Full Version: Polygonal Converter.
Show messages:  1  …  202-221  222-241  242-261  262-281  282-301  302-321  322-341  …  482-483
26 Mar 2015   [#262]
Excelent trick - merci
26 Mar 2015   [#263] In reply to [#262]
For kill the internal best is redraw a polygonal volume inside and make a boolean diff!
26 Mar 2015   [#264]
Dedicated thread for Max's SubD Scripts?
With Max working on new scripts and folks experimenting and sharing results, maybe all posts related to his SubD work should go into a new thread.
26 Mar 2015   [#265]
edgeSplit preview
26 Mar 2015   [#266]
A cup of tea! :)
26 Mar 2015   [#267]
Frenchy Pilou
>> what is the difference with View Points and use the Edit Frame ?
No differences in the v0.5. Check the new one.
My script determines center by averaging a source points. Edit frame uses boundary box center.
>> Does it possible to have Ngons like this ?
It's possible, but not now. My subd script doesn't support ngons.
blowlamp
>> Brilliant work like this shouldn't go unrewarded.
>> Can I suggest you get a Bitcoin wallet and start accepting donations through it?
Thank you. I'll think about it :)
26 Mar 2015   [#268] In reply to [#267]
Cool last one!
26 Mar 2015   [#269] In reply to [#265]
Great work Max, thanks for sharing all of these new tools!
27 Mar 2015   [#270]
Volume with Max Smirnov scripts goes in Sketchup and realtime rendered with the free Visualizer 1.3 ;)
http://getvisualizer.com/
27 Mar 2015   [#271] In reply to [#269]
Amazing. This makes a great bit of software even better. I cannot believe that this has become a toolset available in MoiV3. I was secretly hoping we might have it in V4.
It opens some exciting opportunities for the students I teach.
27 Mar 2015   [#272]
sSplit 0.8
[Added] edge splitting
27 Mar 2015   [#273] In reply to [#269]
Hi Michael
Thank you!
I have one question.. Do you plan to update MoI in nearest future? I mean x86 version. I will be happy if I could get some new features (and js functions) :) If it possible, of course..
27 Mar 2015   [#274] In reply to [#273]
The last split zip is downloading as corrupted on my end.....
27 Mar 2015   [#275] In reply to [#274]
my fault. fixed.
(it was 7z-archive with .zip extension :)
27 Mar 2015   [#276] In reply to [#275]
27 Mar 2015   [#277]
Excellent!
27 Mar 2015   [#278] In reply to [#273]
Hi Max,
Sorry, no I don't expect to have any updates anytime very soon...
Currently I'm experimenting with 64-bit stuff for v4, and still just in the early stages of that.
27 Mar 2015   [#279]
Knife is implicite!
A simple Boolean Diff makes the tricks! :)
27 Mar 2015   [#280]
Max, I repeated Frenchy's little model above; and it worked as shown. But extruding other faces does not work, and results in an error [2] or error [4].
Can you explain a little about these errors, and what things to avoid before invoking sub-D command? I have seen some very complex models work fine in other demos.
Thanks for your fantastic tools!!
Ron
27 Mar 2015   [#281] In reply to [#280]
Hi Ron,
The extrude tool sometimes split edges to parts. Try to select all edges and run Merge command.
