Full Version: ping - Max Smirnov
Show messages:  1-12  13-32  33-52  53-72  73-87
23 Nov 2017   [#33] In reply to [#32]
Yep, that turned out to be the culprit, thanks!
Here's the corrected version:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.79
23 Nov 2017   [#34] In reply to [#33]
Hi Metin,
thank you! :)
I uploaded fixed version to my file archive
23 Nov 2017   [#35] In reply to [#34]
@You : "I uploaded fixed version to my file archive"
Perfect Max! Thanks.
23 Nov 2017   [#36] In reply to [#19]
Hi Max
I updated my post with new error message
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757
23 Nov 2017   [#37] In reply to [#17]
Hi Max
Excepting the bug "Invalid function argument 1 line0" I get when running pentakisDodeca&TruncIcosa.nod (see http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757), all other .nod files run perfectly.
However generally I have the following error intermittently when trackpad navigating & resizing within NE interface. It appears to be triggered by 2 finger gestures (pan & zoom)
TypeError: undefined is not a constructor (evaluating 'this.getCanvasWindow()')
moi://ui/nodeeditor/core/main.js line 4509
4505: case "touchend": type="mouseup"; break;
4506: default: return;
4507: }
4508:
4509: >> var window = this.getCanvasWindow();
4510: var document = window.document;
4511:
4512: var simulatedEvent = document.createEvent("MouseEvent");
4513: simulatedEvent.initMouseEvent(type, true, true, window, 1, first.screenX, first.screenY, first.clientX, first.clientY, false, false, false, false, 0/*left*/, null);
Thank you for your great work
24 Nov 2017   [#38] In reply to [#37]
Hi Max
I spoke too soon. Attached is an example that runs v3 but not v4.
24 Nov 2017   [#39] In reply to [#34]
Hi Max,
I feel like a real coder now, having changed a "," into a ";". :D
Thank you too!
24 Nov 2017   [#40] In reply to [#39]
Yes you just understand that the world's stability depends only on "'" , ",", ":" and sometime ";" without speak about "{" or "}" :)
And alas surely miss some important ones! For exaple the "." :D
24 Nov 2017   [#41] In reply to [#40]
@ Frenchy: :D
24 Nov 2017   [#42] In reply to [#28]
Hello Max.
I've assembled another (I hope) useful model to test your SubDiv scripts and its results.
You can find it at :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8667.47
Ciao ;)
Marco (mkdm)
24 Nov 2017   [#43]
Lets wait the next MoI v4 beta
Sorry, I don't use trackpad, so I can't find a solution of this problem right now.
But few weeks ago I made some changes in functions which affects on getCanvasWindow. I will release a new NE version soon.
Metin
Thank you :) It was just a typo.
Marco
Thank you
But I have no plans to continue development of the Subd script this year.
24 Nov 2017   [#44] In reply to [#43]
Hi Max.
@You : “Lets wait the next MoI v4 beta”
Wise decision!
@You : “But I have no plans to continue development of the Subd script this year.”
No problem Max. I can understand.
You already did a wanderul job (and also for free!)
Ciao.
25 Nov 2017   [#45] In reply to [#43]
Hi Max
Thanks for the update v.0.98.
FYI
>> I made some changes in functions which affects on getCanvasWindow.<<
Despite the changes, the error perists with2 finger trackpad gestures.
moi://ui/nodeeditor/core/main.js line 4508
4504: case "touchend": type="mouseup"; break;
4505: default: return;
4506: }
4507:
4508: >> var window = this.getCanvasWindow();
4509: var document = window.document;
4510:
4511: var simulatedEvent = document.createEvent("MouseEvent");
4512: simulatedEvent.initMouseEvent(type, true, true, window, 1, first.screenX, first.screenY, first.clientX, first.clientY, false, false, false, false, 0/*left*/, null);
I understand that without a MacBook Pro or trackpad periphery device you can't test & find solution, but am reporting it so you are aware.
26 Nov 2017   [#46] In reply to [#45]
Hi James,
thank you for this bugreport
I made some changes to main.js
http://moi.maxsm.net/nodeeditor/main.js
Try it
26 Nov 2017   [#47] In reply to [#46]
Hi Max
Thank you for main.js
It fixed the error message, however there is still some anomalous behaviour with zoom (2 fingers up & down)
Sometime it works, while other time it draws a selection box. This is also true for panning: works intermittently.
Also control clicking on a node does not create a copy of the node.
This is a particularly useful feature, but I think it may have been absent prior to new main.js
Thanks for looking at this. At least now it is possible now to work with NE in v4
1 Dec 2017   [#48]
Hi Max,
i found a bug in nodeeditor...
if you have a slider or knob you can change values with the mousewheel - but if you use a MagicMouse2 or a trackpad it causes NaN if you scroll sideways...
if i go to interface.js and delete all the:
WidgetKnob.prototype.onMouseWheel = function(e)
var v = this.internal.position;
var delta = e.wheelDeltaY/Math.abs(e.wheelDeltaY)/100;
var time = LiteGraph.getTime();
if ( time - this.local.wheelTime < 50 ) { delta *=5 }
else if ( time - this.local.wheelTime < 100 ) { delta *=2; }
this.local.wheelTime = time;
v += delta;
if (v> 1.0) { v = 1.0 } else if (v < 0.0) { v = 0.0 }
this.internal.position = v;
this.properties.value = this.properties.min + (this.properties.max - this.properties.min) * this.internal.position;
this.properties.value = this.properties.value.toFixed(this.properties.digits);
this.updateThisNodeGraph();
this.graph.setisChangedFlag(this.id);
No more Mousewheel ;-(
but no more NaNs :-)
THX for nodeeditor!!
1 Dec 2017   [#49] In reply to [#48]
Hi Ralf,
thank you for bugreport.
Try to replace this line
with this one
var delta = e.wheelDeltaY || e.wheelDeltaX; delta = delta/Math.abs(delta)/100;
1 Dec 2017   [#50] In reply to [#49]
YES! Thats it!
The mousewheel doesnt make any NaNs anymore :)
Thank you
2 Dec 2017   [#51] In reply to [#50]
I fixed Knob and Slider nodes.
You can download updated interface.js here: http://moi.maxsm.net/nodeeditor/
2 Dec 2017   [#52] In reply to [#51]
Tireless repairing! ;)
PS new French lang.js (3 dec 2017)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.js
edit: same address but modified!
Does all that (+ nodeditor) works also for the V3 or it's only for the beta V 4 ?
