Full Version: ping - Max Smirnov
Show messages:  1-4  5-24  25-44  45-64  65-84  85-87
21 Nov 2017   [#25]
Hi Max!
I've tested some of your nodes with V4.
Here you can find a detailed report : http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.49
Ciao!
22 Nov 2017   [#26]
Hi Max.
Maybe you could find interesting this conversation started at http://moi3d.com/forum/index.php?webtag=MOI&msg=8667.17
We are talking about your subDiv tools :)
Ciao!
22 Nov 2017   [#27] In reply to [#24]
Hi Brian
>>In MoI3, the first time it is run, it defaults to UV mode, not U mode. Repeat runs open in U mode.
I tested this script with 3.0(win) and 3.1(mac), and I can't reproduce this UV/U bug. :(
22 Nov 2017   [#28] In reply to [#25]
Hi Marco
>>ERROR : Cloth.v.0.96.2014.02.23.zip (Mon Nov 3 23:56:24 2014)
Thank you, I know about this script error. I'll check it this weekend.
>>Maybe you could find interesting this conversation..
OK, I'll read it right now
22 Nov 2017   [#29] In reply to [#27]
Hi Max,
Upon further testing: If there is a space following the final U, then the UV mode pops up, the first time only.
(I was picking up a trailing space when highlighting for Ctrl_C, Ctrl_V) (silly error)
22 Nov 2017   [#30] In reply to [#29]
I added a command which removes all spaces from script parameters.
You can download new version of the script from my file archive.
http://moi.maxsm.net/files
23 Nov 2017   [#31]
Hi Max,
I just nticed that cMorph doesn't work in the MoI beta. I get this error message:
SyntaxError: Expected an identifier but found 'var' instead
cMorph.js line 47
43: curvesF.setInput( 0, objectpicker.objects );
44: curvesF.setInput( 1, 'Refit' );
45: curvesF.setInput( 2, 0.001 );
46: var curves = curvesF.calculate(),
47: >> var closedCurves = curves.item(0).isClosed && curves.item(1).isClosed;
48:
49: moi.ui.beginUIUpdate();
50: moi.ui.hideUI( 'SelectionPrompt' );
51: moi.ui.showUI( 'MorphOptions' );
Many thanks in advance for updating it.
23 Nov 2017   [#32] In reply to [#31]
there is a , instead a ; at the end of the line
Perhaps it helps if you change it...
Ralf
23 Nov 2017   [#33] In reply to [#32]
Yep, that turned out to be the culprit, thanks!
Here's the corrected version:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.79
23 Nov 2017   [#34] In reply to [#33]
Hi Metin,
thank you! :)
I uploaded fixed version to my file archive
23 Nov 2017   [#35] In reply to [#34]
@You : "I uploaded fixed version to my file archive"
Perfect Max! Thanks.
23 Nov 2017   [#36] In reply to [#19]
Hi Max
I updated my post with new error message
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757
23 Nov 2017   [#37] In reply to [#17]
Hi Max
Excepting the bug "Invalid function argument 1 line0" I get when running pentakisDodeca&TruncIcosa.nod (see http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757), all other .nod files run perfectly.
However generally I have the following error intermittently when trackpad navigating & resizing within NE interface. It appears to be triggered by 2 finger gestures (pan & zoom)
TypeError: undefined is not a constructor (evaluating 'this.getCanvasWindow()')
moi://ui/nodeeditor/core/main.js line 4509
4505: case "touchend": type="mouseup"; break;
4506: default: return;
4507: }
4508:
4509: >> var window = this.getCanvasWindow();
4510: var document = window.document;
4511:
4512: var simulatedEvent = document.createEvent("MouseEvent");
4513: simulatedEvent.initMouseEvent(type, true, true, window, 1, first.screenX, first.screenY, first.clientX, first.clientY, false, false, false, false, 0/*left*/, null);
Thank you for your great work
24 Nov 2017   [#38] In reply to [#37]
Hi Max
I spoke too soon. Attached is an example that runs v3 but not v4.
24 Nov 2017   [#39] In reply to [#34]
Hi Max,
I feel like a real coder now, having changed a "," into a ";". :D
Thank you too!
24 Nov 2017   [#40] In reply to [#39]
Yes you just understand that the world's stability depends only on "'" , ",", ":" and sometime ";" without speak about "{" or "}" :)
And alas surely miss some important ones! For exaple the "." :D
24 Nov 2017   [#41] In reply to [#40]
@ Frenchy: :D
24 Nov 2017   [#42] In reply to [#28]
Hello Max.
I've assembled another (I hope) useful model to test your SubDiv scripts and its results.
You can find it at :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8667.47
Ciao ;)
Marco (mkdm)
24 Nov 2017   [#43]
Lets wait the next MoI v4 beta
Sorry, I don't use trackpad, so I can't find a solution of this problem right now.
But few weeks ago I made some changes in functions which affects on getCanvasWindow. I will release a new NE version soon.
Metin
Thank you :) It was just a typo.
Marco
Thank you
But I have no plans to continue development of the Subd script this year.
24 Nov 2017   [#44] In reply to [#43]
Hi Max.
@You : “Lets wait the next MoI v4 beta”
Wise decision!
@You : “But I have no plans to continue development of the Subd script this year.”
No problem Max. I can understand.
You already did a wanderul job (and also for free!)
Ciao.
