Full Version: Polygonal Converter.
Show messages:  1-11  12-31  32-51  52-71  72-91  92-111  112-131  …  472-483
15 Jun 2014   [#52]
Wow Max, that looks amazing! Are the generated surfaces actual NURBS surfaces? Or just the wireframe as curves?
15 Jun 2014   [#53] In reply to [#52]
At this moment it's just a subdivided mesh. All lines is polylines, not even curves. But it's a just a first step. I've found the algorithm which can produce exact seamless nurbs-surface based on subdivided mesh.
So, stay tuned :)
15 Jun 2014   [#54] In reply to [#53]
Very impressive !
eric
15 Jun 2014   [#55]
Cool!
So what will be the export ? If you export in OBJ : object will be segmented again by the MOi mailer ?
15 Jun 2014   [#56] In reply to [#53]
Max, do you have a link to the algorithm?
I came across this: http://www.cl.cam.ac.uk/techreports/UCAM-CL-TR-773.pdf
Thank you,
15 Jun 2014   [#57] In reply to [#56]
Hi Brian!
I've read a lot of documents about this. The most interesting is:
http://www.dgp.toronto.edu/people/stam/reality/Research/pdf/cc.pdf
http://research.microsoft.com/en-us/um/people/cloop/qteg.pdf
http://www.eecs.berkeley.edu/~sohamum/files/cs284_f12_project_report.pdf
15 Jun 2014   [#58] In reply to [#57]
Hi Max, the difficulty comes with the "extraordinary vertices" - vertices where other than 4 edges are coming off of it.
The subdivision surface behaves somewhat differently in those areas and those are the problematic parts to put NURBS surfaces on.
15 Jun 2014   [#59] In reply to [#58]
Hi Michael.
I am not confident of success, but I'll try to implement Jos Stam's method of calculating the surface exactly.
[added] open mesh support
15 Jun 2014   [#60] In reply to [#59]
Hi Max,
Ok, but evaluating the subdivision surface exactly does not really solve the problem of conversion of the surface into a different form...
I think what you will end up finding is that regular areas of the mesh will convert quite nicely but that there will be difficulties in the areas of extraordinary vertices.
But I'm looking forward to seeing what you come up with anyway! :)
16 Jun 2014   [#61] In reply to [#60]
Michael,
Could the "extraordinary vertices" be easily identified beforehand? This tool, even if there were parts that had to be "left out", would be very cool. Then using other tools to handle the extraordinary part...
17 Jun 2014   [#62] In reply to [#61]
Hi Burr, yeah the extraordinary vertices are pretty easy to identify, they're just vertices where there is some other number than 4 edges coming off of the vertex, see here:
http://www.multires.caltech.edu/teaching/courses/subdivision/intro/sld012.htm
30 Sep 2014   [#63]
This is early beta version of my subdiv script. I'll add more features later. High precision mode (for extra smoothing around an extraordinary vertices), per edge sharpness, and more. Script supports 3- 4- and 5-sided polygons.
30 Sep 2014   [#64] In reply to [#63]
Hi Max, Which scheme are you using?
http://www.holmes3d.net/graphics/subdivision/
Is it going from Nurbs to Nurbs or ?
30 Sep 2014   [#65] In reply to [#64]
Hi Brian, I using this one
Fast Parallel Construction of Smooth Surfaces from Meshes with Tri/Quad/Pent Facets
A. Myles and T. Ni and J. Peters
https://www.cise.ufl.edu/research/SurfLab/papers/08poly.pdf
It can use any solid object with flat faces, which can be created in MoI, or imported using my importobj script.
P.S. Also you can read this document: Smooth Surfaces from 4-sided Facets
T. L. Ni, Y. Yeo, A. Myles, V. Goel and J. Peters.
30 Sep 2014   [#66] In reply to [#65]
Wow Max..... Wow.
Your importobj script? Did I miss that one or is it part of this project?
1 Oct 2014   [#67] In reply to [#63]
I second that Wow!
1 Oct 2014   [#68] In reply to [#66]
Ops.. I forget to share it here :)
Yes, I wrote it as a part of this project, but it can be used separately.
1 Oct 2014   [#69] In reply to [#68]
Really cool stuff Max!
1 Oct 2014   [#70] In reply to [#69]
Thank you Michael.
I still having an issues with extraordinary vertices because I didn't finished with Pm-Patches yet. I hope it will be really cool but a little bit later :)
I plan to release a stable beta at weekend.
1 Oct 2014   [#71]
Sorry where is the Subdiv command ?
It's the one you want release this weekend ?
