353-372
373-392
393-412
413-432
433-452
453-472
473-483
I agree, this is definitely a development path worth investing in. Actually, I would prefer it if Max and Michael would get together and develop this into a fully integrated tool inside MoI. Especially in order to make the final 'on-the-fly shape manipulation' really come together.
I'm not sure such a brilliant synergy would ever happen though. MoI currently has a different toolset and philosophy, and I'm afraid it's outside of Michael's scope. At least for now.
Keep up the good work, Max!
Thank you, guys!
I found program block which allows to load selected objects separately. I used it in beta3, but I turned it off in beta4. Don't ask me why :) I just forgot about it.
Today I turned it on and I was shocked. Look how it works with open surfaces :)
Also I improved open surface engine. Now it processes vertices with more than two naked edges correctly (right one).
Wow! It looks really good!
P.S. Need to sleep. I'll post the new version tomorrow.
My self-portrait after seeing the above two postings:
=:0
Pretty nail! :)
Hi Max,
Hope you get a good night :)
I was looking at your road map, and I'm wondering if anything is planned about a possible surface simplification in the future ? By simplification I mean less edges on the sub-d converted model.
If I remember right t-spline for example only build patches between extraordinary vertex (or something close)
In other words a quad ball with 1 level of subdivision or 5 level of subdivision give the same edge structure once converted. Of course the patches get much more control points.
I'm asking that because it will allow us to use tools like partial edges tension in software like modo.
Here for example a partial edge crease (weight) on a low res model (A). This function is very handy.
(B) on the other hand it the freezed version (so the subdivsion is collapsed).
While the polycount on (B) looks insane, the number of extraordinary is the same than (A).
If I convert model (B) in T-spline, I would get the same numbers of patches than Model (A) ... only more complex patches.
Hi Max,
The latest SubD incarnation is fantastic - something that perhaps you could add in the future to the SubD toolkit is a Pipe Command similar to the TSplines Pipe SubD Modelling from 3d wireframes.
https://www.youtube.com/watch?v=VWRvmmhJBRg
More food for thought.
I also agree that this toolset is becoming so advanced that a pay for model to support your efforts are worthy.
Thanks for time input.
PaQ
I called it surfaces stitching. ( I don't know is that correct name? )
It has been scheduled for version 2.0
AlexPolo
>>I thought about such a script. Maybe someday I'll write it. :)
Hi Max,
Yes sorry, I didn't understand the 'stitching' term (my bad).
And I'm pretty sure you all ready talk about it previously, but boy, ... this is the longest MoI thread ever created I guess :)
Thanks for you dedicated work !
Beta9
- loadMesh function has been improved
- increased overall stability
To get hard edges just split object to several surfaces and then run script.
Max, this is absolutely amazing! Can't wait to play with it. :-)
That's awesome, thanks!
Cool trick for the "crease borders" ! :)
Here the French Version (even with the Alert Messages that i have never think to translate! :)
http://moiscript.weebly.com/subdivision.html
@Max
Can you put something on each start lines code (or before each line) where there is something to translate ?
Because it's an hard work to refind all lines that must be translated in your tremondous codes when there is no ressource file!
Thx by advance for that! :)
/* Careful Pilou next line something to translate! */ or something more smaller like /* */ if you want or more smaller if exist or color words or... :)
| <moi:CheckButton id="preserveCorners" default="true">Preserve corners</moi:CheckButton> |
Beta9 update. Fixed bug with polar triangles with open edges.
Frenchy Pilou
When I write a complex script I always use a lot of comments. And I delete them automatically before publishing.
So it's not a good idea for me to mark text lines with comments. I'll think what I can do.
Gave it a pretty good workout Max... Seems to always work well for how I was using it!
Did some fooling around with using SubDivClassic as a means to "un-subdiv" the parts... Seemed a way to "kindof" revert, but with shrinkage...
Wondering if the "shrinkage" is something that is more or less a known factor, or is it more arbitrary with different geometries?
I didn't want to push too deep into your future plans with the tool.....
<< So it's not a good idea for me to mark text lines with comments. I'll think what I can do.
In my Text editor (NotePad ++) some word to translate are automaticaly in "Bold" but that not explore all! ;)
So maybe number line, color line, extra color word, ...
French version updated! )
Just a question :
In your example, what is the command to directly split surfaces of the solid
is OK to use Separate ?
Also :
It will be great if Subdiv command wasn't destructive like Subdivision Surface in C4D ?
thanks a lot Max !
<< In your example, what is the command to directly split surfaces of the solid
Maybe Select Face(s): Edit / Separate
Select All
Call _subdiv_beta9
And if you subdivide again the result you have a funny rugby ball! ;) (Not shown following)
Message 6674.431 was deleted
Hi Max.
That last post gave me an idea. Love this script. I have already donated some money but plan to give more in the future, Thanks so much. I am teaching 1st year London university students - Moi and Rhino. I think they will love this. My quick "Eames" chair.
353-372
373-392
393-412
413-432
433-452
453-472
473-483
