Full Version: Cycles for MoI
Show messages:  1-3  …  24-43  44-63  64-83  84-103  104-113
19 Jun 2016   [#84] In reply to [#83]
Hi Matt
Are you using software or gpu cycles version?
Try this one: http://moi.maxsm.net/media/files/Cycles.CPU.zip
19 Jun 2016   [#85] In reply to [#84]
I'm using Cycles.cpu
I tried the download you shared and still get the saame grey cycles window.
21 Jun 2016   [#86] In reply to [#85]
Will the script work with version 2 of Moi?.
21 Jun 2016   [#87] In reply to [#86]
I don't know, but most newer complex scripts need functions that are in version 3. You could give it a try though.
21 Jun 2016   [#88] In reply to [#87]
Thanks for the feedback Michael, appreciated!.
27 Sep 2016   [#89]
Hello Max, Michael and all,
because i could not find a binary for OS X on the net i compiled it myself two days ago.
I just want to let you know that it is vers. 1.7.0 standalone and your script seems no
longer compatible with it. Now Cycles requires <cycles> and </cycles> tags in the
.XML files. I also noticed that i have problems with the FOV parameters in the script
and with MoI. Once i completely omitted the FOV parameter in the .XML file, i got reasonably
render result.
Because i don't know if it was tested under OS X i like to ask if you or Michael, or
anybody else knows how to change the script so that it no longer writes in MoI's Temp
directory and how to start the Cycles program with your script under OS X.
Best regards
27 Sep 2016   [#90]
Here's a screen shot showing a test set-up without the FOV parameter usage in your script. With the FOV parameter i get when changing (for zoom-in) up-side down images for example.
Best regards
27 Sep 2016   [#91] In reply to [#89]
Hi Stefan, re:
Can you give some more details? What is the MoI Temp directory that you're referring to, and what is currently being written there, and what directory do you want it changed to write to instead?
I'm not familiar with this script myself but if I started out knowing some more details that would help.
27 Sep 2016   [#92] In reply to [#91]
Hello Michael,
i used Max's Cycles script from here:
and it writes all files (.xml, .obj, .mtl) required for Cycles in MoI's drive_c/users/Wineskin/Temp/ folder.
I then copy those files to my Desktop in a folder and run then Cycles from the command line.
I would like to be able that the script does not write into the MoI app, instead i would like to see that
it writes for example to a folder on the Desktop.
Best regards
27 Sep 2016   [#93]
Hello Michael,
here's the path seen from terminal:
Best regards
27 Sep 2016   [#94] In reply to [#93]
Hi Stefan, so the temp path is set on line #59 in hte file _Cycles.htm which currently has this:
	var tempPath = moi.filesystem.getTempDir();
To make it go into a directory on your desktop try changing that first trying an OS X native path like this for example:
	var tempPath = '/Users/stefan/Desktop/Cycles/';
Let me know if that makes the files go to where you wanted them or if it still doesn't work.
This may also help the auto launch of cycles to work as well, let me know if that part still doesn't work. At least one problem with the auto launching part was giving cycles a Windows/Wineskin style path name as a parameter instead of a mac native file path, and since cycles isn't a wineskin app it won't understand a Wineskin type path.
28 Sep 2016   [#95]
thank you so much for your quick help! Now it works perfectly. It saves in the proper location and starts Cycles too! :-)
Super!
Best regards
28 Sep 2016   [#96] In reply to [#95]
You're welcome Stefan, that's great that was all it took to get it working on Mac!
1 May 2017   [#97]
I tried to find the download for Cycles Standalone /for Windows 8 and XP) but did not find it.
Any tips are warmly welcome !
1 May 2017   [#98] In reply to [#97]
Hi Tom,
have you tried this one?
1 May 2017   [#99] In reply to [#98]
Sorry Max, I did not realize that Cycles is included in the link on your homepage !
So I will try to get it working now - thank you !!
13 Oct 2017   [#100] In reply to [#98]
Hi. I tried downloading http://moi.maxsm.net/media/files/Cycles.CPU.zip , but i think the file is corrupted, can you please help me somehow.
Thanks a lot for the scripts u make!
13 Oct 2017   [#101] In reply to [#100]
Hi David, I just tested downloading http://moi.maxsm.net/media/files/Cycles.CPU.zip and it seemed to be fine over here. Did you get a message when trying to unzip it that the archive is corrupted, or was it some other error? I'd recommend deleting it and trying to download it again.
17 Apr 2018   [#102] In reply to [#98]
Hi Max.
I downloaded http://moi.maxsm.net/media/files/Cycles.CPU.zip, But the file is corrupt. Can you upload it again?
13 May 2020   [#103]
Very sad, this was not more developed, this was the best free option rendering engine for Moi3D if developed.. Is old 5 years..
