Full Version: ping - Max Smirnov
Show messages:  1-17  18-37  38-57  58-77  78-87
9 Sep 2017   [#18] In reply to [#17]
Just 1 question from me.....
How the hell are you?
Take care!
9 Sep 2017   [#19] In reply to [#18]
Hi BurrMan
I'm fine :) Everything is as usual. I'm working hard last months (as always) so I haven't time for MoI at all.
9 Sep 2017   [#20] In reply to [#17]
Hi Max!!
Wow! ...it's a pleasure to see you here again!!
I hope this isn't inappropriate, but...just a simple question.
What's your main job ? What you do for a living ?
I'm a software developer.
Thanks and have a nice day.
Bye.
9 Sep 2017   [#21] In reply to [#20]
Hi Marco
I'm lead engineer in a company which design and installs fire alarm systems, security systems, building automation etc.
In recent years my team mostly works at Moscow public transport objects (subway stations, depot).
10 Sep 2017   [#22] In reply to [#21]
Hi Max!
Thanks a lot for sharing!
@You : "...I'm lead engineer..."
Ok. Now all it's clear :)
Now I understand why your scripts are so reliable!
Have a nice day.
10 Sep 2017   [#23] In reply to [#17]
Hi Max,
Great to hear from you, and I am excited that you had already thought along the lines of a physics engine node/s for project elephant.
It is inconceivable what parametric possibilities this will unleash.
I can't wait...
21 Nov 2017   [#24]
Hi Max,
I just copied editor.css and editor.js to MoI4betaNov18.
The following script seems to work properly in MoI4beta, but maybe there is a bug in MoI3 version of the script?
In MoI3, the first time it is run, it defaults to UV mode, not U mode.
Repeat runs open in U mode.
_FxGraph3D log(u)/log(10);(v);0;1;10;-0.5;0.5;9;1;0;0;0;U
It is of very minor concern :-)
21 Nov 2017   [#25]
Hi Max!
I've tested some of your nodes with V4.
Here you can find a detailed report : http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.49
Ciao!
22 Nov 2017   [#26]
Hi Max.
Maybe you could find interesting this conversation started at http://moi3d.com/forum/index.php?webtag=MOI&msg=8667.17
We are talking about your subDiv tools :)
Ciao!
22 Nov 2017   [#27] In reply to [#24]
Hi Brian
>>In MoI3, the first time it is run, it defaults to UV mode, not U mode. Repeat runs open in U mode.
I tested this script with 3.0(win) and 3.1(mac), and I can't reproduce this UV/U bug. :(
22 Nov 2017   [#28] In reply to [#25]
Hi Marco
>>ERROR : Cloth.v.0.96.2014.02.23.zip (Mon Nov 3 23:56:24 2014)
Thank you, I know about this script error. I'll check it this weekend.
>>Maybe you could find interesting this conversation..
OK, I'll read it right now
22 Nov 2017   [#29] In reply to [#27]
Hi Max,
Upon further testing: If there is a space following the final U, then the UV mode pops up, the first time only.
(I was picking up a trailing space when highlighting for Ctrl_C, Ctrl_V) (silly error)
22 Nov 2017   [#30] In reply to [#29]
I added a command which removes all spaces from script parameters.
You can download new version of the script from my file archive.
http://moi.maxsm.net/files
23 Nov 2017   [#31]
Hi Max,
I just nticed that cMorph doesn't work in the MoI beta. I get this error message:
SyntaxError: Expected an identifier but found 'var' instead
cMorph.js line 47
43: curvesF.setInput( 0, objectpicker.objects );
44: curvesF.setInput( 1, 'Refit' );
45: curvesF.setInput( 2, 0.001 );
46: var curves = curvesF.calculate(),
47: >> var closedCurves = curves.item(0).isClosed && curves.item(1).isClosed;
48:
49: moi.ui.beginUIUpdate();
50: moi.ui.hideUI( 'SelectionPrompt' );
51: moi.ui.showUI( 'MorphOptions' );
Many thanks in advance for updating it.
23 Nov 2017   [#32] In reply to [#31]
there is a , instead a ; at the end of the line
Perhaps it helps if you change it...
Ralf
23 Nov 2017   [#33] In reply to [#32]
Yep, that turned out to be the culprit, thanks!
Here's the corrected version:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.79
23 Nov 2017   [#34] In reply to [#33]
Hi Metin,
thank you! :)
I uploaded fixed version to my file archive
23 Nov 2017   [#35] In reply to [#34]
@You : "I uploaded fixed version to my file archive"
Perfect Max! Thanks.
23 Nov 2017   [#36] In reply to [#19]
Hi Max
I updated my post with new error message
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757
23 Nov 2017   [#37] In reply to [#17]
Hi Max
Excepting the bug "Invalid function argument 1 line0" I get when running pentakisDodeca&TruncIcosa.nod (see http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757), all other .nod files run perfectly.
However generally I have the following error intermittently when trackpad navigating & resizing within NE interface. It appears to be triggered by 2 finger gestures (pan & zoom)
TypeError: undefined is not a constructor (evaluating 'this.getCanvasWindow()')
moi://ui/nodeeditor/core/main.js line 4509
4505: case "touchend": type="mouseup"; break;
4506: default: return;
4507: }
4508:
4509: >> var window = this.getCanvasWindow();
4510: var document = window.document;
4511:
4512: var simulatedEvent = document.createEvent("MouseEvent");
4513: simulatedEvent.initMouseEvent(type, true, true, window, 1, first.screenX, first.screenY, first.clientX, first.clientY, false, false, false, false, 0/*left*/, null);
Thank you for your great work
