Full Version: V4 Wish List
Show messages:  1-7  …  488-507  508-527  528-547  548-567  568-575
3 Oct 2020   [#548] In reply to [#547]
Hi jo, I think that OpenJSCAD only generates triangle mesh output. That's where the model data is stored as a large number of little triangle facets. That type of data is not suitable for importing into MoI, MoI is designed to work with smooth NURBS surface model data for modeling.
So I don't think that is feasible to make a data flow from OpenJSCAD into MoI, they are designed to work with different types of 3D model geometry.
4 Oct 2020   [#549] In reply to [#548]
+1 Thumbnail previews
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=9391.1
I like idea of thumbnails where user can optionally set viewport to create the thumbnail.
Not what I'd class as essential but will help usability a lot. Likely even more valid when we get to grouping
and pullling in reference, tagged or hierarchical organised objects in future versions.
7 Oct 2020   [#550]
I've been using MOI for some time now. It's never let me down. The only thing I'd LOVE to see is a Linux install. :)
EDIT: I did a quick search on the forums and see that some are already using Wine. I gave it a shot! So far, so good. :D
12 Oct 2020   [#551]
Hi All,
I know that my comments are likely quite late but being a very frequent and satisfied user of Moi3D I would like to chime in with just a few wishes that would make my Moi3D user experience just a tad better:
* In the drawing I make I often have quite a lot of different objects and to me it would be feasible if it was possible to group them in "folders" sort of like what happens in windows explorer (Win7). This way a given structure could be "packed" in one folder and "clicked open" when the objects of that structure was worked on.
* Also, also considering the many objects, I sometimes find that it would be helpful if it was possible to describe what a certain object is, i.e. what it does, why it is designed as it is, and why it is placed where it is (etc.). I was thinking that it could be a note that could be attached to the object (after it was named) and maybe displayed just below the object name at the (default) right top of the UI.
* And then a wish I have made before which is to see the individual files as a thumbnail when browsing windows explorer. IMHO it would make it easier to browse drawings with many iterations so that the individual changes between each file was clearer e.g. when returning to the files after some time.
Smaller wishes to a software that I am really satisfied and pleased with ;-)
Cheers,
Jesper
P.S.: Please disregard if someone else has already mentioned this ...
12 Oct 2020   [#552] In reply to [#551]
Hi Jesper, thanks for the feedback! Your #1 and #3 are definitely on my radar but it will need to be for a future version not v4 which is very nearly wrapped up.
12 Oct 2020   [#553] In reply to [#552]
Hope life is well in these different times ;-)
... & also pleased to hear that you will consider my suggestions in due time ...
I am BTW looking forward to trying the V4 when time allows.
Cheers,
Jesper
19 Oct 2020   [#554]
Hi, Michael.
I think the dimensions tab should be open by default since it is used more often. Or make a lock for tabs that are open by default.
Or add the necessary parameters in the ini file. Also, in the settings of the text insertion tool, I need a parameter lock, for example,
I mostly use curves and I have to configure it again every time. Some settings I can make, but due to reinstalls, these settings are forgotten and lost.
I'm interested in your opinion.
19 Oct 2020   [#555] In reply to [#554]
Hi WN, well for both of those things you only have to change the setting one time in a whole program session. Different defaults would only save you like a couple of seconds for the entire program run.
It is possible to set these through script though, so if you place the attached SetDefaults.js file into the MoI appdata startup folder, that should set those up when MoI is launched.
SetDefaults.js
19 Oct 2020   [#556] In reply to [#555]
Hi, Michael.
I'm probably doing something wrong, it doesn't work.
19 Oct 2020   [#557] In reply to [#556]
Hi WN, are you using version 4? Where have you placed the SetDefaults.js file?
19 Oct 2020   [#558] In reply to [#557]
Hi, Michael.
G:\Program Files\MoI 4.0 beta Sep-10-2020
C:\Users\Vladimir\AppData\Roaming\Moi\SetDefaults.js
19 Oct 2020   [#559] In reply to [#558]
Hi WN,
It should go in the startup folder in there:
C:\Users\Vladimir\AppData\Roaming\moi\startup\SetDefaults.js
19 Oct 2020   [#560] In reply to [#559]
Hi Michael.
In this directory are the files of Maxim and it confused me, I just had to try.
Thank you, everything works, the other tabs are closed but I think I'll figure it out, or as you say it will take a couple of seconds.
In SidePane, I swapped lines 234 and 235, an open tab with dimensions became available, which is exactly what I need. The rest is from your script.
Thank you for your help.
19 Oct 2020   [#561] In reply to [#560]
Hi WN,
Hmmm, yes it looks like when the startup scripts are run the main window has not yet been sized and that then runs into some trouble with the mechanism that compacts side pane palettes when the window is sized smaller.
I'll see about running the startup scripts slightly later than they currently are so the original script can work ok.
20 Oct 2020   [#562]
Currently the IncrementalSave feature (which I use all the time) adds a two digit suffix.
Could there be a way to specify the number of digits, say 3 or 4?
Perhaps some entry in the .INI file?
Thanks much.
Frederick
20 Oct 2020   [#563] In reply to [#562]
First save as ...99 :-)
21 Oct 2020   [#564] In reply to [#562]
Hi Frederick, yes like Brian writes above the IncrementalSave is not limited to only do 2 digits, it will go up to as many digits as you need.
The only part about 2 digits is that it adds a 0 padding in front if it would otherwise only be making a single digit.
One thing that I could do to make the zero padding more flexible would be to pay attention to any zero padding in the current filename and make sure to maintain it. So that way if you wanted 4 digits you could name your current file file_0001.3dm and then it would make file_0002.3dm, etc... - no ini setting required with this method.
21 Oct 2020   [#565] In reply to [#564]
My bad - I wrongly assumed that seeing 01, 02, 03 that it was limited to 2 digits.
So could you have an entry in the INI file that specified the format of the suffix?
Nothing fancy, perhaps just allowing for letters and a place holder character for the digits.
For example an entry of " v0000" would append " v0001" , " v0002 ", " v0003", etc (without the quotes of course).
But your idea of using the end of the first file name I create would work as well - but it requires me to remember to do it - which, at my age, may or may not happen. ;)
Thanks.
Frederick
21 Oct 2020   [#566] In reply to [#565]
Hi Frederick, I've set it up using the method of preserving existing padding.
If you forget there isn't much consequence, it will still save.
21 Oct 2020   [#567] In reply to [#566]
So if I create the first file and it ends in " v0001" the next incremental save would end in " v0002"?
Frederick
