9-28
29-48
49-54
Keyshot called this morning. Unfortunately Alibre/KeyShot3 doe not count for much for an upgrade to Keyshot Pro5
so I had to pay $560 more, for a total of $1196, plus $400 maintenance. Still saved some money.
Keyshot 6 may be released "late next year."
One seat is allowed, but, for example, Home PC seat can be deactivated (on-site) and then laptop or office pc can have an install. & vice versa.
re-activation is "easy." In an emergency, by a call to KeyShot business, if they are open, they can deactivate remotely.
Purchased Camtasia Studio and upgrade to SnagIt for 30% off today.
you will have also a special Keyshot for the new ZBrush for 249$! ;)
http://www.zbrushcentral.com/showthread.php?190182-A-Sneak-Peek-at-the-ZBrush-to-KeyShot-Bridge
""""""""""He has nothing of interest to say to me--and in my view he is envious and childish, and his opinions are dead and hollow. I don't need anyone shoving their viewpoints down my throat, which Michael Spencer-Ford seems to think is a great idea. """""""""""""
Boy did you miss the boat Max. A complete misreading of what has been discussed regarding that....
It would be interesting though, to confirm if KeyShot 5 is "actually rendering the NURBS data" or just "doing their own meshing of the model upon import"..... BY FAR, the first one would be a superior result. If it was the second method, then Meshing in MoI would be preferred IMO.......
Ok guys this thread is getting a bit out of control, I'm going to lock it for further replies.
Please remember that it's very easy on a forum like this where you are not able to see facial expressions or other communication cues that it's particularly easy to misinterpret things.
One last comment to hopefully end this thread.
Max, you wrote above:
quote:
I request that those images marked-up images by Michael Spencer-Ford be taken down from this forum page immediately, as I consider it vandalization of my original artwork. My work is owned exclusively by me, and I have never granted permission to anyone on this site to add their artwork [red ink] to my art/designs.
I'm sorry but it's not really a very reasonable request.
See
http://en.wikipedia.org/wiki/Fair_use :
quote:
fair use is a doctrine that permits limited use of copyrighted material without acquiring permission from the rights holders. Examples of fair use include commentary, search engines, criticism, parody, news reporting, research, teaching, library archiving and scholarship.
It's very clear that Martin was marking up the images strictly as a means of communicating his commentary, absolutely not as any type of vandalism.
This type of use of copyrighted images for means of commentary does not require any special permission from the original author, that's a standard part of copyright law.
I'm sorry that you are upset by this. For the record I think your renderings look very nice and I'd usually recommend the workflow that you posted about originally (save to OBJ for export to Keyshot rather than using a CAD file format), one other reason for that is that you will get sub-object materials (like different materials on different faces of a single solid) to work correctly with .obj export while it won't with a CAD file export.
Thank you Pilou
9-28
29-48
49-54
