Full Version: V4 Wish List
Show messages:  1-17  …  498-517  518-537  538-557  558-575
19 Oct 2020   [#558] In reply to [#557]
Hi, Michael.
G:\Program Files\MoI 4.0 beta Sep-10-2020
C:\Users\Vladimir\AppData\Roaming\Moi\SetDefaults.js
19 Oct 2020   [#559] In reply to [#558]
Hi WN,
It should go in the startup folder in there:
C:\Users\Vladimir\AppData\Roaming\moi\startup\SetDefaults.js
19 Oct 2020   [#560] In reply to [#559]
Hi Michael.
In this directory are the files of Maxim and it confused me, I just had to try.
Thank you, everything works, the other tabs are closed but I think I'll figure it out, or as you say it will take a couple of seconds.
In SidePane, I swapped lines 234 and 235, an open tab with dimensions became available, which is exactly what I need. The rest is from your script.
Thank you for your help.
19 Oct 2020   [#561] In reply to [#560]
Hi WN,
Hmmm, yes it looks like when the startup scripts are run the main window has not yet been sized and that then runs into some trouble with the mechanism that compacts side pane palettes when the window is sized smaller.
I'll see about running the startup scripts slightly later than they currently are so the original script can work ok.
20 Oct 2020   [#562]
Currently the IncrementalSave feature (which I use all the time) adds a two digit suffix.
Could there be a way to specify the number of digits, say 3 or 4?
Perhaps some entry in the .INI file?
Thanks much.
Frederick
20 Oct 2020   [#563] In reply to [#562]
First save as ...99 :-)
21 Oct 2020   [#564] In reply to [#562]
Hi Frederick, yes like Brian writes above the IncrementalSave is not limited to only do 2 digits, it will go up to as many digits as you need.
The only part about 2 digits is that it adds a 0 padding in front if it would otherwise only be making a single digit.
One thing that I could do to make the zero padding more flexible would be to pay attention to any zero padding in the current filename and make sure to maintain it. So that way if you wanted 4 digits you could name your current file file_0001.3dm and then it would make file_0002.3dm, etc... - no ini setting required with this method.
21 Oct 2020   [#565] In reply to [#564]
My bad - I wrongly assumed that seeing 01, 02, 03 that it was limited to 2 digits.
So could you have an entry in the INI file that specified the format of the suffix?
Nothing fancy, perhaps just allowing for letters and a place holder character for the digits.
For example an entry of " v0000" would append " v0001" , " v0002 ", " v0003", etc (without the quotes of course).
But your idea of using the end of the first file name I create would work as well - but it requires me to remember to do it - which, at my age, may or may not happen. ;)
Frederick
21 Oct 2020   [#566] In reply to [#565]
Hi Frederick, I've set it up using the method of preserving existing padding.
If you forget there isn't much consequence, it will still save.
21 Oct 2020   [#567] In reply to [#566]
So if I create the first file and it ends in " v0001" the next incremental save would end in " v0002"?
Frederick
21 Oct 2020   [#568] In reply to [#567]
Hi Frederick,
Yes, in the next v4 beta that's how it will work.
21 Oct 2020   [#569] In reply to [#568]
I am now a happy camper!
Thanks much.
Frederick
22 Oct 2020   [#570]
Hello Michael,
Hmm... Maybe I missed something.
Does the Detail button not provide the opportunity to copy the value of a Dimension?
22 Oct 2020   [#571]
Is the value of the decimal precision property preset (Options / Dimensions / Formatting / Decimal display) available for read access via the API anywhere? Thanks.
--Larry
22 Oct 2020   [#572] In reply to [#570]
Hi Mindset, re:
It does not, but that is a good idea to put in.
22 Oct 2020   [#573] In reply to [#571]
Hi Larry,
Yup, you can get a list of annotation presets using moi.geometryDatabase.getAnnotationPresets(); , and then each preset object has a whole bunch of properties on it:
   presetName
   presetIndex (read-only, position in preset list)
   setFont() (function that will show font picker dialog)
   fontName
   fontPtSize
   fontStyleName
   fontWeight
   fontStyle
   fontUnderline
   fontStrikeout
   textDisplayMode
   textAlign
   scaleMode
   height
   textAnchor
   textBoxOutline
   textBoxOutlineWidth
   textBoxOutlineWidthModelUnits
   textBoxPaddingX
   textBoxPaddingY
   textBoxPaddingXModelUnits
   textBoxPaddingYModelUnits
   arrowheadType
   arrowheadArrowLength
   arrowheadArrowLengthModelUnits
   arrowheadArrowWidthFactor
   arrowheadOpenArrowLength
   arrowheadOpenArrowLengthModelUnits
   arrowheadOpenArrowWidthFactor
   arrowheadTickLength
   arrowheadTickLengthModelUnits
   arrowheadTickLineWidth
   arrowheadDotSize
   arrowheadDotSizeModelUnits
   arrowheadReverse
   arrowPosition
   outsideLineLength
   outsideLineLengthModelUnits
   outsideDrawLineAcross
   extensionLength
   extensionLengthModelUnits
   extensionGap
   extensionGapModelUnits
   arrowLineExtension
   arrowLineExtensionModelUnits
   formattingDistanceDisplay
   formattingFractionalPrecision
   formattingDecimalPrecision
   formattingDecimalShowTrailingZeros
   radialDimensionRadialType
   radialDimensionCrossSize
   radialDimensionCrossSizeModelUnits
The one for Formatting > Decimal display is the formattingDecimalPrecision property, it can be an integer number from 0 to 7 for the number of decimal places to show.
22 Oct 2020   [#574] In reply to [#573]
Awesome Michael, you've thought of everything!! I'll give it a whirl.
--Larry
Message 6925.575 was deleted
