Full Version: Log Spiral
Show messages:  1-20  21-31
18 Jul 2022   [#21] In reply to [#20]
Thank you Michael.
.html vs htm, my mistake. (I'll blame it on the computer helping me out with extension.)
put " " around 0.306349. (does not seem to matter.)
added missing table closure. ( absence did not seem to matter.)
Script is working good now. PushButton looks nice.
ps,
per google search, As of June 2022, it is not possible to disable the popup on Hover of the news/weather, in Windows 11. (Very annoying.)
18 Jul 2022   [#22] In reply to [#20]
>One other thing to note, if you give a control in the command UI an id="" value then it will automatically generate a UI event of that id value when it is clicked or updated or whatever it does.
So in another situation, PushButton could feed a value into the .js file?
18 Jul 2022   [#23] In reply to [#22]
I should rename the PushButton "Restore Golden Spiral"
18 Jul 2022   [#24] In reply to [#22]
Yup! Usually the .js file will have an event loop in it and can respond to the event triggered by the button.
19 Jul 2022   [#25] In reply to [#23]
The PushButton in LogSpiral7 looks good Brian.
I'd suggest that it simply say "Golden Spiral" as it is now a clear UI element whose function is to reset the Grow_Shrink to the proper value to produce the Golden Spiral.
On edit:
The help text "To revert to the default Golden Spiral, Click on the box: Click for Golden Spiral." might be simplified to "Click the Golden Spiral button to revert to the Golden Spiral."
--Larry
24 Jul 2022   [#26]
Version 8 of LogSpiral.
As per Larry, renamed pushbutton and changed help text.
Changed color of pushbutton text to html darkgoldenrod.
24 Jul 2022   [#27] In reply to [#26]
Looks good Brian & again, a neat script!
--Larry
7 Aug 2022   [#28]
"Final" update to LogSpiral scripts. This would be version9, but I removed the version number.
Got rid of darkgoldenrod color.
Added elastica style centerPlane1 Frame, so the LogSpiral will form in any of the seven MoI Views, parallel to it's axis grid, including previously set CPlane Frame.
If user has an old LogSpiral script in a commands folder that the user wishes to keep, suggest renaming it LogSpiralOLD.
Thought about getting rid of underline, but did not.
LogSpiral2022.zip
8 Aug 2022   [#29] In reply to [#28]
Looks good Brian, neat to be able to use any view as well, thanks!
--Larry
18 Oct   [#30]
Here is an update of LogSpiral script, and may be installed in the MOI AppData>commands folder, if Custom UI is installed.
It is essentially the same as the 2022 version, but the blue help button information was updated.
It was good to refresh memory of the 2022 code, preparatory to a Conical Logarithmic spiral, also known as a ConchoSpiral.
Note that the name remains LogSpiral, without any underscore (_) prefix. The script will show up in Max's CustomUI, to the right of any scripts with underscore (_) prefixes.
The 2022 version may be overwritten.
For user selection of the center point of the spiral in any one of the six 2D views, if other geometry is in the way, said geometry may be temporarily hidden by the user.
LogSpiral2024.zip
19 Oct   [#31]
For test the script Log Spiral by BemFarmer
Alpaca
