Full Version: Polygonal Converter.
Show messages:  1-11  …  32-51  52-71  72-91  92-111  112-131  132-151  152-171  …  472-483
7 Oct 2014   [#92]
Cool
Thx for the infos and tips and tricks!
7 Oct 2014   [#93]
This is great! Thanks Max!
7 Oct 2014   [#94]
Fantastic! You da man, Max, many thanks!
7 Oct 2014   [#95]
Sweet baby jesus this is powerful stuff. Max, I can't begin to tell you how thankful I am that you've implemented this and shared with the community.
While I only started a year or so ago with MOI as a step from STEP to FBX conversion, MOI has become such an invaluable tool that I've more or less gone from Maya polygon modelling to MOI parametric modelling* after nearly 15 years of using Maya. This addition feels like the last missing link between the two. Subdivision sketching can now be brought into MOI for finalizing.
Thank you, thank you, and thank you again.
/Rico Holmes.
*Yes, MOI's THAT good.
7 Oct 2014   [#96] In reply to [#95]
Same here, Rico. 14 years of 3ds Max (1998-2012), then I moved to Blender 3D (which is still my preferred 3D all-rounder), and not long after that MoI entered my life and stole my heart. ㋡
The only thing I really missed in MoI was the powerful branching of polygon subdivision modeling, but Max built an interesting bridge to that now.
7 Oct 2014   [#97]
Don't forget ExplodeMove after subdivide for cool possibilities!
7 Oct 2014   [#98] In reply to [#97]
Pilou, it looks great :)
P.S. Small update (Unsupported polygons stays selected)
7 Oct 2014   [#99] In reply to [#98]
Cool! ;)
7 Oct 2014   [#100]
Cool stuff Max!
8 Oct 2014   [#101] In reply to [#91]
Wow!
Thank You very much!!!
8 Oct 2014   [#102]
Finally found the time to try this cool script.
It looks great. Thanks a lot, Max! I especially love the minimal number of control points.
A question:
When using the max number of subdivs, you still see seams along the surface edges. Will those be gone in the Quality mode? Would be great if the surfaces would have seamless continuity.
All the best,
Metin
8 Oct 2014   [#103] In reply to [#102]
Hi Metin,
Thank you. This was one of the main tasks.
I'm working on it. Fast mode will be used for interactive tuning only.
Yes. At least I hope so :)
8 Oct 2014   [#104]
Here is the Tetrus stp, from an old topic, for testing purposes, if useful.
Not quite as pretty as the old "t-splines" version.
(I bought ViaCad, at the half price special, and used it to convert the stl to stp.
Thanks to those responsible for the tips.)
9 Oct 2014   [#105] In reply to [#104]
Made a small pdf for the customUI Objects, to be placed along with the tetrus .3dm in the Objects folder, if so desired.
I had to manually set the background color in Moi to white, then reset it to the saved "grey" color rgb.
Is there a script way to temporarily set the background color white, and restore the "grey"?
The porcelain lighting seemed to match the 3 default objects.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5410.6
9 Oct 2014   [#106] In reply to [#105]
Hi Brian, check out here for a script that saves the current viewport background color, then sets it to white, then takes a screenshot, then restores the starting color back:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4559.2
9 Oct 2014   [#107] In reply to [#103]
That'd be fantastic, Max, keep up the great work!
9 Oct 2014   [#108] In reply to [#106]
Thank you Michael.
The script works very well.
9 Oct 2014   [#109]
Max,
When I import my OBJ I get a strange error. The mesh is 816 polygons and when I run the Subd converter the mesh just disappear.
Grip.obj
9 Oct 2014   [#110] In reply to [#109]
I did not think that Moi would import .obj format.
9 Oct 2014   [#111] In reply to [#110]
@ Brian
It will if you use Max's importObj script from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.68
That will import quads or triangles (not n-gons) from an .obj file.
