Full Version: Cycles for MoI
Show messages:  1-20  21-40  41-60  61-80  81-100  101-113
6 Feb 2015   [#21] In reply to [#20]
>> Where is your script ??
>> What must be there in the Moi's Cycles folder ? All the unzip Cycles file ?
Cycles.v.0.8.2015.02.06.zip -> moi directory/commands
Cycles_Windows64.zip -> moi directory/cycles
Ps It's a Zenit camera ? :)
Yes :-) My first slr.
7 Feb 2015   [#22] In reply to [#20]
Hi, it's working very nicely. The exporter seems very stable and quick. Is there others options for materials?
7 Feb 2015   [#23]
Cool!
All works this time!
7 Feb 2015   [#24] In reply to [#23]
Frenchy Pilou what them you use for Windows? I saw that kind of windows before and I like them.
7 Feb 2015   [#25]
No Special Windows, it's the natural model by default in Windows 8! :)
(i just edit the color of 2D image for the forum ;)
But you can make the same inside Moi with editing color of the UI !
Options / View
French version and manual of Cycles for Moi
http://moiscript.weebly.com/cycles-pour-moi.html
7 Feb 2015   [#26] In reply to [#25]
Frenchy Pilou, I just talking about windows theme, not about MoI GUI, now I understood it is Windows 8, thanks.
7 Feb 2015   [#27] In reply to [#16]
Does anyone know if this works with the Mac?
7 Feb 2015   [#28] In reply to [#27]
From this http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
I suppose yes, but the Max script itself I don't know!
7 Feb 2015   [#29]
Seems the render Window size is not kept if this size modified at the beginning for the next renders!
7 Feb 2015   [#30]
New version.
Shaders support:
[D:xx] - Diffuse : Roughness 0-100
[G:xx] - Glossy : Roughness 0-100
[S:xx] - Glass : Roughness 0-100
[V:xx] - Velvet : Sigma 0-..
[C:xx] - Toon : Smooth 0-100
[T] - Translucent
[E:xx:xx] - Emission : Strength 0-... : Size (for point light sources; optional)
Added mix shader:
[G:10 C:30] - Glossy:10+Toon:30 (50/50 default)
[G:10 C:30 70] - Glossy:10+Toon:30 (30/70)
8 Feb 2015   [#31] In reply to [#20]
It's possible to do the same for mac ?
8 Feb 2015   [#32]
Added:
[A] - Ambient occlusion
fixed point lights export bug
Finema
chippwalters
Unfortunately I don't have a Mac, so I can't check this.
I'll try to install MacOS to virtual machine.
It's impossible to get window size information from cycles to moi.
8 Feb 2015   [#33] In reply to [#32]
<< It's impossible to get window size information from cycles to moi.
I speek about the Window's size render of Cycles: who can be anywhere on the same monitor or on another one
so not in the screen of Moi !
8 Feb 2015   [#34]
OSX:
I managed to get Cycles standalone running on OSX, also managed to write out an .xml file into the temp folder with your script!
Then with Terminal, I rendered it with Cycles. With this script:
/Applications/MoI\ v3.app/Contents/Resources/drive_c/moi/cycles/cycles /Applications/MoI\ v3.app/Contents/Resources/drive_c/users/Wineskin/Temp/ball_square_scene.xml
But not a programmer, so didn't understand how to edit your script so it does this automatically.
http://blender.dingto.org/cycles_standalone/Cycles_OSX_10.9_x86_64.zip
8 Feb 2015   [#35] In reply to [#34]
When you say that
"Then with Terminal"
How do you process for access to a "terminal" ?
8 Feb 2015   [#36] In reply to [#35]
Oh, in Applications > Utilities - you will find the Terminal app.
With the Terminal app opened, you can drag your Cycles standalone app there (to get it's location), then add a space and then drag your xml file to the Terminal window and hit enter.
This will render your xml in Cycles standalone on OSX.
Did this very fast test, to see if it worked. Pretty sweet render of glass in 30 seconds on a laptop! Like the Cycles renderer! :-D
8 Feb 2015   [#37] In reply to [#36]
What's the way to process ball_square_scene.xml
9 Feb 2015   [#38]
Can we imagine have some cursors in Moi for input the Different shaders against input them by hands?
And what about textures ?
9 Feb 2015   [#39]
Very nice work Max! Thank you very much! :)
I had a few problems, described below, which might be a bug with the MoI script - and/or help someone else.
A big problem remains however: Cycles still isn't writing the png image to the snapshots folder despite reporting that it is, (see the screen capture below). Any ideas appreciated.
My Win7(64) was reporting compatibility issues:
- The first script didn't work, other than the Cycles window flashing open-closed after I specified the mesh geometry in MoI.
- The second script seemed to work for a while, then, after pressing Q to save and quit from Cycles, Win7 reports Cycles had terminated incorrectly and was searching for a solution; nothing saved either.
- Next time Cycles started, Win7 told me it was applying compatibility settings.
- Thereafter, pressing Q in Cycles displays a message saying it's saving the png in the MoI3.0\snapshots folder, but no file is actually saved there.
- Now I'm right back to the beginning - the Cycles window flashes open and closed after specifying the mesh geometry.
Somewhere along the way (above) I changed the script to "Cycles noexport". At first it seemed to work, then in the Cycles window that flashed open-closed, I could read "xml file not found" or words to that effect. Changing the script back to "Cycles" got it working again.
Cycles reports "Writing Image", but no file is created:
Cheers,
hairykiwi
9 Feb 2015   [#40]
<< pressing Q to save and quit from Cycles, Win8 reports Cycles had terminated incorrectly and was searching for a solution
Idem for the Q key !
