Full Version: Polygonal Converter.
Show messages:  1-20  …  321-340  341-360  361-380  381-400  401-420  421-440  441-460  …  481-483
25 Sep 2015   [#381]
I've made two illustrations which might help you to understand what extraodinary faces is.
A vertex surrounded by three (1) or more than four (3) faces is called extraordinary vertex. And a vertex surrounded by four faces (2) is called ordinary.
If one or more vertex of a face is extraordinary, this face is called extraordinary too.
My script can load meshes with following types of polygons:
A - Ordinary quads ( 4 ordinary vertices ) - full support, best quality
B - Extraordinary quads ( 1 or more extraordinary vertex ) full support, best quality
C - Ordinary triangles ( 3 ordinary vertices ) looks good, but sometimes an artifacts can be noticable,
D - Extraordinary triangles ( 1 or more extraordinary vertex ) doesn't support at all. produces noticable artifacts on all neighbour faces.
E - Polar triangles ( group of triangles with a common vertex, two other vertices of each triangle must be ordinary ) full support, best quality.
So, you should not use type C and type D polygons.
25 Sep 2015   [#382] In reply to [#381]
THX for the detailed infos!
1 Oct 2015   [#383]
Beta8 will be soon ;)
1 Oct 2015   [#384] In reply to [#383]
Seems there are some new concepts realized!
1 Oct 2015   [#385] In reply to [#383]
Trying to imagine if you get this down to the vertex level..
2 Oct 2015   [#386]
Looks like you're making great progress, Max! Can't wait to try those open surfaces!
Really amazing to see this in MOI - thanks again for all your efforts!
2 Oct 2015   [#387] In reply to [#383]
Hey Max,
Do you think it might be possible to have an option to crease open edges ?
In practice it should even be the 'default' behavior, but I'm probably biased by Modo default settings.
2 Oct 2015   [#388]
BWAAA!!! SOOOO AWESOME Max! :-) ..oh, the evil plans are a conjurin'
2 Oct 2015   [#389]
I think PaQ's suggestion would make a lot of sense as a 'default'. Having an option to crease other (non-outer) edges would be the icing on the cake, if possible ;-)
2 Oct 2015   [#390]
Hi guys!
archetype
Next weekend, I hope. Maybe earlier, maybe later :)
It's possible, I have it in the plans.
PaQ
Yes. I've wrote this script block yesterday.
2 Oct 2015   [#391] In reply to [#390]
It's looking great Max!
2 Oct 2015   [#392]
Wonderful, thanks Max !
3 Oct 2015   [#393]
That amazing Max!
4 Oct 2015   [#394]
Woah! Sweet!! Need to create a tutorial on *that* version!
5 Oct 2015   [#395]
Thank you :)
The work is going on successfully.
I need from two to five days to finish it. In fact I can do it during one evening, but I'm busy at work (as always) :)
5 Oct 2015   [#396]
Somptuous!
5 Oct 2015   [#397]
Can't wait! :-)
5 Oct 2015   [#398]
Thickness possible or problematic for the last example?
6 Oct 2015   [#399]
Beta8
Added: open surfaces support
This version can be unstable. I need to optimize it, fix a lot of bugs, surface issues e.t.c.
Updated version will be soon.
Frenchy Pilou
The shell command can't process this shape.
6 Oct 2015   [#400] In reply to [#399]
Very funny scene! :)
And bravo for the task even some little glitches are maybe persisting!
