Full Version: V4 Wish List
Show messages:  1-7  …  328-347  348-367  368-387  388-407  408-427  428-447  448-467  …  568-575
16 Dec 2017   [#388] In reply to [#385]
Hello Michael. I'm sorry if I wrote somewhere bad, I communicate through an interpreter. If the translation is bad let me know and I will cease to bother you.
Vladimir.
16 Dec 2017   [#389] In reply to [#388]
Hi Vladimir, you didn't write anything bad I'm just not sure how much work is involved and I'd need to do some studying before really knowing any answer for when an arc fitting function could be implemented.
I was also trying to think about where it could be exposed in the UI, there are a few different possibilities like maybe on a more detailed object properties dialog, or maybe as another curve conversion option for DXF export.
16 Dec 2017   [#390] In reply to [#389]
Thank you for your attention. Good luck to you.
17 Dec 2017   [#391]
Here is a link to a recent paper, with an algorithm, for fitting arc splines to NURBS:
https://www.researchgate.net/profile/Xunnian_Yang/publication/3845146_Approximating_NURBS_curves_by_arc_splines/links/594ca7eb458515e70348b782/Approximating-NURBS-curves-by-arc-splines.pdf
17 Dec 2017   [#392] In reply to [#391]
Thanks Brian!
Message 6925.393 was deleted
17 Dec 2017   [#394] In reply to [#392]
You are welcome Michael.
I'm still reading the paper...
From my limited understanding, the purpose of such a dxf export in arc/line format would be useful?
Maybe tangents of NURBS curve would be exposed to scripting in the future?
- B
17 Dec 2017   [#395] In reply to [#394]
A closer look shows that the paper was uploaded in 2017, but was written in 2000.
There are 2 other similar papers by the author in ~2001, and the paper is cited by other papers.
Piegl & Tiller: https://documents.tips/documents/biarc-approximation-of-nurbs-curves.html
- B
18 Dec 2017   [#396] In reply to [#394]
Yeah often time research papers can take a lot of effort just to read and understand.
Yes, there are some CNC machines that need to be driven only by arcs for curved pieces and don't deal with spline curves.
I'll see if I can cook up some initial curve evaluating methods for the next beta.
18 Dec 2017   [#397] In reply to [#396]
Thank you Michael.
Maybe I'll start a new biarc thread.
There is a lot of information on the web.
16 Feb 2018   [#398]
a HUUUHGE wishlist ! obj importer as reference ! similar to Topogun (for Michael ref https://youtu.be/_SOCEnTgSns?t=2m21s )!
where i should have my base Hpoly as reference for modeling, some snaps options to draw curves on Hpoly !
i'm not talking about the scripted one that Max did ! (it's making surfaces out of polys - where a poly converted to surface is 16 larger than it should be ->4*4 conversion for a poly) & it's slow, Hpoly wont support, only LP
where it can be used !
*scanned surfaces to draw on top of them
*from zbrush sketches to moi - lot's of users will enjoy it ! since poly modelling is Huge time consuming -> will speed up process *4 or more
*there are more obj (meshes) libraries than stl ones !
*u'r stuff :))
17 Feb 2018   [#399]
- Anti-shell. Instead of shelling out a part, be able to unshell it, essentially making the interior of a part a solid.
- An easier stl import flow. I realize from my earlier posting on the subject that stl import isn't directly supported, but there seem to be workarounds, nothing perfect, but doable (like going through the nodeditor, which I still can't understand or make work, dummy me). I'd love to see something like this incorporated into the next version.
- Parametric MOI!
17 Feb 2018   [#400]
Hi Cemortan_Tudor, and Bob - these are pretty different kinds of things than what MoI is really focused on doing.
@Cemortan_Tudor - Reverse engineering really needs a specialized toolset to do it well. It's a broad area of work that MoI is just not focused on.
@ Bob -
re: anti-shell, could you post an example?
re: An easier stl import flow - as I mentioned in that other thread, STL files contain triangle mesh geometry, it's a very different type of geometry than the NURBS surface geometry that MoI is focused on working with for modeling. It's also a broad area of work that is pretty different than what MoI is focused on right now.
19 Feb 2018   [#401]
Any chance of adding a angle tool under deformations? If you could simply pick faces then pick the axis to taper from this would really be helpful for making master patterns for casting or models for injection molding.
Right now we are limited to the basic draft from the extrusion tool which is handy for text models but limited to base curves. Often I have models that require more than just a simple extrusion where drafts need to be put in place or modified after creation of the part as features are added. I usually end up extracting curves, offsetting them and lofting them back to create my solids which can be horribly tedious especially when you know the customer is going to make a change for the sake of changing...
20 Feb 2018   [#402] In reply to [#401]
Hi KAC - do you have an example you could post? It can be difficult for a deformation to process just some faces and not others.
20 Feb 2018   [#403]
My wish list for MOI4, in random order:
Extend with cursor, without the need for a feature to extend to.
’Snap To…’ - I often want to snap to something that is buried in a blizzard of possible targets- I end up isolating and hiding, but I wish I could just specify ‘snap to the center of this circle’.
‘Look At’ - a feature in other software that lets you select a planar surface and the view orients to it and changes the construction plane to it- I used it all the time, very useful.
An annotation text box where I could keep track of changes I made, things that need to be done, etc.
I’d like to be able to save a high resolution bitmap without shading- my end product is 2d technical drawings that I color with other software- black line art would be great, without going through the gruesome AI file cleanup.
And finally, for now, SVG output. The AI files are a mess- I spend hours trimming/extending/deleting duplicates/etc. Rather than try to improve the accuracy of AI files, a proprietary format owned by a company I don’t really admire, SVG might be a better choice.
I, of course, have no clue about what’s involved in coding these changes- just things that would make MOI better for me.
Rick
20 Feb 2018   [#404]
I can email a sample model I hand constructed, was a logo that had to go on a pipe that was sand cast. Logo is arched but drafts had to be all perpendicular to the part line.
22 Feb 2018   [#405] In reply to [#403]
Look at - try cPlane - orient to all views
Snap to might be scriptable - just for centers of objects
I have a lot of time mess in my scene with snaps options, if scene grows dramaticly -> i have to open several Moi windows to do small stuffs in other windows, keep all tangecy that i need there & one for collecting with few snaps/low mesh angle detail
a saving way for ai I see making a 4k-8k res render of view ( with hight contrast lines ) & trace in ai, manually shade surface inside Ai
22 Feb 2018   [#406] In reply to [#400]
when u say reverse engineering - the only thought is hacking that software ! nope ! i wanted a object view inside moi !
obj mesh -> moi
head -> headphones, microphone, gas masc, helm , gear, etc etc - to match shape
table -> ornaments !
old 60'th phone -> ornaments ! details
scanned mesh -> moi
roentgen, room, nature -> objects construct objects inside
22 Feb 2018   [#407] In reply to [#405]
Cemortan_Tudor-
Thanks, cPlane is usually a trial and error process- my wish is that a selected planar surface could become the cPlane.
Tracing a bitmap in Illustrator is a lot of work with files that have thousands of curves- editing a Make2D image is the best solution I've found, but still a very long process.
Rick
