Full Version: Sharp points delete, script request.
Show messages: All  1-6  7-18
2 Sep 2014   [#7] In reply to [#6]
Hi Andrei,
> Yes!
> Just want to run script and replace all shar points without any other steps.
Try using the attached version, it has that point picking step removed.
DelCorners.js
2 Sep 2014   [#8] In reply to [#7]
Great Michael, thank you very much!!!
2 Sep 2014   [#9] In reply to [#8]
Michael is it possible to make fillet work on multyple curves at the same time?
2 Sep 2014   [#10] In reply to [#9]
Hi Andrei,
One difficulty with that is that fillet works in a different way currently if you pick 2 different curves, it does a fillet just between those curves like for example if you have 2 individual separate line segments selected that cross each other.
That fillet between 2 individual lines is the sort of old style AutoCAD type curve fillet method.
2 Sep 2014   [#11] In reply to [#10]
It will be nice, to fix it in the future.
2 Sep 2014   [#12]
Some Tips on how to use DelCorners.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.43
1
2 Sep 2014   [#13] In reply to [#2]
>> currently there is no script interface set up to allow scripts to access the individual edit points of a curve
Hi Michael!
Could you implement this interface in the future versions of MoI?
It will be very powerfull tool for scripting.
Something like this:
curve.getControlPointCount()
curve.getControlPoint(index)
curve.setControlPoint(index, newcoords)
and for surfaces:
surface.getUControlPointCount()
surface.getVControlPointCount()
surface.getControlPoint(U_index, V_index)
surface.setControlPoint(U_index, V_index, newcoords)
2 Sep 2014   [#14] In reply to [#13]
Hi Max, yes I do want to add something like that in the future. If you can bring it up again during the v4 development cycle that would be a good time for me to dig into it.
2 Sep 2014   [#15]
2 Sep 2014   [#16] In reply to [#15]
Hi Pilou, for the case you show there, just draw in a new 3 point curve using Draw curve > Freeform > Control points, you'll then have the new segment in the shape you want.
Or another possibility is to use Edit > Separate and then Edit > Join and only join the ending 2 segments together and then run DelCorners on that...
2 Sep 2014   [#17] In reply to [#16]
Yes :)
It was just for know! :)
First method is more suitable and easy!
Mine is draw a new "no corner point" near the old corner then kill the corner point and move the new on the old! :)
3 Sep 2014   [#18]
French version :) http://moiscript.weebly.com/delcorners.html
English one
