>>Is there any more that can be done with this?
>>maybe you could do "all that you can" with this as the "main tool of the bag", before all the "timesaver" trick scripts.....
I have some difficulties with subd script. Unfortunatelly Moi javascript tools has very limited nurbs functionality. I can build curves of degree 2 or 3 only. I can't ajust control points weights. I can't build curves with double knots. etc..
So I need to find the way how to improve my script in this situation. But right now I'm tired of it. I need to switch to something else. So I decided to take a rest and write several simple scripts. After few weeks I'll continue my experiments with the main script.
Function Draw Curve Polygon
Extrude
Kill first polygon curve generator if not need
The trick : Select volume so a solid but sSplit need only faces!
So after select volumum (solid) use the Browser button for choise Faces ;)
Then use sSplit !
Et voilĂ
Frenchy Pilou
>> what is the difference with View Points and use the Edit Frame ?
No differences in the v0.5. Check the new one.
My script determines center by averaging a source points. Edit frame uses boundary box center.
>> Does it possible to have Ngons like this ?
It's possible, but not now. My subd script doesn't support ngons.
blowlamp
>> Brilliant work like this shouldn't go unrewarded.
>> Can I suggest you get a Bitcoin wallet and start accepting donations through it?
Thank you. I'll think about it :)
Amazing. This makes a great bit of software even better. I cannot believe that this has become a toolset available in MoiV3. I was secretly hoping we might have it in V4.
It opens some exciting opportunities for the students I teach.
I have one question.. Do you plan to update MoI in nearest future? I mean x86 version. I will be happy if I could get some new features (and js functions) :) If it possible, of course..
