Full Version: Cycles for MoI
Show messages:  1-18  19-38  39-58  59-78  79-98  99-113
6 Feb 2015   [#19] In reply to [#18]
Just a Dos (?) window as I can see on this rapid view! :) and just 1/10 second then nothing!
What must be there in the Moi's Cycles folder ? All the unzip Cycles file ?
Ps It's a Zenit camera ? :)
6 Feb 2015   [#20]
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
<< Cycles needs to be started from a terminal: cycles [options] file.xml
How have this terminal ?>> My script can have problems with special characters in the paths
(sure French Windows System alas has some accents... :)
Where is your script ???
I don't see it in your post!!!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7208.16
6 Feb 2015   [#21] In reply to [#20]
Cycles.v.0.8.2015.02.06.zip -> moi directory/commands
Cycles_Windows64.zip -> moi directory/cycles
Yes :-) My first slr.
7 Feb 2015   [#22] In reply to [#20]
Hi, it's working very nicely. The exporter seems very stable and quick. Is there others options for materials?
7 Feb 2015   [#23]
Cool!
All works this time!
7 Feb 2015   [#24] In reply to [#23]
Frenchy Pilou what them you use for Windows? I saw that kind of windows before and I like them.
7 Feb 2015   [#25]
No Special Windows, it's the natural model by default in Windows 8! :)
(i just edit the color of 2D image for the forum ;)
But you can make the same inside Moi with editing color of the UI !
Options / View
French version and manual of Cycles for Moi
http://moiscript.weebly.com/cycles-pour-moi.html
7 Feb 2015   [#26] In reply to [#25]
Frenchy Pilou, I just talking about windows theme, not about MoI GUI, now I understood it is Windows 8, thanks.
7 Feb 2015   [#27] In reply to [#16]
Does anyone know if this works with the Mac?
7 Feb 2015   [#28] In reply to [#27]
From this http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
I suppose yes, but the Max script itself I don't know!
7 Feb 2015   [#29]
Seems the render Window size is not kept if this size modified at the beginning for the next renders!
7 Feb 2015   [#30]
New version.
Shaders support:
[D:xx] - Diffuse : Roughness 0-100
[G:xx] - Glossy : Roughness 0-100
[S:xx] - Glass : Roughness 0-100
[V:xx] - Velvet : Sigma 0-..
[C:xx] - Toon : Smooth 0-100
[T] - Translucent
[E:xx:xx] - Emission : Strength 0-... : Size (for point light sources; optional)
Added mix shader:
[G:10 C:30] - Glossy:10+Toon:30 (50/50 default)
[G:10 C:30 70] - Glossy:10+Toon:30 (30/70)
8 Feb 2015   [#31] In reply to [#20]
It's possible to do the same for mac ?
8 Feb 2015   [#32]
Added:
[A] - Ambient occlusion
fixed point lights export bug
Finema
chippwalters
Unfortunately I don't have a Mac, so I can't check this.
I'll try to install MacOS to virtual machine.
It's impossible to get window size information from cycles to moi.
8 Feb 2015   [#33] In reply to [#32]
<< It's impossible to get window size information from cycles to moi.
I speek about the Window's size render of Cycles: who can be anywhere on the same monitor or on another one
so not in the screen of Moi !
8 Feb 2015   [#34]
OSX:
I managed to get Cycles standalone running on OSX, also managed to write out an .xml file into the temp folder with your script!
Then with Terminal, I rendered it with Cycles. With this script:
/Applications/MoI\ v3.app/Contents/Resources/drive_c/moi/cycles/cycles /Applications/MoI\ v3.app/Contents/Resources/drive_c/users/Wineskin/Temp/ball_square_scene.xml
But not a programmer, so didn't understand how to edit your script so it does this automatically.
http://blender.dingto.org/cycles_standalone/Cycles_OSX_10.9_x86_64.zip
8 Feb 2015   [#35] In reply to [#34]
When you say that
"Then with Terminal"
How do you process for access to a "terminal" ?
8 Feb 2015   [#36] In reply to [#35]
Oh, in Applications > Utilities - you will find the Terminal app.
With the Terminal app opened, you can drag your Cycles standalone app there (to get it's location), then add a space and then drag your xml file to the Terminal window and hit enter.
This will render your xml in Cycles standalone on OSX.
Did this very fast test, to see if it worked. Pretty sweet render of glass in 30 seconds on a laptop! Like the Cycles renderer! :-D
8 Feb 2015   [#37] In reply to [#36]
What's the way to process ball_square_scene.xml
9 Feb 2015   [#38]
Can we imagine have some cursors in Moi for input the Different shaders against input them by hands?
And what about textures ?
