Full Version: Polygonal Converter.
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  105-124  125-144  …  465-483
30 Sep 2014   [#65] In reply to [#64]
Hi Brian, I using this one
Fast Parallel Construction of Smooth Surfaces from Meshes with Tri/Quad/Pent Facets
A. Myles and T. Ni and J. Peters
https://www.cise.ufl.edu/research/SurfLab/papers/08poly.pdf
It can use any solid object with flat faces, which can be created in MoI, or imported using my importobj script.
P.S. Also you can read this document: Smooth Surfaces from 4-sided Facets
T. L. Ni, Y. Yeo, A. Myles, V. Goel and J. Peters.
30 Sep 2014   [#66] In reply to [#65]
Wow Max..... Wow.
Your importobj script? Did I miss that one or is it part of this project?
1 Oct 2014   [#67] In reply to [#63]
I second that Wow!
1 Oct 2014   [#68] In reply to [#66]
Ops.. I forget to share it here :)
Yes, I wrote it as a part of this project, but it can be used separately.
1 Oct 2014   [#69] In reply to [#68]
Really cool stuff Max!
1 Oct 2014   [#70] In reply to [#69]
Thank you Michael.
I still having an issues with extraordinary vertices because I didn't finished with Pm-Patches yet. I hope it will be really cool but a little bit later :)
I plan to release a stable beta at weekend.
1 Oct 2014   [#71]
Sorry where is the Subdiv command ?
It's the one you want release this weekend ?
1 Oct 2014   [#72] In reply to [#71]
At this moment subdiv script is not ready for public release. Wait a few days. :)
1 Oct 2014   [#73] In reply to [#72]
Ok Cool! Thx for the info!
1 Oct 2014   [#74]
Really amazing Max!
Best regards
1 Oct 2014   [#75] In reply to [#74]
Hi Max,
Hope their will be a little 'donate' button somewhere so we can buy you a drink or something :)
1 Oct 2014   [#76]
Hi Max:
For the 2008 paper, ....Tri/Quad/Pent Facets, there is source code and a movie here:
http://www.cise.ufl.edu/research/SurfLab/pubs.shtml
There is an errata file with corrections for page 5 and 6 here:
http://www.cise.ufl.edu/research/SurfLab/papers_html/myles08fast_errata.txt
There is a 2009 paper as well.
1 Oct 2014   [#77] In reply to [#75]
(Hope their will be a little 'donate' button somewhere so we can buy you a drink or something :) )
I'll second that! Very cool, Max.
Ron
1 Oct 2014   [#78]
Agree with Paq !
Thanks Max!!
M
1 Oct 2014   [#79]
Amazing !
1 Oct 2014   [#80]
Wow. Really great stuff, Max! This looks like the ideal bridge between poly and NURBS modeling.
I'm wondering: how clean are the smooth surfaces that are generated, in terms of surface points amount when separated? It would be fantastic if the smoothed version of a model remains adjustable after the smoothing.
Also, models converted with T-Splines in Rhino have trouble managing vertex points with 5 edges (so-called star points), resulting in a visible surface continuity artifact where quad polygons meet at a star point. How does your script manage those?
Can't wait to have a go at this!
Thanks!
Metin
1 Oct 2014   [#81]
TSplines-like modeling in moi? That sounds incredibly useful. Thank you for your effort.
Max.
6 Oct 2014   [#82]
Here is the first public release of the subdiv script :)
In fact this is only a half of the script. It works correctly with ordinary and polar vertices only. But it still has some problems with extraordinary vertices in some cases. I'll finish the second half of the script in nearest future. There will be two methods of subdivision: fast and accurate. Here is an implementation of the fast mode only.
Usage:
Select one solid or group of solids. Run script.
P.S. Would like to thank everybody for support. Thank you!
The idea about a donate button is good. Maybe sometime, but not now :)
6 Oct 2014   [#83] In reply to [#82]
Thanks :o
6 Oct 2014   [#84] In reply to [#82]
Hi Max, cool stuff! Looks like it is working well for valence=4 vertices currently.
