Full Version: Polygonal Converter.
Show messages:  1-15  …  216-235  236-255  256-275  276-295  296-315  316-335  336-355  …  476-483
27 Mar 2015   [#276] In reply to [#275]
27 Mar 2015   [#277]
Excellent!
27 Mar 2015   [#278] In reply to [#273]
Hi Max,
> I have one question.. Do you plan to update MoI in nearest
> future? I mean x86 version.
Sorry, no I don't expect to have any updates anytime very soon...
Currently I'm experimenting with 64-bit stuff for v4, and still just in the early stages of that.
27 Mar 2015   [#279]
Knife is implicite!
A simple Boolean Diff makes the tricks! :)
27 Mar 2015   [#280]
Max, I repeated Frenchy's little model above; and it worked as shown. But extruding other faces does not work, and results in an error [2] or error [4].
Can you explain a little about these errors, and what things to avoid before invoking sub-D command? I have seen some very complex models work fine in other demos.
Thanks for your fantastic tools!!
Ron
27 Mar 2015   [#281] In reply to [#280]
Hi Ron,
The extrude tool sometimes split edges to parts. Try to select all edges and run Merge command.
28 Mar 2015   [#282]
Thank you Max. Great work.
OT: We need a dedicated page where users can upload the latest version of their scripts. Asap. We can't follow the threads everytime to be sure of getting the newest version.
28 Mar 2015   [#283]
subdSplit 0.9
now it uses pointpicker instead of slider
I'm very satisfied with the results
This version is close to 1.0.. Need to fix a couple of rare bugs :)
wastzzz
I made a site several months ago, but I haven't free time to fill it with information. Maybe someone help me?
Anyway, you can download all latest versions of my scripts here: http://moi.maxsm.net/media/files
28 Mar 2015   [#284] In reply to [#283]
really nice work Max !!!
28 Mar 2015   [#285]
very nice!! amazing. Thanks for taking time to work on this new plugin.
28 Mar 2015   [#286]
Very very cool ! Bravo!
but you don't answer me about an automatic selection of all new faces "Splited" at the end of the sSplit function?
28 Mar 2015   [#287]
Thank you Max - these tools keep getting better.
Can you explain usage of the Repeat check box on the latest Split tool?
I get stuck with an dialog box that I can't close, saying to pick an edge or a face, even though I already have a selection.
28 Mar 2015   [#288] In reply to [#286]
Frenchy Pilou
Forgot about this. Sorry :)
When you asked me I tried to do this, but I couldn't done it successfully :(
When MoI joins separated parts it changes ID's of the faces. So I can't find which faces are new created.
At the moment I know only way to do it: create a new style. assign it to a new faces. join surfaces. restore selection. revert styles.
It will work, but I don't like this method.
I think we should ask Michael about this :)
28 Mar 2015   [#289] In reply to [#287]
Hi Ed
I can't explain because my script doesn't use it :)
added "norepeat noautolaunch" key to disable it.
script reuploaded.
28 Mar 2015   [#290] In reply to [#288]
No problem :)
We shall make some clicks more! ;)
...and waiting some Michael's tricks :)
Ps I will start in a second the Last Max Plugins' versions! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7320.1
28 Mar 2015   [#291]
In Plugin Subdivision what is the use of the View Control Points
as we can't select them! ?
28 Mar 2015   [#292] In reply to [#288]
Hi Max,
Yeah that's just basically how ID values work - they are basically tied to a specific version of an object. When an object is edited in any way, the new objects generated from that then have their own new ID values as well.
Maybe instead of setting up a style to track it you could assign object names to the faces you want to track, I think they should persist across the separate as well.
28 Mar 2015   [#293] In reply to [#291]
""""""""In Plugin Subdivision what is the use of the View Control Points
as we can't select them! ?"""""""""
You can preview the point structure you are making. One of the unique things about max's script is it will generate "solids" that will show their points, like a revolve object does....
29 Mar 2015   [#294]
Impressive work Max, thanks for sharing :)
31 Mar 2015   [#295]
How in the heck did I miss this! This is an awesome set of tools Max!
I can't wait to see you future progress with the sub-d tool in Moi.
Two things I'd be interested in:
1) A way to sub-D with an open face. The perimeter around the open face staying pretty much static except for it's own division.
For an example, if you divided a cube with a missing face, you would end up with sort of a cup shape.
2) If only there was a way to take existing Moi multi-surface solids and convert them into polygonal structures much like the .obj export works, except in a live manner that allows for sub-D to work on it.
In effect a melty tool for an existing Moi object.
But what do I know? My head is spinning of the possibilities of incorporating some pseudo organic character into any Moi model. ...it's like a teaser T-spline.
