Full Version: ping - Max Smirnov
Show messages:  1-6  7-26  27-46  47-66  67-86  87
13 Feb 2018   [#67] In reply to [#66]
Ok. ASAP I will do. Thanks.
13 Feb 2018   [#68] In reply to [#66]
Done!
Now all is ok both in V3 and V4.
Thanks a lot!
15 Feb 2018   [#69]
Hello Max.
While surfing the web searching a tool that I need actually for my daily software developing,
I accidentally found this : https://pressurejs.com/
And it occurred to me the topic you were talking about some days ago : "touchpad gestures"
I don't know that product (https://pressurejs.com/) but it may help you for what you want to do.
If you want, give it a chance. It's free.
Ciao!
Marco (mkdm)
15 Feb 2018   [#70] In reply to [#69]
Hi Marco,
thank you for this link, I'll check this library and maybe I'll find something interesting.
However, I have no plans to use this library in my projects. In the cases when I can write a code by myself, I prefer to not use external libraries and frameworks.
15 Feb 2018   [#71] In reply to [#70]
Hello Max!
@You : "...thank you for this link, I'll check this library and maybe I'll find something interesting...."
You're welcome.
Ciao!
23 Feb 2018   [#72] In reply to [#71]
Hi max,
Have you update Heightmap for V4 ?
Thanks a lot.
23 Feb 2018   [#73] In reply to [#72]
Hi Finema,
I didn't update it yet.
Wait a couple of days, I'll try to fix it.
23 Feb 2018   [#74] In reply to [#73]
OK Max
Thanks a lot.
23 Feb 2018   [#75] In reply to [#74]
Hi Finema,
http://moi.maxsm.net/media/files/Heightmap.v.0.7.2018.02.23(MoI.v4).zip
P.S. I don't know why but this script doesn't work without an alert dialog. I'll check it later (or maybe Michael will help us)
23 Feb 2018   [#76] In reply to [#75]
Hi Max,
It's because setting img.src is asynchronous. When you set img.src it just initiates the image loading process - things are set up in HTML in this asynchronous way often times because it's designed for downloading stuff from remote servers which can take a while.
When you show the alert dialog, that runs a message loop and the timers for image loading are able to get triggered and finish the load.
You could remove the alert dialog though if you split the rest of your image processing functionality into a separate function and then get that set up on the image.onload event, img.onload should be called when the image is all ready.
23 Feb 2018   [#77] In reply to [#76]
Thanks Max !
I like the image in the control panel of heightmap
bravo !
24 Feb 2018   [#78]
Hi Max,
Do you think it is possible to create a MoI plugin like the Rhino Panneling Tools ?
https://wiki.mcneel.com/labs/panelingexamples
2 Mar 2018   [#79]
Hi Max! I am meeting a problem with the 'scale array' plugin too. And I am meeting it in v.3 (I am working in Windows seven). It appears, heavily flickering, only as far as I do keep the attached keyboard button pressed, when I leave the button it disappears. So it is not possible to use it. What may be going on? Any idea, help?
2 Mar 2018   [#80] In reply to [#79]
Hi Dimitri,
I never used this script. Could you send me it?
2 Mar 2018   [#81] In reply to [#80]
Hi Max.
I apologize, I made a mistake :)
Dimitri has written to you because I told him :
"Anyway if your problem is related to the "ScaleArray" you should ask to Max, the author of that plugin, using the forum thread named "ping - Max Smirnov".
I thought that also this plugin was written by you, but I did a check...It was originally written directly by Michael :)
Again, my apologies for the mistake.
Ciao.
Marco (mkdm)
2 Mar 2018   [#82] In reply to [#79]
Hello Dimitri.
I write this text also to you...
I told you to ask Max about the ScaleArray command because I thought that also this plugin was written by him, but I did a check...it was originally written directly by Michael :)
Ciao.
5 Mar 2018   [#83]
No problem Marco, will inform Michael about the plugin. Thanks again! : - )
5 Mar 2018   [#84] In reply to [#83]
You're welcome Dimitri.
Ciao!
8 Sep 2019   [#85] In reply to [#17]
Max,
I note that you regularly like my instagram posts, which I greatly appreciate.
I've been meaning to ask you if you are OK with my link to your instagram in my bio section.
I feel people should be aware that nodeEditor is your creation, so none of my posts would be
possible without you.
Since it is a public account, I assumed you would be fine with my dissemination of your insta-address,
but let me know if you would rather I remove this info.
Also, I remember now you saying to post questions here. Please have a look at this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.875
9 Sep 2019   [#86] In reply to [#85]
Hi James,
>> I note that you regularly like my instagram posts..
Your works are great! :) I'm impressed
Yes. It's ok :) Thank you
