for the text-color.
Please NOTE: If you've previously *saved* a template from MGB, and then load it, you will now need to press the (2) RESET button for any individual item which has been updated since last saved. In this case, all you need to do is reset the two shown areas (4 & 3).
Michael,
On another note, is there any sort of CSS which I can access to define the text input highlight text and background color (5)? FWIW I tried variants of:
::-webkit-selection {
  background: green;
  color: yellow;
13 Feb 2015   [#20] In reply to [#19]
Does the dowloading address of the new version is always the same ?
13 Feb 2015   [#21] In reply to [#20]
Hi Frenchy,
The URL for the application will stay the same. But, (and this is important) when newly downloaded from the web it will ONLY run the older version. You **MUST** press the check update button to download the latest version.
So, once it is installed, you never have to install again (unless I make changes to the core engine). Just press the check for update button and you will always have the latest version.
13 Feb 2015   [#22] In reply to [#21]
Thx for the Infos!
13 Feb 2015   [#23]
Don't want to niggle, just two things:
Would be nice changing
the hover Color here:
Background here:
and here:
Color of the pressed PushButton:
Thanks a lot. Rest should be fine! :-)
13 Feb 2015   [#24] In reply to [#23]
I'll look into where I can find the CSS. Thanks for sharing. Probably get to it this weekend.
13 Feb 2015   [#25] In reply to [#23]
Hi Jay & Chipp, just some quick notes on the location of the CSS for those:
That's a <moi:LabelButton>, the css for its background colors for hovered and active (when clicked down) are in moi.css:
moi\:LabelButton:hover, .label_button:hover {
	background-color:#BBBBBB;
moi\:LabelButton:active, .label_button:active {
	background-color:#999999;
> Background here:
That one is in StyleMenu.htm, in a stylesheet in the <head> element, the one for id="Container":
			#Container {
				background-color:white;
> and here:
That one is in EditStylesDialog.htm, in a stylesheet in the <head> element, the one for id="StylesContainer":
			#StylesContainer {
				border:1px solid #CCC;
				background-color:#FFF;
That one is in moi.css, the one that controls the active state of a moi:PushButton :
moi\:PushButton:active > div {
	background:rgb(205,215,227);
	-webkit-box-shadow:inset 0px -1px rgb(255,255,255), inset 2px 2px rgb(180,180,180);
Message 7245.26 was deleted
15 Feb 2015   [#27] In reply to [#25]
There are three places don't know where to change the color, please help to solve. Thank you very much!
Background here:
and here:
Color of input
-Yuan
15 Feb 2015   [#28] In reply to [#27]
Hi Yuan,
> Background here: (Shortcut key editor sections of Options command):
Unfortunately the shortcut key editor uses an unusual non-HTML based control not used anywhere else and the colors it uses are not settable using CSS. So currently there isn't any way to modify those particular colors.
> and here: (List control at top of the View > Image command):
That's in the Image.htm file, which you'll find in the commands sub-folder (commands folder, not the ui folder), it's in the top of the file here:
			#FilenameContainer {
				border:1px solid #AAA;
				background:white;
> Color of input (color for selected text in an input control):
Sorry it does not look like it is currently possible to modify these colors. There is a ::selection selector in CSS which is supposed to do it, it does not seem to be working in the version of WebKit that MoI uses though.
15 Feb 2015   [#29] In reply to [#28]
Great UI!
